Interior trim pieces
Discussion in 'Audio & Video' started by Flkracker, Jun 16, 2020.
  1. Jun 16, 2020 at 4:35 PM
    Flkracker
    Flkracker [OP] Well-Known Member
    I know it's here but can't find it and can't remember the technical name. I need to remove the grey plastic door sill and the kick plate on the driver's side. I think these are the correct terms. I'm running some wires for an under seat sub. Do these pieces just pop off ? Any help is appreciated. Thanks
  2. Jun 16, 2020 at 4:42 PM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Yes, pop the door sill off
    Then pull off the dead pedal piece of plastic in the left of the drivers floorboard, and there is a plastic screw-on piece holding a tab of the kick panel. Unscrew that and then the kick panel pops off
  3. Jun 16, 2020 at 4:45 PM
    Flkracker
    Should of just PM you lol thank you. You are the audio expert. Forgot about the dead pedal. It just pulls off.
  4. Jun 16, 2020 at 7:37 PM
    pinktaco808
    pinktaco808 Hot Steppa
  5. Jun 17, 2020 at 12:49 AM
    Flkracker
    Not sure what this means
