Intermittent beep
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Roscoe Taco, Oct 4, 2020.
  1. Oct 4, 2020 at 7:59 PM
    Roscoe Taco
    Roscoe Taco [OP] Sort of old guy
    Ron
    Southern NM
    2017 Tacoma TRD OR 4x4
    Here’s a dilemma that just surfaced this evening. My Taco is sending out a beep, once every minute or two. This beep is lower in volume than the one produced when locking the truck. After locking the truck, the alarm sets as normal but a minute or so later, this beep starts. I’ve tried starting the truck then shutting down and locking again, hoping everything would reset, but the beep is still there.
    Has anyone else experienced this? We’re you able to solve this mystery beep?
  2. Oct 4, 2020 at 8:23 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Just taking a shot in the dark, but do you have your sunroof or a window open/cracked open by chance?
    RedWings44 likes this.
  3. Oct 4, 2020 at 8:38 PM
    tcjacado
    tcjacado Well-Known Member
    Are you parked in the garage and the smoke/carbon monoxide alarm chirping???
    That was the answer to the last one of these.
    davidstacoma, Skydvrr, Chew and 2 others like this.
  4. Oct 4, 2020 at 8:48 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Aftermarket Alarm System?
  5. Oct 5, 2020 at 7:05 AM
    Roscoe Taco
    Ron
    Southern NM
    No, no and no.
    Sunroof not open (I recognize the sound for this as I have often left the sunroof in the pop up position and had the chirp sound. This one is different)
    not parked in garage.
    Factory alarm system.
    Any more ideas?
  6. Oct 5, 2020 at 7:29 AM
    Freetime
    Freetime Well-Known Member
    2016 TRD OR AC 4x4 Quicksand
    Something in the truck on battery that isn't getting juice so it's complaining? Such as a battery backup or something?
  7. Oct 5, 2020 at 9:01 AM
    piff
    piff Well-Known Member
    Minnesota
    2019 Quicksand Tacoma TRD OR DCLB AT
    Bone stock baby
    This would be my best guess...
    Another thing to check is if the security indicator upload_2020-10-5_11-0-35.jpg appears in the little section under the head-unit upload_2020-10-5_11-1-14.jpgafter you lock the vehicle.
    davidstacoma likes this.
  8. Oct 5, 2020 at 10:18 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Are you saying it beeps randomly after arming it when u walk away from the truck ? If you have a alarm then it’s normal my old ranger used to do that it would drive my neighbors nuts lol .
  9. Oct 5, 2020 at 10:26 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Truck is telling you that it's lonely. You need to drive it more.
    shakerhood and Skydvrr like this.
  10. Oct 5, 2020 at 1:23 PM
    Roscoe Taco
    Ron
    Southern NM
    That must be it. Damn Covid.
    actually, I did drive the truck today for several errands. After parking at home, I was outside near the truck for quite a bit and didn’t hear the beep again.
    however, another strange thing did happen today. As I drove away from home, I noticed the BSM switch was turned off. When I turned it on, a warning came up in the info panel stating BSM not available. After several attempts I gave up. After one of my errand stops, I turned it out and all was well.
    now I’ve owned classic British cars for close to 40 years and Lucas wiring is known to have “Gremlins “ living within but this is my first (and today second) experience within Toyota Gremlins. I hope they have a short life span.
    By the way, I do not have anything electrical connected to my truck that did not come as stock except for my brake controller, which I unplug when not towing.
  11. Oct 5, 2020 at 4:25 PM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    Don't be giving away secrets.
  12. Oct 6, 2020 at 10:25 AM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Damn this thread. Last night I was puttering around the garage. Intermittent beep. It sounded exactly like a smoke alarm low battery chirp, but as far as I know there isnt one in the garage. :annoyed: I was jacking with the running lights and tails on my camper (converting it all to LED) I'm hoping that the chirping was coming from it and not the truck...
  13. May 29, 2021 at 2:18 PM
    Toyotatron
    Toyotatron Well-Known Member
    Megatron
    2019 Tacoma TRD Offroad Quick Sand
    My 2019 When I swapp sd cards, my Toyota Factory Dashcam makes beeping noises every minute or so... sometimes I don't get the beeps, I just switched it out tonight, now its beeping again, I have to play loud hardcore Metal to make sure I can't here it.
    I have searched for the open source DIY fix etc... nothing yet and Im about to do the rapid planned disassembly of the factory Douche Cam and install a proper DVR.
  14. May 29, 2021 at 7:18 PM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Man this is a blast from the past. I don't even remember what I was complaining about. :anonymous:
    shakerhood and b_r_o like this.
  15. Oct 17, 2021 at 6:23 AM
    2017taco_go_packers
    2017taco_go_packers New Member
    Sky
    2017 TRD sport 4x4 4dsb
    1.25 wheel spacers
    Has anyone figured out how to fix the beep?
  16. Oct 17, 2021 at 6:44 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Fob battery low.
  17. Oct 17, 2021 at 7:25 AM
    2017taco_go_packers
    Sky
    1.25 wheel spacers
    I thought that too but I changed the key fob battery and it's still beeping
