intermittent charge light
Discussion in '1st Gen. Tacomas (1995-2004)' started by 5000fingers, Aug 28, 2016.
  1. Aug 28, 2016 at 2:44 PM
    5000fingers
    5000fingers [OP] Well-Known Member
    Bruce
    Bay Area, CA
    '95 Tacoma, 6 cyl.
    My charge light has start going on intermittently (I've got about 190K on my '95). It tends to go off when idling. I tried the easy fix of cleaning up the battery terminals, but I guess I'm not that lucky today. What is the diagnostic sequence for this? Are there any good pics or videos about how to diagnose my alternator?
  2. Aug 28, 2016 at 3:00 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Measure the voltage across the battery terminals.
    If the alternator is working properly, it should be around 14 volts (motor running).
    A good battery (with motor NOT running) will measure about 12.5 volts.
  3. Aug 28, 2016 at 4:07 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    You might want to check the belt tension
    If you have a intermittent problem
    When did you last change the belts ??
  4. Aug 28, 2016 at 4:15 PM
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    also check the for bad connections on the alternator.
  5. Aug 29, 2016 at 8:23 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    get your battery load tested as well
