Intermittent clicking/rattling in engine bay
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Avsfreak24, May 28, 2019.
  1. May 28, 2019 at 10:00 AM
    Avsfreak24
    Avsfreak24 [OP] Member
    San Tan Valley, AZ
    08 TRD Off-Road
    ICON 2.5" extended travel coil-overs with SPC Light Racing UCA's up front, replacement leaf spring lift with Bilstein 5100's in back, Rear E-locker with VIair onboard compressor and ARB front locker, Full Relentless Fab skid plate, welded on rock sliders, baja roof rack, bed rack, bull bar with 20" white/amber light bar, round pods on ditch brackets, and yellow pods on roof rack, 40" light bar on roof rack
    So, I know it could be a valve but it isn't a constant steady noise. Sometimes it stops completely and I'm thinking it is actually a pulley, whether it is idler or A/C clutch, or power steering pulley. I suppose it could even be the balancer pulley and I'll have to remove the belt and check all the pulleys to see if one is loose or wobbly or turning hard. Have any of you experienced that noise from a pulley instead of a whine when the bearing goes out in a pulley. This just started up out of the blue and I haven't had check engine or any issues with overheating. I don't see the fan interfered with and the fan shroud hasn't shifted. I also don't see any fraying or weird wear on the belt but I'll get a better look when I pull it. Is there a trick to isolating the noise? It really doesn't sound like a valve as it is way too loud and it sounds like it is in the front coming from the cooling fan/serpentine belt and pulley system.
  2. May 28, 2019 at 10:01 AM
    Avsfreak24
    San Tan Valley, AZ
    08 TRD Off-Road
    there are no cooling issues so I don't think it is the fan clutch. However, when the engine is off the fan does turn manually. Is that normal?
  3. May 28, 2019 at 10:03 AM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Checked to see if any exhaust heat shields are rattling?
    Avsfreak24[OP] likes this.
  4. May 28, 2019 at 10:22 AM
    Avsfreak24
    San Tan Valley, AZ
    08 TRD Off-Road
    Thanks Skrain! I didn't even think about that. Now that you mention it, the exhaust has had a vibration when I accelerate hard. I will take a look at those and check them. . .after the truck has been sitting, of course
  5. May 28, 2019 at 10:23 AM
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    can remove the belt and start it.
  6. May 28, 2019 at 10:26 AM
    Avsfreak24
    San Tan Valley, AZ
    08 TRD Off-Road
    Remove the belt and start the truck? Why would I do that?
  7. May 28, 2019 at 10:32 AM
    Avsfreak24
    San Tan Valley, AZ
    08 TRD Off-Road
    To isolate the idler/accessory pulleys from the balancer? I do work on my own vehicles and have done engine swaps on older vehicles but I'm not a professional mechanic. my gut says firing up the truck with the belt off isn't a good idea. Are you saying fire it up for a moment to isolate the noise?
  8. May 28, 2019 at 10:33 AM
    Avsfreak24
    San Tan Valley, AZ
    08 TRD Off-Road
    I suppose the only necessary thing not running would be the water pump but if the engine is cold and it's only on for a second it shouldn't harm anything
  9. May 28, 2019 at 10:59 AM
    wheeliest
    Json
    TMPE AZ
    Correct. Water isn't circulated till the Thermostat reaches 180+ f anyways.. so you can run it for a minute or two (as long as your battery is healthy)
  10. May 28, 2019 at 11:15 AM
    Avsfreak24
    San Tan Valley, AZ
    08 TRD Off-Road
    Thanks, wheeliest. . .Yeah, my battery is charged. I'll try that tonight and just make sure all the electrical accessories are turned off. . but only a minute or so won't kill it anyways
  11. May 28, 2019 at 12:15 PM
    Beerline123
    Beerline123 Well-Known Member
    07 Tacoma access 4x4
    check air inlet hose that supplies air to filter. The hose is on passenger side fender. The insulation wears where the hose enters the fender and rattles.
    Avsfreak24[OP] and wheeliest like this.
  12. May 28, 2019 at 2:26 PM
    Avsfreak24
    San Tan Valley, AZ
    08 TRD Off-Road
    Beerline123, thank you for the advice. I have an AFE aftermarket cold air intake so I don't think that is the issue, but I will check there as well
  13. May 28, 2019 at 2:39 PM
    DayTripper85
    DayTripper85 Well-Known Member
    2005 Tacoma DCSB Off Road
    My exhaust manifold shield was held on by one weld, it rattled like the Dickens. I pulled it off, and will re weld it in the future. Good luck to you
    I had a rattle when I first bought my truck that sounded like a knock on start up or when pulling. Turns out that my cold air intake was hitting the heat shield that it passes through. I centered the piping and have had no more word noises.
    Squeeks, and very light rattles can point to idlers and are super easy to replace. To check put a 14mm wrench on your tensioner, and pull the bell off the power steering pump. Then spin each idler to find the bad ones. Buy OEM Toyota replacements.
    Good luck
    deanosaurus and Avsfreak24[OP] like this.
