intermitten hesitation
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Alfie, Feb 18, 2012.
  1. Feb 18, 2012 at 2:01 PM
    Alfie
    Alfie [OP] New Member
    Saskatchewan
    SR5 Debadged
    Command start,3 inch lift,brush guard,tonnea cover,285/55/16 tires ,after market wheels,GF performance chip
    2005 4.0Litre V6 manuel trans--I took the cats out three years ago and six months ago i started having a hesitation occasionally. I put a code reader on and clear the codes caused by the lack of cat. converters and the hesitation goes away until the check engine light comes on again.Usually within 100 miles. Plugs and filters are new-and all of the error codes point to the errors you would expect from no cat.converters.Any help would be great!
  2. Feb 18, 2012 at 2:06 PM
    Fractured
    Fractured FPS-a-holic
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    TRD wheels, TRD cat back exhaust, ScanGauge 2, Debadged, Avid sliders, UWS bed box w/automatic LED light, Led Interior/Reverse/Lic. Plate lights, Yellow Fogs, Flyzeye Light, Color matched grill, Rearview mirror relocate bracket, Power Sliding rear window, Plasti-dipped bumper/"T" emblem
    Remember, the truck is designed to have cats. The intake is designed to be able to flow the correct amount with proper backpressure from the cats.
    With that said, if the hesitation occurs when the CEL comes on, its probably due to limp mode. The ecu thinks the cats are being damaged so it cuts power.
    Why it didnt happen sooner, i cant say.
  3. Feb 18, 2012 at 2:25 PM
    Alfie
    Saskatchewan
    SR5 Debadged
    Thanks--i was told i could put something in to fool the computer into thinking i still have the cats and that would eliminate the check engine light and i assume the hesitation as well. any knowledge in this area??
  4. Feb 18, 2012 at 2:31 PM
    Fractured
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    Yea usually its a small resistor.
    Goggle "cel fix" you should be able to find something.
  5. Feb 18, 2012 at 3:14 PM
    Alfie
    Saskatchewan
    SR5 Debadged
    will do thanks any major down side that you know of?
  6. Feb 18, 2012 at 3:23 PM
    Fractured
    Corey
    NOR*Cal
    2012 MGM DCSB 4x4
    To installing the cel fix? No.
    I ran one on my wrx for 3 years with no issue.
    The truck should be tricked into running normal.
  7. Feb 19, 2012 at 10:38 AM
    cjthedj
    cjthedj Member
    Chadd
    WV
    06 extended cab
    Good info. Thanks for posting
