Interior Overhead Molle Rack
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MESO, Oct 31, 2018.
  1. Jun 24, 2020 at 5:25 PM
    #981
    Tacospike
    Two Trucks
    You might need to adjust your insert tool to tighten more.
    You have the first squeeze to insert the jack nut but you might need to adjust for a for the full tolerance.
    if you have a manual tool there is a dial on the top head to adjust, I used a nematic tool to pull till threshold is met to tolerance
    MESO[OP] likes this.
  2. Jun 24, 2020 at 5:33 PM
    #982
    svermilyea
    svermilyea Well-Known Member
    Scott
    East Tennessee
    2018 Taco Sport (Cement)
    3in leveling lift (Coilovers and AAL) 285/65R18 tires 18" Fuel wheel/tire package Pro Grill, Morimoto XB LED Headlights, DD SS3 Pro Fogs Body Armor Front and Rear Bumpers Pioneer WC6600 head unit w/ OEM Audio + Reference 500 System with dedicated sub amp Meso signal lights, gas hole, led interior lights, ECT relocate, Chrome delete kits Meso Overhead Molle Rack, Seat Risers, Katzkin Leather seats (self installed...it was a fucking bitch) VFTuned .....KDMax Pro!
    I used a pair of needle nosed vice grips to hold the jack bolts. I tightened them with my impact driver. They are snug and do not move. Also, when you torque the unit into place, they finish tightening up.
  3. Jun 24, 2020 at 6:57 PM
    #983
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    This. Readjust the tool and crimp again. You want the jack nuts tight.
    Tacospike[QUOTED] likes this.
  4. Jun 24, 2020 at 8:29 PM
    #984
    CP40
    CP40 Well-Known Member
    Toyota Tacoma TRD off-road 2020
    I will. I bought the tool suggested in your instructions. Can you tell me with more detail exactly how to do that?
  5. Jun 24, 2020 at 8:36 PM
    #985
    MESO
    State of Jefferson
    The end should have an adjustment screw. You need to tighten that up and re-crimp the jack nut.
  6. Jun 24, 2020 at 8:44 PM
    #986
    CP40
    Thanks. I'll try that.
  7. Jun 24, 2020 at 8:57 PM
    #987
    brentano
    brentano Well-Known Member
    2017 TRD OR AC SSM
    :sawzall:Access Cab Meso Molle Love
    As an AC owner with limited interior space, I’ve always felt a little left out of the Meso Molle party.
    There are decent alternatives, but I like the robustness of the pre-bent Meso design.
    I lobbed off the “ears” of the Molle rack, drilled on-center holes and mounted it up using the Meso hardware. No extra bending required.
    Vertical downward stability is excellent and the front to back rocking is minimal: I get about 1/32 of an inch rock when I press hard on the rack. The result is more than adequate for my needs.
    DIY installation notes are here.
  8. Jun 24, 2020 at 9:00 PM
    #988
    MESO
    State of Jefferson
    Wow! Thanks for the intel. I have never test fit it on an access cab so that’s cool it worked. I might have to tweak the files and offer something like this in the future for AC guys. I never thought 1 bolt on each side would be stable but good to know now :)
  9. Jun 24, 2020 at 10:05 PM
    #989
    CP40
    Tried to tighten the river gun and re-crimp. No difference. The jack nuts slide back and forth still.
    I'll take pics tomorrow
  10. Jun 25, 2020 at 1:14 PM
    #990
    Fused_Taco
    Fused_Taco Well-Known Member
    Franco
    Wyoming
    2017 Toyota Tacoma OffRoad
    @MESO Any photos with the hexpod led on the rack? And also you should make some of these sunroof model racks in OD
  11. Jun 25, 2020 at 4:06 PM
    #991
    YearofRevival
    YearofRevival Well-Known Member
    Anthony
    Cleveland, OH
    2018 TRD Stormtrooper
    Way too many lights. Genesis Off Road Dual Battery. Volant Powercore w/Ram Air Intake. Corsa “Sport” Cat Back Exhaust. SSO Slimline Hybrid Bumper (Stage 1 & 2) with Smittybilt XRC 9500. 2” BORA Spacers. Expedition Essentials TPAM. Custom Door Mounted Molle Panels. Qi Charger replaced with Cobra CB Radio. On Board Air courtesy of McGyver skills. BAK MX2 Tonneau. Cali Raised LED Fog Lights. Indestructible Vinyl Fender Flares. Mobtown Offroad Tailgate Panel. Amazon PA System. Wolo’s “The Chief” Air Horn. Hella Supertone Horn. Icon Stage 9 Suspension with Total Chaos Expedition LCAs. More Lights
    Been a long time coming... thank you @MESO
    Crom, K-Bear, Grindstone and 2 others like this.
  12. Jun 27, 2020 at 3:22 PM
    #992
    Xx_Evilvirus_xX
    Xx_Evilvirus_xX Well-Known Member
    Houston, TX
    2018 Tacoma TRD Offroad 4x4
    I'm assuming this goes for those who got the retention kit??
  13. Jun 27, 2020 at 3:51 PM
    #993
    svermilyea
    Scott
    East Tennessee
    If you are going to use jack nuts often, buy the tool from Amazon, it's worth it (very easy). Otherwise you can just hold the jack nut with a set of needle nosed vice grips, and torque it into place with the screw that comes with it. Yes, these are used to anchor the overhead molle rack and and retention Kit. I set the jack nuts first and then installed the molle rack. Once that was done, I pulled one screw out at a time, and installed the retention kit and grab handle.
    MESO[OP] and Xx_Evilvirus_xX like this.
  14. Jun 28, 2020 at 9:24 AM
    #994
    K-Bear
    K-Bear Well-Known Member
    2017 Inferno DCSB TRD OR
    Anyone have their handles they took off for sale?
  15. Jun 28, 2020 at 9:47 AM
    #995
    Afilao
    Afilao Tacoma Driver
    SoCal
    ‘18 MGM DCSB Off-Road 6MT
    For the people having trouble with the install. I want to encourage you to give up and sell me your molle rack. I’m just a bit jelly...:rofl:
    Xx_Evilvirus_xX and DSRamsey13 like this.
  16. Jun 29, 2020 at 7:43 PM
    #996
    YearofRevival
    Anthony
    Cleveland, OH
    Mine are a bit scuffed from being removed twice. Once for antenna removal and once again for the Molle rack. But they are intact. Unless you live on the other side of Earth, I’ll send them to you. PM me.
  17. Jun 29, 2020 at 7:58 PM
    #997
    Ducman82
    Ducman82 Well-Known Member
    jake
    2016 Sand Tacoma TRD
    darn sun roof .....
    Frsh2df likes this.
  18. Jun 30, 2020 at 9:13 AM
    #998
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I notice you have the same med kit bag as I do. If yours hangs down alot, sew the center of the velcro to the backing of the rip away panel.
    You can see the gray stitching I have on mine that follows the sew lines of the molle straps. Mine hung down like 2 inches before I had my MIL sew a few lines in there.
  19. Jul 2, 2020 at 10:28 AM
    #999
    dewelrTX
    dewelrTX Well-Known Member
    Dewel
    SAN ANTONIO, TEXAS
    2019 Tacoma TRD Off-Road 4x4 DCLB
    Finally got around to installing mine. Super easy install. Glad I was able to get one. :bananadance:
  20. Jul 2, 2020 at 2:45 PM
    #1000
    Beef Nachos
    Beef Nachos Here for a good time, not a long time
    Dallas/Ft. Worth
    2017 SR5 DCSB 4x4
