Intermittent AC light flashing does not occur with my hood open
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MarkNap128, Jul 10, 2022.
  1. Jul 10, 2022 at 3:09 PM
    MarkNap128
    MarkNap128 [OP] Well-Known Member
    Mark
    West Warwick RI
    2013 Black Tacoma TRD Sport 4x4 dbl cab
    None
    Hey guys
    I’ve for a while known of the issues that can cause this problem (bad relay which I’ve swapped more than once) and the pickup sensor on the compressor going bad BUT I’ve recently noticed if my truck is running but the hoods opened it will not start flashing.
    Any ideas? Could the issue be related to high temperatures in the engine bay?
    Thanks
    MARK
  2. Jul 10, 2022 at 4:05 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Have a look at the compressor clutch. Does it appear to have rubber bubbled up....
  3. Jul 10, 2022 at 6:02 PM
    daluvian
    daluvian Well-Known Member
    San Diego
    2005 Tacoma
    Long travel
    Do you have anything aftermarket installed like a alarm ?
  4. Jul 11, 2022 at 12:46 AM
    MarkNap128
    Mark
    West Warwick RI
    None
    No I do not. This problems been intermittent for a few Years now I will def look for bubbles on the sensor I mean I obviously need to swap it out but I just thought how weird it was staying on wirh the hood opened
  5. Jul 11, 2022 at 5:55 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Look at the compressor clutch coil to see if the rubber has been overheated and bubbled. You may just need a new AC Clutch Assembly.
  6. Jul 11, 2022 at 11:16 AM
    bmcclain90
    bmcclain90 Well-Known Member
    I 2nd the AC clutch probably it
  7. Aug 7, 2022 at 9:59 AM
    MarkNap128
    Mark
    West Warwick RI
    None
    I think since I’m having other problems with my A/C i should throw in a new compressor since I’m already replacing the expansion valve as
    Well as the discharge hose
