Interior Overhead Molle Rack
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MESO, Oct 31, 2018.
  1. Jan 25, 2022 at 9:28 AM
    #1761
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    I would love one
  2. Jan 25, 2022 at 3:50 PM
    #1762
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    Yes please! This would open up a bunch of options for mounting things!
    tacoshell88 and TomTwo like this.
  3. Jan 27, 2022 at 12:27 PM
    #1763
    Scrovak
    Scrovak Ask me about TacoBomba's tonneau cover
    Maryland
    2016 White Taco TRD Offroad
    No worries, brother! You do you, we're happy for whatever you can put out and when.
    TomTwo and tacoshell88 like this.
  4. Apr 12, 2022 at 4:31 AM
    #1764
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    @MESO any idea when you will have some racks and handle retention kits in stock again?
  5. Jul 7, 2022 at 8:40 AM
    #1765
    wornandtorn
    wornandtorn Well-Known Member
    Nathan
    GA
    2020 Cement Tacoma TRD Sport 4x4
    Fellas,
    I already reached out to @MESO on this one via the support email. In the meantime, any of you have any experience with stripped jacknuts on your racks? I have the sunroof model. Installed about a year ago. No items attached to the molle/no extra weight. About a week ago I noticed a rattling and pinpointed it to the rack. When I checked, one of the screws/bolts had come loose from the jacknut. Upon further review, it is the jacknut thread that is toast.
    Any good or easy way to replace the jacknut? Not having any luck removing it so far. If not, any way to repair as is. I have a trip coming up where I’ll need the rack to carry weight and that just won’t happen as is.
  6. Jul 7, 2022 at 1:29 PM
    #1766
    JFanaselle
    JFanaselle Well-Known Member
    Joe
    Murrieta, CA
    2020 TRD Off-Road DCSB 4x4
    The jack nuts are very soft metal that can break apart and fall into peices pretty easily (probably the same reason it's stripped out).
    When I removed my rack, I simply threaded one of the bolts a few turns into the jacknut, and wiggled it around with a pair of pliers until the jacknut broke apart. It'll break the front part away from the rear part, and if you're lucky, you can use needle nose pliers to fish the back part out of the hole. On most of mine, the back part fell down inside and was unrecoverable. At first I was worried about that, but I never hear them rattling around while driving or anything.
    wornandtorn[QUOTED] likes this.
  7. Jul 9, 2022 at 9:52 AM
    #1767
    wornandtorn
    Nathan
    GA
    This is very helpful! Thank you for this. @MESO replied and said that they had never heard of a jack nut stripping on their racks. Their recommendation was to drill out the jack nut. Just as you mentioned my fear was that I would lose a bit of the nut in the roof and then I would have a whole new rattle problem. Good to new you haven’t experienced that.
    JFanaselle[QUOTED] likes this.
  8. Aug 10, 2022 at 10:54 AM
    #1768
    wornandtorn
    Nathan
    GA
    UPDATE: Spoke to Austin @MESO. He said they haven’t had another case of the jack but stripping. (I’m the lucky one :)) He offered to replace the jack nut but unfortunately they don’t currently have any in stock. The other option was to source locally but after a couple trips to NAPA, Autozone, Ace, Home Depot, and finally Lowe’s they don’t seem to stock them either.
    Here’s the question: Does anyone know a relatively inexpensive way to source one of these? (Jack nut = M6 x 1mm, 18.6mm long)
    Any help would be greatly appreciated. Had to take rack down because it was squeaking too bad without that nut in.
  9. Aug 10, 2022 at 5:57 PM
    #1769
    littlefish
    littlefish Buzz, your girlfriend...
    Hudson Valley NY
    2016 TRD Off-Road DCSB
    The one who dies with the most stuff wins.
    Without looking for you, I'd start with McMaster-Carr.
    wornandtorn[QUOTED] and TomTwo like this.
  10. Aug 10, 2022 at 7:03 PM
    #1770
    89hatcher
    89hatcher Well-Known Member
    i bought my rack used and it didn't come with the jack nuts. i just ordered some jack nuts on ebay. m6x1.0 long. not sure if its the correct size to use but took a chance.
    try looking up "swordfish zinc plated jack nut" you can choose the thread pitch m6x1.0 short or long version. i chose long because i think the short one is to short.
    if anything i can measure it when it arrives and send you a couple if needed.
  11. Aug 10, 2022 at 10:47 PM
    #1771
    GrizzledBastard
    GrizzledBastard OH NO! I've built a Faux Pro!
    Tim
    Central Coast, CA
    '21 TRD OR 4x4 DCLB Super White
    Not enough bandwidth on the internet to list.
    I used a jack nut identical to the MeSo supplied nuts for another application and even used the MeSo install tool that came with the panel. I was able to source the jacknuts at my local Ace Hardware in the library of those skinny-ass plastic bins of shit. If you get stuck, ping me, I have some here if I can locate them during my hideous move to a new house. o_O
    wornandtorn likes this.
  12. Aug 11, 2022 at 10:10 AM
    #1772
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    https://www.mcmaster.com/90186A107/
    89hatcher and musicisevil like this.
  13. Aug 11, 2022 at 1:50 PM
    #1773
    E.T.
    E.T. Well-Known Member
    Los Angeles
    2016 MGM OR TRD AC Field Truck
    89hatcher likes this.
  14. Sep 25, 2022 at 3:12 PM
    #1774
    Jamesr913
    Jamesr913 Well-Known Member
    2019 Cement Tacoma offroad
    Sorry for resurrecting this old thread but I'm curious what you guys store on yours. Looking for ideas.
  15. Sep 25, 2022 at 6:08 PM
    #1775
    Goatfrog
    Goatfrog Well-Known Member
    Bill
    Pittsburgh, PA
    2020 Red DCLB TRD Off Road
    Mostly pouches that hold first aid items, charging cables and maybe a rolled up fleece jacket and a rolled up blanket at times.
    Jamesr913[QUOTED] likes this.
  16. Sep 25, 2022 at 7:38 PM
    #1776
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    It’ll fit a skateboard?
    echoboom, E.T., Ahomeofbones and 2 others like this.
  17. Sep 26, 2022 at 6:19 AM
    #1777
    Tacospike
    Two Trucks
    First aid kit pouch
    pouch with spare glasses (night time) collapsible dog water / food bowls, dog leash
    pouch with tools, allen keys set, some open sockets 10mm and a few other sizes, screw drivers, spare fob batteries
    Pouch with spare bulbs, brake bulbs and a few others, spare fuses
    9'' K-Bar knife
    all my other junk is under and behind the rear seat. jumper cables, ratchet straps, bungee's, gloves, 4 way, poncho's, rope, towels, tools, bed cleats, bed net, ~ pretty much keep the same stuff in both trucks
  18. Sep 26, 2022 at 8:48 AM
    #1778
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    You never know when you’ll have to do some emergency shredding. EMPs are always a possibility these days.
    E.T. and musicisevil[QUOTED] like this.
  19. Feb 19, 2023 at 8:57 AM
    #1779
    IssaGreenTaco
    IssaGreenTaco Well-Known Member
    Canton GA
    21 TRD Off-Road
    Dobinsons IMS Lift SPC UCA's
    Has anyone had the issue where the jacknut is too big? I went around and they don't fit.
  20. Feb 19, 2023 at 9:11 AM
    #1780
    RushT
    North Texas
    Can you squeeze the nut a little thinner, still leaving a slight bend so it expands once tightening begins?
