Interior rattle/clicking noise on 22 OR
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Diesel170, Feb 24, 2023.
  1. Feb 24, 2023 at 1:33 PM
    Diesel170
    Diesel170 [OP] Member
    2022 Lunar Rock OR
    For the past few weeks I’ve been experiencing a rattle like noise that sounds like it’s coming from the interior. Either from around the gear select or the passenger side. It’s driving me insane that I can’t seem to find it.
    Saw a post here that it may be the weather stripping in the door and to try lubricating with silicone, tried that didn’t work.
    Tried the tweeter grill and a pillar trim, both are solid.
    Happens with the fan and radio on or off.
    Only happens while driving.
    Can’t replicate in park violently shaking the truck, the sound doesn’t occur inside or out.
    Can’t seem to track it down, any ideas are welcome.
  2. Feb 24, 2023 at 1:38 PM
    Lunar Squirrel
    Lunar Squirrel Well-Known Member
    24 TRDOR Hybrid SPF100-Octane
    Passenger seat will sometimes vibrate against the center armrest, can make a light tapping noise. Not sure if that’s your issue but adjusting the seat rake quick fix.
  3. Feb 24, 2023 at 1:43 PM
    Diesel170
    2022 Lunar Rock OR
  4. Feb 24, 2023 at 1:54 PM
    Lunar Squirrel
    I’ve had 3 of these so familiar with most of of their noises & that’s not one I’m familiar with.
    You’re still on warranty so might just want to take ride around the block with a service person & let them pull a panel & tighten whatever’s loose.
  5. Feb 24, 2023 at 3:44 PM
    Diesel170
    2022 Lunar Rock OR
    Update: took it to dealer and did a test drive, of course I couldn’t replicate the sound. Showed them videos of it and they thought it was weird and would like to keep the truck for a day to see if they can figure it out but that’s going to be hard to do since I use it for work. Fingers crossed someone comes along this thread with a solution.
  6. Feb 24, 2023 at 4:24 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Speaker grill and pillar maybe solid, but they do rub. I would still put felt or piece of rubber between them.
  7. Feb 24, 2023 at 4:27 PM
    Diesel170
    2022 Lunar Rock OR
    I can’t seem to replicate the sound no matter how I physically abuse the a-pillar or tweeter grille
  8. Feb 24, 2023 at 4:28 PM
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    Maybe it’s somatic symptom you’re having
  9. Feb 24, 2023 at 4:29 PM
    Ob1-adobe
    Ob1-adobe Well-Known Member
    2019 Tacoma TRD Off-Road DCSB Magnetic Gray
    The microphone thing above my head rattles
  10. Feb 24, 2023 at 4:37 PM
    na8rboy
    WI
    I couldn't either., but driving it was there. I put piece of foam rubber between and problem solved.
  11. Feb 24, 2023 at 4:46 PM
    Diesel170
    2022 Lunar Rock OR
    Actually this thread doesn’t even exist, it’s all a false reality you’ve created in your own mind. Wake up ryanvar42, escape the matrix.
  12. Feb 24, 2023 at 4:49 PM
    Diesel170
    2022 Lunar Rock OR
    If I had a gun to my head and had to bet my life on where the sound was coming from I would say it was the center console and not the right side of the dash, but I’m not 100% confident in that answer. I guess I’ll start pulling the dash and putting felt up there to see if anything changes.
  13. Feb 24, 2023 at 5:09 PM
    na8rboy
    WI
    Give it a shot, nothing to lose but a minute of your life. No need to pull anything. Just put foam rubber or felt between speaker grill and A-pillar.
  14. Feb 24, 2023 at 6:53 PM
    Tallgrass05
    Tallgrass05 Well-Known Member
    My 2022 with 10,200 miles on it just started making a similar rattle. If I press on the front passenger seat or the headrest, it stops. I need to pull the headrest out and see if that is the source of the little rattle.
  15. Feb 24, 2023 at 6:55 PM
    Diesel170
    2022 Lunar Rock OR
    I’ve noticed the seat vibrates pretty violently especially when you look at the headrest while driving, I’ll give that a shot as well. You’d think a 50k off-roading truck would be a bit more stable in the interior
  16. Feb 24, 2023 at 7:12 PM
    SerialKiller
    SerialKiller Well-Known Member
    2019 Cement Tacoma OR
    It’s probably inside the passenger side A-pillar. Someone I know had the same noise and it was like a loose piece of tape or wire something like that. They just put new tape in there and it fixed it. It’s been a long day sorry I can’t remember the specifics.
  17. Feb 24, 2023 at 7:14 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Are there any coins in your cup holders?
  18. Feb 24, 2023 at 7:19 PM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    The overhead trim piece (around the crawl control) rattled on my truck, put a tiny piece of a business card up there and solved it.
    :notsure:
  19. Feb 25, 2023 at 2:27 AM
    22Coma6MT
    22Coma6MT Well-Known Member
    2022 TRD Sport AC 6MT
    mine is one of the worst assembled vehicles i've owned and my biggest complaint with this truck. i hate driving on a gravel road, it feels like parts are falling off.
    is this a double or access cab? i had (still have somewhat) squeaks, rattles, and a ticking noise inside my doors for the access cab. it was ufb. the plastic panels were rubbing and tapping on metal supports. i removed the door panels and put gorilla tape over the metal supports, and while i had the panels off covered other things that looked suspicious as well as installed sound deadener. it helped a lot.
    as others mentioned above, the passenger seat vibrating was causing other noises. i get squeaks and rattles from the head unit bezel, especially when it's cold outside. i have to press on it every now and then to make it stop.
    sinewave likes this.
  20. Feb 25, 2023 at 3:27 AM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    I think it could be the seat.Like the OP suggested which is why they couldn’t duplicate the problem on a test drive.
