Intermittent ABS Light & Fuse Location
Discussion in '1st Gen. Tacomas (1995-2004)' started by Broham, Feb 19, 2018.
  1. Feb 19, 2018 at 9:39 AM
    Broham
    Broham [OP] Member
    '99 Toyota Tacoma V6 4x4 TRD
    Hey guys. I recently bought my '99 Taco and I've been working out some kinks with it. The most recent one being an intermittent ABS light that seems to be temperature inclined.
    Thanks to this thread: I narrowed it down to the ABS sensor with the orange clip being wonky. When i would mess with it, the light would go off regardless of temperature. I finally got it way more snug and greased it up, but when I was cleaning it with electrical cleaner, it sparked a tiny bit...even though the truck was completely off and without keys. Now the light is tripped full time and I'm trying to figure out if I blew a fuse or destroyed the sensor altogether.
    Is this sensor the ABS fuse under the hood? It doesn't look tripped, but I haven't had much luck getting it out. Is there another fuse I should check?
    The truck is in really good condition, but I'm about to say f it on this ABS system and just pull the bulb from the dash.
  2. Feb 19, 2018 at 8:30 PM
    Glamisman
    Glamisman Well-Known Member
    yes the fuse, 60 amp if I remember, is in the engine compartment fuse box marked ABS. Dealer only item as far as I know.
