Interior of Taco incredibly weak.. Plastic scratches easily..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Airwolf NSX, Feb 10, 2010.
  1. Feb 10, 2010 at 4:23 PM
    Airwolf NSX
    Airwolf NSX [OP] Well-Known Member
    Irvine, CA
    2010 Tacoma TRD Sport Double Cab
    So my friend decided to put his backpack on the floor while sitting in my truck.. As he was trying to push it between his legs, he ended up scuffing (pretty deep scratches) into the plastic of the glove compartment and the center console area..
    Ugh. what an eye sore.. I have to see this everytime now.. His bag wasn't even hard or had metal clips or anything.. Just regular zippers and it ended up scratching it pretty deep.
    Is it known that our Tacomas have weak brittle plastic interior that scratches easily?
    Is there anything I can do to make the scratch less visible? (I know, wishful thinking)
  2. Feb 10, 2010 at 4:40 PM
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    Yup, the interior of our trucks are really fragile. Iused my fingernail to file down the gouge, then spread a thin layer of vasoline to hide the scratch. Some people have used a blow dryer or heat gun to soften the scratched area and rubbed the scratch to blend it in.
  3. Feb 10, 2010 at 4:41 PM
    Airwolf NSX
    Irvine, CA
    i dont' understand how vasoline helps hide the scratch??? is it only temporary while it's on there but when you rub it off, it's visible?
  4. Feb 10, 2010 at 4:42 PM
    REVHARD25
    REVHARD25 Well-Known Member
    so cal
    RUGGED TRAIL PACKAGE
    Tint on front windows. Dnx7120 kenwood. Rear tsb springs. Wet okoles seat covers UWS truck box Weathertech floor mats TSB floor mat hook grommets Satoshi grill AFE drop in filter Fumoto drain valve Bed mat
  5. Feb 10, 2010 at 4:42 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    15 Black DC OR Prerunner
    I just dont even bother. To me its a truck and a few scratches dont bother me.
  6. Feb 10, 2010 at 4:43 PM
    09TRDSpt
    09TRDSpt African Light Infantry
    Atlanta, GA
    09 TRD Sport DC 4x4
    Use a lighter to warm up and depress with a finger. Don't get it too hot just warm up the spot and it will be alot less noticable.
    Did that with great success on my dash under the HVAC.
  7. Feb 10, 2010 at 5:23 PM
    BeardedWeirdo
    BeardedWeirdo Junior Mint
    Texas
    2010 AC SR5 PreRunner
    Barcelona Red Pop & Lock, Tint, New Shoes, Removed Rear Headrests, Grille(in the works)
    Jeez, what were the zippers made of? Metal or something?! :D Just messing with you.
    I've got a couple already and I have no idea how they even got there. I'm going to heat them up like the others said. That's how I've fixed them in other vehicles in the past.
  8. Feb 10, 2010 at 5:27 PM
    steviestyles
    Colorado Springs
    Bone Stock
    The Vasoline isn't going to get rid of the scratch, but will do a very good job at hiding it. Second the Vasoline doesn't come off that easily unless you puposely wipe it off with Armor all or something like that. I've noticed over time the petroleum base in the Vasoline fades the scratch as it absorbs into the plastic. Think how it works on dry skin. If your scratches are that bad, you're going to have to do the heat gu/lighter method.
  9. Feb 10, 2010 at 5:46 PM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    You have a double cab with i assume, an entire back seat available, and some idiot felt the need to shoe-horn the back pack into the small crevice between his knees and the dash.
    Sounds like that 'soft plastic' may not have been the issue here. People need to use their heads a little.
  10. Feb 10, 2010 at 5:51 PM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    its a truck.....
  11. Feb 11, 2010 at 5:10 AM
    Got Tacoma
    Got Tacoma Well-Known Member
    Gila
    Arizona
    2010 Dbl. Cab Sb 4 x 4 Trd
    Undercover Tonneau, Roof Rack, ABR Bumper, Warn 9.5xp, OME 886, Dakar leaf springs, Bilstein 5100 Struts and shocks
    Everyone has a brain the problem is most people do not use their brain.
    I don't think the Tacoma interior is more scratch prone than any other vehicle out there. I have seen cars with destroyed interiors 4 years old and the same model owned by someone else 15 years old with a perfect interior.
    Example #1 of lack of brain usage
    Jam and cram a bag with a zipper on it into a tight space composed of hard plastic = scratches and gouges.
    Example #2 of lack of brain usage
    I sure everyone here has seen a passenger in a vehicle with their feet on the dash at 70 mph. I have even seen drivers with their left foot on the dash while driving. Cars and trucks are not living rooms. They are fun to drive and look at but can become injury causing appliances at any time.
    When in a vehicle you are supposed to sit in your seat like a person who is using their brain.
    Sit with your feet on the dash and have an accident = potential stretched and severed spinal cord. Lots of fun to never walk again.
    And the list goes on and on
  12. Feb 11, 2010 at 5:39 AM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    holy common sense overload! :eek:
  13. Feb 11, 2010 at 5:55 AM
    default83
    default83 Active Member
    Katy
    01 DC 2wd
    my interior is all F*ed up, used to be my work truck, screw it, if your concerned about it, then do what they said, use the heat gun,
    i would be kind of leary about this though, i would think it would weaken the plastic more than it already is, like when you heat metal it gets brittle, idk just a thought.
    or REALLY fine grit sandpaper might work?
  14. Dec 25, 2010 at 8:47 AM
    jetchef
    jetchef Member
    I had a guy from best buy put a cardboard box in my front seat, rest of truck was packed solid. Barely brushed the rubber like material that covers the airbag above the glove box. Left 3 big scratches. Dealer says 1400 for a new piece and Toyota told me to go f myself, they weren't paying for it. Truck gas 900 miles on it. I get to look at these scratched for the next 100000+ miles.
    Taco interior is a brittle P O S. So much for rugged.
  15. Dec 25, 2010 at 8:55 AM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    A metal zipper will scratch any interior and I don't see how a cardboard box is going to leave three big scratches unless something was sticking out of it. I always pack stuff in my truck myself, ever notice it's always someone else that messes up the interior ? You also have to watch out for watches, bracelets, rings, etc.
  16. Dec 25, 2010 at 9:17 AM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    The last sentence applies to more than one post.
  17. Dec 25, 2010 at 9:54 AM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    A lot of complaints I have seen on these forums fall into this category as well. Things break, paint will scratch, things will make noise not vehicle is immune but of course there is the occasional lemon.
  18. Dec 25, 2010 at 10:16 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    the last time i did injection molding/making plastic parts,they were soft.i dont think our plastic trucks(all trucks)are any different.welcome to the new age of plastic.
  19. Dec 25, 2010 at 10:31 AM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    When you use things, they will get wear.
    Such is life.
  20. Dec 25, 2010 at 10:38 AM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    :amen:
