Interior Overhead Molle Rack
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MESO, Oct 31, 2018.
  1. May 20, 2021 at 8:13 AM
    #1521
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    May I ask what part was terrible on the install?
  2. May 20, 2021 at 8:16 AM
    #1522
    scifidelity
    scifidelity Well-Known Member
    mainly holding the very thick (a good thing) and heavy rack up while trying to line the long bolt up with the jack nut.
  3. May 20, 2021 at 8:24 AM
    #1523
    Devious6
    Devious6 Not your Average College President Emeritus
    Mark
    Northeast Pennsyltuckyvania
    2020 Army Green TRD Pro
    Mine does not angle back at all. It would definitely be easier to get that first screw started if you had another set of hands to help...but I really didn't struggle at all getting mine in place.
    Grindstone likes this.
  4. May 20, 2021 at 8:45 AM
    #1524
    MESO
    State of Jefferson
    Gotcha. Yeah it can be a little awkward holding it above your head while trying to screw it in. I suggest having a Buddy help or if you are by yourself use a broom stick/pole to prop it up in the middle.
  5. May 20, 2021 at 8:48 AM
    #1525
    Tacospike
    Two Trucks
    I just held it with my head.
    Momma always said it would take me anywhere
  6. May 20, 2021 at 8:49 AM
    #1526
    MESO
    State of Jefferson
    It helps if you leave your helmet on too. :D:rofl:
  7. May 20, 2021 at 8:49 AM
    #1527
    crashdb
    crashdb I break chainsaws
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Rollin' hydrocarbons!
    For the sunroofers: rear attachment point is the coat hooks?
  8. May 20, 2021 at 9:02 AM
    #1528
    MESO
    State of Jefferson
    Correct. It replaces the hooks and uses those 2 holes for mounting.
  9. May 20, 2021 at 9:21 AM
    #1529
    crashdb
    Dave
    Manassas, VA
    2008 Toyota Matrix
    Thanks! Keeps me from having to buy replacement hooks that I destroyed taking out the headliner.
  10. May 20, 2021 at 9:24 AM
    #1530
    BringbackSnacks
    BringbackSnacks Mr Steal Your Habibti
    Pasadena,CA
    2017 TRD PRO
    Installed mine over a year ago. Probably my favorite mod I've done to truck. I ran some Bungie cord across just to keep everything tight. Also added some grab handles and got rid of the OEM ones.
    bulalo, Lucky Lefty and MESO[OP] like this.
  11. May 20, 2021 at 10:23 AM
    #1531
    xMaverickx
    xMaverickx Well-Known Member
    Jeremy
    New Brunswick, Canada
    2016 MGM Limited V6 4X4 DCLB
    Stew’s actually being pretty nice about this... if you’re having a hard time holding a 5lbs rack over your head maybe put it down, do some shoulder exercises and try again tomorrow :D:D
    TartanEagle and Lucky Lefty like this.
  12. May 20, 2021 at 11:08 AM
    #1532
    Tacospike
    Two Trucks
    :anonymous:
    :curls::benchpress::militarypress:
    waltuo likes this.
  13. May 20, 2021 at 11:13 AM
    #1533
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Holy schmokes that was rough. Nothing wrong with MESO’s product or design, but getting the grab handles and rack on was painful. The last set was the toughest. I ended up pinning everything in place with a screwdriver in each hole and then securing the rack and pulling a screwdriver out to replace with the screws.
    2 hours, 3 screwdrivers, 1 Allen wrench, 5 jacknuts, 1 soft mallet, 2 needle nose, 1 car wash sponge, 1 auto clothes hanger bar, 3 bungees, and about $30 in the swear jar and I’m all done.
    Sponge on the head for lifting. You don’t want to see the clown circus video. Solo work in a nighttime garage. Toyota must have used up all the tolerances in my truck as I had a bit of separation issue between the nuts on one side.
    But it’s all in now and quite stealth if you ask me.
    Thanks for another great product @MESO!!!
    indoomitable and waltuo like this.
  14. May 20, 2021 at 11:31 AM
    #1534
    waltuo
    waltuo Well-Known Member
    Toyotas
    Haha I ended up not installing with the spacers. Panel stays off the headliner except at the mounting points. Even with help, it was rough.
  15. May 20, 2021 at 3:22 PM
    #1535
    krnsole
    krnsole Member
    Honolulu, HI
    2021 Voodoo Blue TRD Sport
    TRD Exhaust Pro Grill TRD Pro Rims Tailgate Lock KDMax 6.0 Reg Premium
    Those that purchased the handle retention kit. Did you have trouble screwing the provided screws? The threads appear to be a different thread size. DB0FA990-FBB3-4372-B08D-588819B4FEEE.jpg
  16. May 20, 2021 at 3:54 PM
    #1536
    JFanaselle
    JFanaselle Well-Known Member
    Joe
    Murrieta, CA
    2020 TRD Off-Road DCSB 4x4
    My experience was very similar (also non-sunroof model). Retaining the grab handles, in hindsight, was not worth the extra effort. I should have just thrown some paracord grab handles up there instead. I actually installed the rack using the shorter screws first (it was still a pain to do alone with the spacers). Then I tried to remove each one and replace it with the longer bolt for the handles, but couldn't get it to work. I had to take the rack back down and reinstall it with the handles and longer bolts in one shot. I ended up using a long wooden dowel to force the rack upwards and bend it into shape while I fit the final screws into place. For those joking about not being strong enough to hold the rack over your head... it took more like 50 pounds of force, overhead, reaching out away from your body, with your non-dominant hand/arm, while you try to line up screws and curse at the world. It's DEFINITELY a two person job.
    indoomitable likes this.
  17. May 20, 2021 at 4:10 PM
    #1537
    RushT
    North Texas
    Yep. A challenge for sure. I even rolled over with feet up trying that.... aside from the totally uncomfortable vibe I got from being in a backseat with my legs in the air.... it didn’t work so well. :)
    I’m wondering if Meso would share his standoff cad file so I could print some shorter ones.
  18. May 20, 2021 at 4:16 PM
    #1538
    Lucky Lefty
    Lucky Lefty Tenured Patience Tester; Master deBater
    NJ
    2019 DCLB TRD SPORT
    :rofl::rofl::rofl::rofl::rofl::rofl:
  19. May 20, 2021 at 4:17 PM
    #1539
    Tnc
    Tnc Well-Known Member
    Tim
    NE Oklahoma
    2017 DCLB TRD OR
    Got my sunroof version installed today. Used the stainless hardware just to get it in. Took the extras he provided and put a couple coats of plastidip black on them. Once they dry, I’ll replace the stainless with the black.
    Devious6, Grindstone and bulalo like this.
  20. May 20, 2021 at 4:44 PM
    #1540
    RushT
    North Texas
    One good thing about retaining the handles, is that the hardware doesn’t show.
