Intermittent Issues Engaging and Disengaging 4x4
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Musubi3, Oct 3, 2020.
  1. Oct 3, 2020 at 6:21 PM
    Musubi3
    Musubi3 [OP] Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    I went to turn the 4x4 dial to 4H today and nothing happened. No light and no 4x4 engaged. I tried it a couple more times then it finally engaged and then I engaged 4Lo fine. Later, I went to disengage 4Lo (4Lo to 4H), but again no change in lights. It still read 4Lo and nothing blinking (and still in 4Lo). Tried switching the dial back and forth a couple more times and it finally disengaged.
    Got it home and tried engaging and disengaging 4x4 over and over again. It works fine about 9/10 times, but then I'll get the same issue.
    In searching this, it seems like this may be an issue with the actuator, but thought I'd post up and get feedback to confirm or provide different insight.
  2. Oct 4, 2020 at 7:03 AM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    How often do you put it in 4H/L?
  3. Oct 4, 2020 at 9:15 AM
    Musubi3
    Big Island
    Typically it’s at least once a month I engage 4x4
  4. Oct 4, 2020 at 11:44 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  5. Oct 4, 2020 at 3:01 PM
    Musubi3
    Big Island
    Thanks TnShooter! I'll take some time to read through it. So far really good info. I caught that thread while searching, but didn't catch that troubleshoot guide. Thanks for pointing it out.
    Just based on my quick read of the Operation, it seems like my intermittent issue is the signal not getting past the ECU, since I'm not getting the light when it happens.
    TnShooter[QUOTED] likes this.
  6. Oct 4, 2020 at 4:15 PM
    TnShooter
    Deogee
    STOCK
    Musubi3[OP] likes this.
  7. Oct 7, 2020 at 11:27 AM
    Musubi3
    Big Island
    Update:
    I decided to physically check my connections two nights ago (no testing with the multimeter yet). My related mods are the illuminated 4x4 switch (Hilux switch) and the 2Lo module from @Up2NoGood.
    I didn't think it was my switch since the only additional wiring I did was for the illumination portion, but I made sure everything was snug and tight anyway behind the dash.
    I went to check the 4x4 ECU since I had been touching things in there with my truck ECU and completely forgot I had the 2Lo module inline with the 4x4 ECU and switch (which is obvious I know). I disconnected the 4Lo module and reconnected things back to stock. I've been engaging and disengaging since then and no issues (knock on wood).
    So, I'm starting to think the intermittent issue I have is with the 2Lo module or something about it. I'm definitely not knocking it or regret buying it. I'm going to run without it for a few more days to see if I get the issue. If I determine it's the 2Lo module, I think I'll actually reinstall it and run it like that since it really only happens about 10% of the time. Uninstalling it in the field is easy enough should I get an issue.
    Just thought I'd update my thread.
    TnShooter likes this.
  8. Oct 7, 2020 at 12:22 PM
    TnShooter
    Deogee
    STOCK
    Thanks for the Update:thumbsup: :fingerscrossed:
