Intermittent Howling Sound
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SilverBulletII, Jul 12, 2018.
  1. Jul 12, 2018 at 11:37 AM
    SilverBulletII
    SilverBulletII [OP] Well-Known Member
    New England
    2017 Silver Tacoma SR, MT, 4 cylinders, 4X4
    I have a 2017 SR, Access Cab. I sometimes hear a howling sound when I back off the throttle with the engine turning 2000 to 2500 rpm. It is more likely to do it (or perhaps I am more likely to hear it) when the road is wet. It is not a terribly loud sound, although it can be clearly heard.
    I have read the various threads on howling sounds and the sound I am observing does not seem to be the same as the sound/conditions described by others. Any thoughts/suggestions ?
  2. Jul 12, 2018 at 1:50 PM
    NickleCityTaco
    NickleCityTaco Well-Known Member
    Western New York
    16 Acess SP 6MT
    stuff and things
    Sounds like what I have going on. I'll see if I notice it more in the rain now. I was thinking it had something to do with cross wind... now I'm not sure.
  3. Jul 12, 2018 at 1:56 PM
    Fett85
    Fett85 Well-Known Member
    Ohio
    2021 Tacoma TRD Off Road 4x4
    I made a similar thread that I think died.....anyways. Mine happens on acceleration. Have you done the howling differential TSB? Reason I ask is a member there thinks the howling sound shows up in a different spot now that the springs and other stuff was changed out. I guess like the harmonics changed.
  4. Jul 12, 2018 at 1:59 PM
    FuzzysTacos
    FuzzysTacos Well-Known Member
    Corey
    Wichita, KS
    Sold: 2017 TRD OR/2012 TRD Sport
    It might just be wind in the door channel. A couple members have added their own weatherstripping to the channel. Could be coincidental about your other hunches.
    Where's it coming from?
  5. Jul 12, 2018 at 2:14 PM
    Ellswj86
    Ellswj86 Well-Known Member
    Jarrad
    2017 TRD DCSB
    I have the exact same issue. I've noticed right at 58mph when I let off of the gas. I thought it was the rear end so I took it to the dealership an they found no problems.
  6. Jul 12, 2018 at 2:15 PM
    SilverBulletII
    New England
    It's coming from under the truck. Can't tell location beyond that.
  7. Jul 12, 2018 at 2:21 PM
    SilverBulletII
    New England
    ...and it doesn't always do it.
  8. Jul 12, 2018 at 2:48 PM
    Tacos in Gensokyo
    Tacos in Gensokyo Bohemian Archive in Japanese Red
    2017 SR 4cyl MT SSM
    Rokblokz Mudflaps, 2015 TRD Pro Suspension
    Same issue, but it happens so infrequently that I've yet to determine any rhyme or reason. Never stays for long either, so I havn't felt any reason to explore further.
    TeecoTaco likes this.
  9. Jul 12, 2018 at 4:52 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    It's cuz yooooooo haven't got a Ti knob...gosee!
  10. Jul 12, 2018 at 5:39 PM
    SilverBulletII
    New England
  11. Jul 12, 2018 at 5:45 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Plus 1
  12. Jul 12, 2018 at 5:45 PM
    trazerr
    trazerr Well-Known Member
    Oregon
    2024 Tundra Plat 4x4 LB (prev 2018 DCLB SR5 4x4 and 1996 AC LX 4x4 5sp)
    58mph has been the sweet spot for many members with the rear diff howl. Letting off the gas is when it does it the loudest for most. Did you mention the howl TSB to them? The TSB applies to your model. Then again correlation doesn’t imply causation or something like that ha
  13. Jul 13, 2018 at 5:04 AM
    SilverBulletII
    New England
    Is the howling addressed by the TSB a mechanical problem or simply an harmonics annoyance ?
  14. Jul 13, 2018 at 5:16 AM
    TacoJetMech
    TacoJetMech Noob Taco owner
    Doug
    Las Vegas, NV & England
    2018 MGM TRDOR DCSB
    Just getting started...
    I have just over 900mi on my new 2018 TRDOR DCSB, and I hear the howl pretty regularly. From what I've been able to tell, I believe it's coming from the blade in the throttle body. It seems to be manufactured in just a way that, within a certain speed/throttle position/rpm envelope, the air happens to pass through the throttle body/blade /just/ right to create the sound. Almost like blowing across a blade of grass between your thumbs to make it whistle.
    I dunno... just my two pennies, but it's certainly not coming from underneath mine, and is pretty clearly coming from the engine bay. To me anyway it seems to be the only mechanically explainable thing to cause it. I'm certainly not sweating it or anything. Just kinda interesting I suppose. Never had a car do that before, haha.
  15. Jul 13, 2018 at 5:26 AM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Mine definitely changed. Instead of the 50mph-ish howl it now does it under acceleration... especially if I’m loaded down with passengers and / or gear. I’m dealing with it but when I’m loaded down I think I prefer how it use to be :)
  16. Jul 13, 2018 at 5:32 AM
    SilverBulletII
    New England
    I have not heard any howl when accelerating. Only've heard it when backing off the accelerator.
    Where do I find the TSB addressing this ?
    Thanks
  17. Jul 13, 2018 at 6:38 AM
    trazerr
    Oregon
    Toyota was replacing diffs at first, but then realized it was just harmonics. The TSB adds a few things, but the harmonic dampers are what help the most. They just attach to rear cab mount.
  18. Jul 13, 2018 at 6:40 AM
    trazerr
    Oregon
  19. Jul 13, 2018 at 6:50 AM
    SilverBulletII
    New England
  20. Jul 13, 2018 at 7:12 PM
    SilverBulletII
    New England
    Brought the truck up to 58 mph and feathered the accelerator and she howled. Tried it again and no howl.
    Even when the howl occurs it is not very loud. I think I can possibility live with it as long as: 1). it doesn't get louder, over time; 2). it is not a mechanical problem, just harmonics.
    I am wondering how loud this howling has been for others.
