intermittent hard starting
Discussion in 'New Members' started by ECARV, Apr 12, 2014.
  1. Apr 12, 2014 at 7:33 AM
    ECARV
    ECARV [OP] New Member
    Al
    campo calif
    95 Tacoma
    3" lift 32+1150 +15 tires Detroit lockers front and rear ARB bumper and warn 8000 winch ham radio
    My 95 Tacoma 2.7 has an intermittent hard start problem but will always start after cranking for bit. Anyone have a similar problem?
  2. Apr 12, 2014 at 7:36 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW! Check the distributer for moisture, check for vacuum leaks, and check the spark plugs. After that, if the issue still happens, check the ignition wires, EGR valve, and fuel filter.
  3. Apr 12, 2014 at 7:40 AM
    BamaToy1997
    Bill
    Navarre, FL
    I would also consider trying to narrow down the intermittent part. Many times there is actually a pattern, you just don't recognize it. Does it happen after it has sat, or after it has warmed up? Does it happen when it is humid, or dry outside? Does it happen after a "hot soak"? (When you have driven for a while and then it sits for less than 20 minutes) I recommend to most customers who have a intermittent problem that occurs on a reasonably often basis to take a notebook and when it happens, take notes about the current driving condition. Many times this will help.
    When you say it will start after cranking for a bit, do you mean you try and try and try, and eventually it fires right up, or do you mean that you keep cranking for say 30 seconds and it finally starts?
    Have you checked for codes? (not every code will turn on the CEL)
