intermittent keyless access - any ideas?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ComaTosin, Nov 2, 2009.
  1. Nov 2, 2009 at 10:55 AM
    ComaTosin
    ComaTosin [OP] The Not So New guy
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    my keyless entry (lock and unlock) system only works some of the time. I'd say it works once out of 20 times I press the buton. Lock and unlock are equally inconsistent. I have changed the battery 2 times with no luck, what could it be? think the remote itself is bad? is there a way to check? the little machine at pepboys/autozone says it is working and has a good battery but when i take it to my truck it doesn't work? should i check something in the truck?
    thanks!
  2. Nov 2, 2009 at 6:31 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Did it get wet? I had a remote key for my Accord go through the washing machine and it never worked the same after that.
  3. Nov 2, 2009 at 6:35 PM
    ComaTosin
    Drew
    Atlanta, GA
    06 SR5 PreRunner
    see my sig
    No, never in washing machine. I can not remember it getting wet anytime. Anyone have any more ideas?
  4. May 3, 2010 at 12:21 PM
    wolfeye
    wolfeye Well-Known Member
    I'm having this issue.
    Bump
  5. May 3, 2010 at 3:08 PM
    Agent7
    Agent7 Senior Executive of Nothing.
    Toronto, Canada
    07 Tacoma TRD Sport 4x4 6spd
    BHLM, Stubby Antenna, Custom Front Grill, Debaged Tailgate, Added TRD Emblem, Removed Factory Pinstripes, Leer 100XL Cap, Prolumen 6000K HID Kit with custom glare shields, Eurolite Yellow fog lights, 20" Fast Hustler wheels (black w/3" deepdish polished lip), Cooper Zeon LTZ 275/60/20's, Spidertrax 1.25" Wheel Spacers, Custom LED Gauges, Pioneer AVIC F700BT All-In-One Indash Navigation (Hacked)
    It will only get worse. My driver's side eventually failed to the point I needed a new automatic lock for it. Mine failed at the door module, not the remote... They are very expensive unless your covered under warrenty.
  6. May 3, 2010 at 8:00 PM
    wolfeye
    Coma, did you try the spare keyless and see if you are having the same issue to isolate the problem?
  7. Jul 28, 2010 at 9:16 PM
    singlefin
    singlefin Well-Known Member
    Hood River, OR
    Syncro
    Anyone else having this issue or had it resolved? Mine has this issue with both key fobs.
  8. Jul 29, 2010 at 4:55 AM
    atebit
    atebit What's all this, then?
    The basement of the Alamo
    18 Inferno TRD OR 4x4 AC
    Could it be cell phone (or other RF) interference? I once had a Lexus key fob that was unreliable, turned out that my cell phone was causing the interference.
  9. Jul 29, 2010 at 8:09 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Dealer and Autozone usually have a transmitter/fob checker. It'll tell you if it's transmitting.
  10. Jul 29, 2010 at 8:37 AM
    Cobra6
    Cobra6 Well-Known Member
    Beri
    Tennessee Valley
    '06 PreRunner SR5 TRD Sport
    have you tried reprogramming your remote(s)?
  11. Jul 29, 2010 at 8:49 AM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    I have had this problem, it was caused by where I was parked at. I was parked close to some big power lines and it was interfering with it.
