Intermittent E-Locker issue
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mike330R, Nov 3, 2015.
  1. Feb 6, 2016 at 2:54 PM
    #101
    db1984
    db1984 Well-Known Member
    Derek
    Bend, OR
    2023 Tacoma DCLB Off-Road Premium 4X4 w/ Adv. Tech.
    Full front and rocker PPF, ceramic coating, driver/passenger window tint (20%)
    I was playing with my 4LO and locker this afternoon. It's really temperamental with locking or not. A few different times that I was in 4LO and neutral and pushed the locker button, it would just blink and never engage. A couple of times it engaged on the first shot. It definitely seems inconsistent like most everyone's experience so far.
  2. Feb 6, 2016 at 4:13 PM
    #102
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    It is an electromagneticly engaged locker it is not going to lock until the spines line up. This is going to require the rear wheels to be moving at different rates or just getting lucky and having it line up. It will engage better the more you use it as the parts wear in to each other. The tolerances are tight and will get better with use.
    db1984 likes this.
  3. Feb 6, 2016 at 4:18 PM
    #103
    RedBeard1
    Red
    If your locker is hesitating to engage just hit the throttle a little and get the tires to break loose some and it will line up and engage. If not try it again.
  4. Feb 7, 2016 at 3:12 AM
    #104
    Simms65
    Simms65 Well-Known Member
    David
    WV
    '16 Quicksand O/R M/T
    When I tried that with mine with a tech in the truck, we still couldn't get it to lock consistently.
  5. Feb 7, 2016 at 8:52 AM
    #105
    Mike330R
    Mike330R [OP] Well-Known Member
    Far West Phoenix
    '16 DC Offroad w/ stuff
    I added to the OP:
    Dealer replaced Differential Position Switch. Also states one rear wheel must slip for it to engage. However I have found that it does sometimes engage without any wheel movement.
    db1984 and WCoyne like this.
