Interior Molle Racks- safety concerns
Discussion in '3rd Gen. Tacomas (2016-2023)' started by D Soulman, Dec 13, 2020.
  1. Dec 13, 2020 at 8:11 AM
    D Soulman
    D Soulman [OP] Well-Known Member
    Dan
    Fargo, North Dakota
    Hi, I am considering some center console Molle racks and wondering if there are any safety concerns in the event of an accident. Seems like they could pose a risk if they came loose or were smashed sideways? Or am I just overthinking it? I like the idea but just wondering if this has been addressed- by the manufacturers possibly?
    Thanks, Dan.
  2. Dec 13, 2020 at 8:20 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Most of the area inside the cab is rigid enough that in the event of a crash the cab wont buckle causing the racks to come loose. The bigger issue with these racks in a crash is what you mount to them. If you have a fire extinguisher on there and it comes loose in a crash, you now have a giant metal wrecking ball flying around the cab.
    Tacospike likes this.
  3. Dec 13, 2020 at 8:36 AM
    Tacospike
    Two Trucks
    No more than any other loose items in the truck or projected objects coming into the truck..... or the accident itself
  4. Dec 13, 2020 at 8:39 AM
    D Soulman
    Dan
    Fargo, North Dakota
    True, but they are a fairly good sized piece of stout metal, I don't typically have a lot of that in the cab.
    Thanks for the replies guys!
    Tacospike[QUOTED] likes this.
  5. Dec 13, 2020 at 8:42 AM
    Iwilltaco
    Iwilltaco Well-Known Member
    @kairo’s guest house having a water with @not_nick
    Under development
    I wouldn’t be worried about the panel itself. Just consider what you are mounting on it. Use your best judgment
  6. Dec 13, 2020 at 8:43 AM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    You walk out of the house in the morning and you take your chances!
  7. Dec 13, 2020 at 8:46 AM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    This
  8. Dec 13, 2020 at 8:53 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    I originally posted thinking you were referring to overhead molle racks and deleted that post lol.
    The console mounted type I am not super concerned about. If you are really concerned, what you can do is instead of screw mounting them, I’d mount using bolts and fender washers on the inside of the plastic. Much more stout install in the event of a wreck. If you get hit hard enough to crumple the central body hump, you’ve got other things to worry about.
    I do tend to agree, loose drink cups or groceries in the rear seat are more of a “risk” than those molle panels
  9. Dec 13, 2020 at 9:15 AM
    D Soulman
    Dan
    Fargo, North Dakota
    All good points- thank you.
  10. Dec 13, 2020 at 10:33 AM
    ICU1
    ICU1 Well-Known Member
    In an accident, everything inside a vehicle is a potential projectile. I was involved in a rollover and a loose twenty dollar bill got impaled into the headliner trim piece. Imagine what that bill could have done to your face...
  11. Dec 13, 2020 at 7:47 PM
    D Soulman
    Dan
    Fargo, North Dakota
    You all have put my fears to rest. Thanks for the input all! Now to decide which brand. Leaning towards Cali Raised. Any feedback regarding the different vendors?
  12. Dec 14, 2020 at 9:18 AM
    Malvolio
    Malvolio free zip ties for Stun
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    I’d just add that you should consider low-profile heads (button-head hexes, maybe) on the bolts; and keep in mind that a lot of rollover injuries occur when people are hanging upside down and unbuckle, crashing headfirst into the inverted ceiling. That ceiling is now going to have metal edges and exposed bolt heads and whatever else you have attached to it. And, of course, anything strapped up there may come loose and hit you and your passengers in the face or arms or whatnot if and when there’s a crash.
