Intermittent clunk/pop
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gfenza89, Jan 7, 2023.
  1. Jan 7, 2023 at 9:51 AM
    Gfenza89
    Gfenza89 [OP] Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    Hey guys I have a 2022 tacoma sr5 4x4 v6. It has 3500 miles on it. I’ve been noticing I have a strange pop/clunk when rolling in traffic or accelerating from a stop sign. It only does it occasionally and randomly but at least once every time I drive the truck. Sometimes it feels like someone kicked the underside of the floorboard feel it right on my feet and other times I feel it further up in the front of the truck. Seems to only happen acceleration/deceleration . It’s a feeling if something is loose but I checked everything it seems fine. I’m at a loss . The dealership is going to be performing the tsb for my driveline vibration under deceleration which involves replacing both rear leaf springs and checking driveline angle and installing a steering wheel damper. They are thinking this ckunk and pop are related to the tsb vibration but I have my doubts. Any input would be appreciated!
  2. Jan 7, 2023 at 9:56 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    mine does it every time accelerating from a stop. i think it's either the brake pads rattling around or the slip yoke clunking into place. I wanted to grease the slip yoke but there are no zerks and I'm hesitant to drop the whole propeller shaft since I've never done it before.
  3. Jan 7, 2023 at 9:58 AM
    Gfenza89
    Yeah I’m kinda thinking that too. Just don’t know why it feels like it’s only on the drivers side under my feet or coming from the front of the truck . The driveshaft is in the center in the rear
  4. Jan 7, 2023 at 11:46 AM
    Color_Me_Taco
    Color_Me_Taco Well-Known Member
    Doug
    Utah
    2022 TRD OffRoad, 2019 TRD OffRoad, 2021 Subaru STI, 2021 Kawasaki ZX6R
    ADD, Rigid, ToyTech, DBcustomz, Methods, Nittos, Powertank, Morimoto
    Make sure nothing is rolling around under your seats, in the bed, hidden away in a storage compartment, etc
    Gfenza89[OP] likes this.
  5. Jan 7, 2023 at 12:18 PM
    Gfenza89
    Don’t see anything under my seat. I don’t know so strange and it also seems to happen within the first few miles of driving then goes away
  6. Jan 7, 2023 at 12:23 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    You say you have checked everything, but have you checked your U-Bolts? There was an issue with them being loose a few years ago.
    https://www.tacomaworld.com/threads/check-your-u-bolts.544596/
    Gfenza89[QUOTED][OP] likes this.
  7. Jan 7, 2023 at 12:56 PM
    Gfenza89
    No I didn’t check the ubolts because I’m getting the feeling from under the floor board and front end. I didn’t think that anything in the rear would travel up that far to the front but I’ll deff check
  8. Jan 7, 2023 at 2:58 PM
    turbosnail
    turbosnail Well-Known Member
    Pa
    18 dbl cab sr5 v6 4x4 , 1985 turbo sr5 pick up
    If it only happens the first few feet of driving , especially after backing out of the garage or driveway then clunks on your first stop going forward , it may be your ABS self check , mine does it every time . Just a thought …there’s a thread somewhere on here about it
  9. Jan 7, 2023 at 3:25 PM
    Gfenza89
    I know exactly what your talking about it feels just like that abs self check but happens to frequently to be that
    turbosnail likes this.
  10. Jan 8, 2023 at 4:25 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Have you checked your brake pads. I had similar issue. I pulled brake pads. Cleaned back of pads, shims and pins up. Applied fresh coat of brake grease to them. Issue resolved.
  11. Jan 8, 2023 at 5:26 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I'll get a clunk, or feel a pop from a start if a accelerate over a pothole with my sr5 like i ran over something, otherwise nothing. I just chalked it up to being normal like other toyota pickups i've had.
  12. Jan 8, 2023 at 7:43 AM
    Gfenza89
    What do you mean like the pop feels like you ran over a lot hole ?
  13. Jan 8, 2023 at 7:45 AM
    Gfenza89
    In regards to the brake pads I just can’t imagine that. Truck has less then 4k miles lol but guess anything’s possible
  14. Jan 8, 2023 at 7:51 AM
    zoo truck
    None
    Pot hole...its more like a thud when starting over a bunch of loose stones with too much right foot.
  15. Jan 8, 2023 at 7:53 AM
    na8rboy
    WI
    Mine had 10,000 miles on it. All depends on road/offroad conditions. The factory grease was all gummed up with dirt/debris.
  16. Jan 8, 2023 at 7:58 AM
    na8rboy
    WI
    Someone has a video on here. Their truck was doing same thing.
  17. Jan 8, 2023 at 8:09 AM
    o0_henry
    o0_henry Well-Known Member
    South Texas
    2018 Tacoma TRD-offroad
    Check the sway bar bushings. Had a similar noise until I took the sway bar off and it went away. Had replaced them with I did the ball joints and everything else with the lift. They don’t make MOOG like they used to
  18. Jan 8, 2023 at 8:36 AM
    Ilove2dubb
    Ilove2dubb Well-Known Member
    Jeffrey
    Montreal, Quebec
    2020 Tacoma TRD Sport in Cement
    Had the same issue as you for the 10k that I owned my Tacoma before it was stolen. Dealer could never find the issue, even though they could hear the sound. I removed the front sway bar and the sound was still there. Changed the front shocks for aftermarket and it remained unchanged. I’d be curious to see if you ever find it because it drove me crazy. If it’s just another “normal” sound that the tacoma has, I will be sure to sell my replacement that should be here in the next month. Creaks and knocks drive me nuts.
  19. Jan 8, 2023 at 11:09 AM
    Gfenza89
    I think it’s somewhat normal I’m thinking it really has to do with the driveline angles
  20. Jan 8, 2023 at 11:35 AM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    or maybe your transmission needs to warm up a little bit.
