Interior Overhead Molle Rack
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MESO, Oct 31, 2018.
  1. Jul 3, 2020 at 5:21 PM
    #1021
    Gen2Tacoma
    Gen2Tacoma A Question Asked is an Answer Learned!
    North East Atlanta
    Anyone mount a CB to this. I know its in the rear but just checking. Thoughts?
  2. Jul 3, 2020 at 5:30 PM
    #1022
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    That was a nasty little tease! :annoyed:
    Aluminum yes! raw or powder coat as a drop down option. Now, will the aluminum need to be thicker to keep the same strength for the non sunroof models.
    I call first dibs on the one in the pic, I'll take the non sunroof hex model as is!
  3. Jul 3, 2020 at 7:17 PM
    #1023
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Thread the tool out a little bit till you can get some threads in.
  4. Jul 3, 2020 at 7:30 PM
    #1024
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Unscrew the thread out and it should give you more length to engage the jacknuts. Some tools also have another “collar” Threaded on the end and that can be removed as well for a little more length.
  5. Jul 3, 2020 at 10:22 PM
    #1025
    SubaruTheTacoma
    SubaruTheTacoma SubaruTheTacoma
    Rhys
    USA
    2017 STI Off Road
    HELLA Horns BP-51 ARB Summit SCS Ray 10 And many many others
    Powder coated pink!!!! Please and thank you
  6. Jul 4, 2020 at 6:53 AM
    #1026
    PinoyTaco27
    PinoyTaco27 Well-Known Member
    East Stroudsburg, PA
    2018 TRD Sport Double Cab
    Would you be able to connect these two pieces together for more surface storage space?
  7. Jul 4, 2020 at 8:54 AM
    #1027
    UncleRick
    UncleRick Well-Known Member
    Rick
    2012 Tacoma Prerunner
    I'm curious too. Hard to find a place to mount a full size CB in a taco.
  8. Jul 4, 2020 at 2:38 PM
    #1028
    LOWEREDLIFESTYLE
    LOWEREDLIFESTYLE Well-Known Member
    Orlando, FL
    2019 TRD OFFROAD 4X4 (Super White)
    Stealth Customs, UpTop, Morimoto, Diode Dynamics, Meso Customs, Borla, Rotopax, etc
    Got mine installed after fighting a little bit with the jack nuts. Figured the trick out after the first one, and the rest went in fine.
  9. Jul 5, 2020 at 2:35 PM
    #1029
    brentano
    brentano Well-Known Member
    2017 TRD OR AC SSM
    @MESO could you please provide the dimensions of the HEX cutouts.
  10. Jul 6, 2020 at 6:09 AM
    #1030
    Tacospike
    Two Trucks
    Pretty small
  11. Jul 6, 2020 at 3:39 PM
    #1031
    MESO
    State of Jefferson
    32MM from edge to edge
    We're getting closer... Aluminum coated black. These are my final samples and if testing goes well we will start production on the new HEXrack Line. Also coming out with a custom packaging box and better hardware to make it easier for everyone to install.
    cencal_taco, Toynado, KUMA26 and 11 others like this.
  12. Jul 6, 2020 at 3:40 PM
    #1032
    Frsh2df
    Frsh2df Well-Known Member
    2017 MGM TRD Off Road 4x4
    Looks awesome , so can’t wait to grab one :thumbsup:
    Tacospike likes this.
  13. Jul 6, 2020 at 4:09 PM
    #1033
    Gen2Tacoma
    North East Atlanta
    Can you please school me on why this is better? I'm new to this. I get the aluminum switch but why the hex holes verses slots? There must be hex mounts that fit in the holes. (I saw your previous post on this) But why is this better and where do you obtain the hex mounts. ( I googled it with out much success success) Thanks in advance!
  14. Jul 6, 2020 at 4:17 PM
    #1034
    MESO
    State of Jefferson
    The hex gives more versatility on mounting. You can strap items front to back, side to side, or even diagonal.(SEE PIC)
    I am also starting to incorporate the "HEX" pattern into a lot of my new products, so that's the idea behind to design.
    Last, I am making a small adaptable light (HexPod) that happens to be the exact same side hole cutout. So they can snap into the rack for even more interior lighting:D
  15. Jul 6, 2020 at 4:37 PM
    #1035
    Gen2Tacoma
    North East Atlanta
    OK I can kind of see the directional thing but where does someone obtain the hex patterned mounting pins/ hex anchor points. Again new at this. Thanks,
  16. Jul 6, 2020 at 4:45 PM
    #1036
    brentano
    2017 TRD OR AC SSM
    OK, that makes each of the six hex sides 16mm. In order to lay a strap flat in the hex opening, I require a 16mm or less width strap. Correct?
  17. Jul 6, 2020 at 4:50 PM
    #1037
    MESO
    State of Jefferson
    You would just weave the molle webbing through the Hex's. Just like you would any "molle" std holes. There is no direct mounting pins or anchor points. Although I might make something like that in the future once this product line grows to other platforms.
    This should help
    Toynado, Crom, 12TRDTacoma and 4 others like this.
  18. Jul 6, 2020 at 4:51 PM
    #1038
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
    The width of one of the sides would be closer to 18.5 mm
  19. Jul 6, 2020 at 5:00 PM
    #1039
    brentano
    2017 TRD OR AC SSM
    Apologies, I originally interpreted your 32mm as the long diagonal, not the short diagonal. 18.5mm is correct on the hex side length.
  20. Jul 6, 2020 at 7:06 PM
    #1040
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    @NoFear9491 looks like you might be able to get that AC molle rack soon.
    NoFear9491 likes this.
