Intermittent A/C Problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by NOLA3090, Jul 22, 2020.
  1. Sep 27, 2020 at 12:35 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I’d find out it there’s a blend door that’s supposed to open when the AC is turned on and note if that problem happens when the AC turns on with the defrost settings as well.
  2. Sep 27, 2020 at 3:45 PM
    Dumpy
    Dumpy Active Member
    California
    01 black dbl 4x4 TRD limited
    Black Snugtop
    I had my dash all apart for days with the wiring diagram trying to narrow mine down. My blower stays on. Everything staying on except the compressor. Hot/cold control valve staying 'cold'.
    You're newer '10 vs 01 and may have more control, but mine has a high pressure /low pressure switch and evap temperature sensor with terminal plugs hidden behind the glove box that input the AC controller that is part of the switch assy which also has a modular plug any of which can cause intermittent problems.
    I tested the pressure switch and the temperature sensor.
    I bypassed the pressure switch and installed a resistor in place of the sensor and cleaned the modular plugs. .No luck.
    Pulled the controller to clean the modular plug and check voltages at the pins...Problem cleared!
    Put glove box together but driving around with dash center apart for awhile, 2 days working fine. Looking like a bad connection at the control module.
  3. Sep 27, 2020 at 7:58 PM
    Dumpy
    Dumpy Active Member
    California
    Black Snugtop
    If you haven't already I'd document high side and low side pressure when you can get it running. Confirm normal ranges.
    Then check the electrical connection at the compressor and wire in a 12v light to that compressor wire so you can determine when it's energized from the cab.
    Then trouble shoot from there.
  4. Sep 27, 2020 at 8:19 PM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    I had a problem with mine, and it was the A/C switch in the dash. It would go out intermittently, I finally got a used from Speedway Salvage (like a Pick n Pull) from a RAV 4, and it fixed it! Also, it only cost $2.
    Dumpy likes this.
  5. Sep 28, 2020 at 7:01 AM
    TacoTime10
    TacoTime10 Well-Known Member
    New Hampshire
    2010 ACLB 4x4 SR5 2.7L 5MT
    2021 TRD OR wheels and tires, bed stiffeners, fog lights
    I had disconnected the battery about a week ago to install fog lights and hadn’t tried using the AC until about a week after. I read on other threads that the AC resets itself for awhile after disconnecting the battery, and i’m hoping this was the case. It seemed to start working again on it’s own after restarting the car and letting it run for awhile. Hopefully that’s all it was!
    Dumpy likes this.
