Intermittent IG1 No2 Fuse Blowing
Discussion in '2nd Gen. Tacomas (2005-2015)' started by irishexile, Sep 13, 2022.
  1. Sep 13, 2022 at 4:56 PM
    irishexile
    irishexile [OP] Member
    2013 Tacoma 4x4
    Hi, first post! Hopefully someone can help... I've been having the same recurring issue for the past year and no shop can fix it. The IG1 No2 fuse will blow intermittently for seemingly no reason leaving no speedo, no window power, no fan, and a cluster lit up like a xmas tree! Also, the alternator then stops charging and battery dies if you continue to drive. The code reader says P0500 and no other errors. It's a 2013 double cab short bed 4x4.
    It's very frustrating as the randomness means I'm reluctant to take my family in it, especially up the mountains in summer.
  2. Sep 13, 2022 at 5:28 PM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    Welcome to TW. Almost all intermittent problems on vehicles are caused by a connection issue and even for us technicians they are very hard to diagnose due to their random nature and inability to duplicate the concern while testing. Unless there is some sort of pattern failure issue for this on tacomas I doubt there is much we can do for you. P0500 is for Vehicle speed sensor. I am not sure if that is the speedometer sensor on the trans or if that is an Wheel speed sensor for the ABS. By the wording I would think it would be for the trans. What have the shops you have taken it to all done/said?
  3. Sep 13, 2022 at 5:58 PM
    irishexile
    2013 Tacoma 4x4
    I couldn't replicate the issue when it was in the shop and either could they. They looked for shorts and worked their way through various systems on that fuse but no luck. The guy was super helpful and genuinely wanted to solve the issue but just couldn't.
    AJKlug1 likes this.
  4. Sep 13, 2022 at 6:04 PM
    Tacoma Mike
    Southern Maine
    check your ac clutch magnet and make sure it hasn’t rotated and pinched the power wires against the compressor housing.
    b_r_o and irishexile[QUOTED][OP] like this.
  5. Sep 13, 2022 at 7:59 PM
    PineappleMan
    PineappleMan Member
    2015 Tacoma SR5 4x4
    This is what my issue was. I incorrectly replaced my AC clutch magnet and caused it to short out because the coil melted. Every time I turned the fan on it blew the fuse.
    AJKlug1 and Tacoma Mike[QUOTED] like this.
  6. Sep 14, 2022 at 9:26 AM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    I have had the issue also and narrowed it down to being related to the ac compressor. I assume it was the magnetic clutch failing. When I would tow, I just made sure to turn the ac off before down shifting and spiking the rpms. Haven't gotten around to replacing the clutch, but I have other signs now it is failing/failed (smoking belt intermittently at start up).
  7. Sep 14, 2022 at 12:19 PM
    irishexile
    2013 Tacoma 4x4
    My uneducated visual inspection showed no pinched power wires. I checked every wire I could find in the engine block to look for signs of wear or possible shorting but again, all looked fine.
    The only aftermarket add-on was a remote starter if that info is of any use :confused:
  8. Sep 14, 2022 at 12:34 PM
    Tacoma Mike
    Southern Maine
    Could be a internal short in the ac mag.
    Get a fuse diagram to see all the circuits on that fuse. You know most of them cause they ain’t working. Lol
    Then systematically run the vehicle and try every circuit 5 times and see the results. If you can, do not run ac hvac system for a couple of days. I guarantee a coordination between something turning on and everything else sitting. Basically what you are doing when your driving. Make sure everything is shut off
    While driving and work one circuit. Then while driving turn on the ac, then shut it off after 5 min. Wait 5 and turn it back on. At some point you will hit the right combo. Don’t use multiple circuits at once.
    Be very precise. I had to take a cust truck home for two days and drive it until I got the right combo.
    FYI those two wires out of the clutch magnet needs to be centered in the recess of the housing. If it’s not centered then you have a issued there. Make sure the engine is off and use a screwdriver to play with that magnet. If it moves it’s trashed.
  9. Sep 14, 2022 at 12:36 PM
    irishexile
    2013 Tacoma 4x4
    Thanks Mike, really appreciate the help!
  10. Sep 14, 2022 at 12:41 PM
    Tacoma Mike
    Southern Maine
    I’ve had a couple and it does suck the first or second time. That’s what the little black book is for lol.
    But being precise will help you narrow it down
  11. Sep 14, 2022 at 12:42 PM
    irishexile
    2013 Tacoma 4x4
    Also, the short only happens when the fan or AC is running - sometimes immediately, sometimes after a few minutes, other times right in the middle of a long journey.
  12. Sep 14, 2022 at 12:43 PM
    Tacoma Mike
    Southern Maine
    Dam,would have saved me a bunch of typing if you had said that from the start.
    davidstacoma likes this.
  13. Sep 14, 2022 at 12:44 PM
    irishexile
    2013 Tacoma 4x4
    Sorry dude!
  14. Sep 14, 2022 at 12:45 PM
    Tacoma Mike
    Southern Maine
    That’s ok.
    After 48 years I got use to fixing shit in the blind..
  15. Sep 23, 2022 at 9:57 AM
    irishexile
    2013 Tacoma 4x4
    Following up on this issue: after reading every thread I could find, I changed out the blower and the resistor in the hope this would solve the problem. No dice. Took it for a test drive and switched the fan on, fuse blew within seconds and lost speedo, windows, etc.
    Any ideas for next steps @Tacoma Mike ??
  16. Sep 23, 2022 at 10:39 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    If it only blows when the A/C is switched on I bet it's a shorted compressor clutch or shorted wire between the compressor and engine bay fuse box as @Tacoma Mike said.
    I would want to put a clamp on amp meter on the A/C clutch wire and see how much current it's drawing when it's turned on.
  17. Sep 23, 2022 at 1:03 PM
    08TRDOFFROAD
    Dan
    Could check your IA4 connector in the driver's kick panel. It is probably smoked like mine. Could be melted bad enough it is shorted to another wire in the connector.
    irishexile[OP] likes this.
