Intermittent Long Cranking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by eda3789, Jan 22, 2024.
  1. Jan 22, 2024 at 7:26 PM
    eda3789
    eda3789 [OP] New Member
    2009 Tacoma PreRunner 2.7L
    Hi everyone,
    I just picked up a 09 Tacoma with the 2.7L in it 3 days ago and it seems to now have a problem where if I try to re-start the engine after a couple of hours of it being off, it takes 2 or 3 tries for the engine to not immediately die after starting. However, it starts just fine on a cold start. I was doing some research and I think its the fuel pressure regulator but I'm new to Tacomas so I don't know for sure. Is there a way for me to test the regulator?
    Thank You!
  2. Jan 22, 2024 at 7:32 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Pop the number 4 coil out and if the tip is oily you need a valve cover and spark plug tube gaskets. Good luck!
  3. Jan 22, 2024 at 7:42 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Pull the vacuum line off the regulator and see if it's wet with fuel, if it is then the regulator is leaking. If it's not then it's probably not the regulator.
    It could be an injector leaking or the fuel pressure bleeding off but you would need a fuel pressure gauge to see if fuel pressure is holding with the engine off.
    That might would cause a misfire, it would affect starting a warm engine.
    Steves104x4[QUOTED] likes this.
  4. Jan 22, 2024 at 7:44 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The regulator regulate the pressure. It does NOT maintain pressure.
    The pressure check valve is in the pump/tank.
    1. Measure the fuel pressure while the engine idles.
      Standard:
      281 to 287 kPa (2.87 to 2.93 kgf/cm2, 40.8 to 41.7 psi)
    1. Stop the engine.
    1. Check that the fuel pressure does not change for 5 minutes.
      Standard:
      147 kPa (1.5 kgf/cm2, 21 psi)
    1schoir likes this.
  5. Jan 22, 2024 at 7:50 PM
    lr172
    lr172 Well-Known Member
    ‘11 DCLB 4.0 Auto
    Fuel pressure problems are likely to be far more pervasive than this. I would start with cleaning the throttle body, given that this happens somewhere between hot starts and cold starts.
    Dm93 likes this.
  6. Jan 22, 2024 at 8:13 PM
    eda3789
    Thank you guys. I will test the fuel pressure and clean the throttle body soon. I suspect it’s a fuel issue because when the problem happens it almost seems like the fuel system needs to be primed like I just opened and drained the system.
    Steves104x4 likes this.
  7. Jan 23, 2024 at 6:10 AM
    lr172
    ‘11 DCLB 4.0 Auto
    If it was a problem like you describe, it would get progressively worse, the longer it sits. You said the problem is there after 2 hours of sitting, but is fine when fully cold. There is a check ball in the fuel pump that keeps the fuel from draining back into the tank. When this starts to fail, the symptoms go from none at a few minutes to bad at some time, usually hours or days. The interval from good to bad is variable by problem, based upon the leakage rate.
    Your reported symptoms sound more like the computer not adjusting the Throttle plate appropriately for the conditions (temp based). When it is kind of warm, the ECU uses only a moderately open throttle, but when cold it goes much further open. Computer learns this position and remembers it. Fill the blade up with carbon and the throttle doesn't pass as much air and therefore struggles to catch after starting, but runs fine once it does.
  8. Jan 23, 2024 at 3:28 PM
    eda3789
    Thank you I will try to clean the throttle body tonight.
  9. Jan 23, 2024 at 9:20 PM
    eda3789
    I just cleaned the throttle body and waited about an hour and a half and it’s the exact same still. I forgot to add that once I do get it started and instantly shut it back off and start it again it starts normally so I don’t think it has to do with the temp of the motor. I will get a fuel pressure tester and check that next.
    TnShooter likes this.
  10. Jan 24, 2024 at 5:56 AM
    lr172
    ‘11 DCLB 4.0 Auto
    that is a bit different than the first post. So, if it has sat for any meaningful amount of time it struggles, but if started immediately after shut down, it struggles? That is symptomatic of the check ball problem in the FP I and others mentioned. Your original post said it started fine when cold, which implies sitting for a while.
    If fine after 1 min and problematic at 1-2 hours, but fine after a full day, then I am struggling to see this as a check ball issue. You should determine all the variables involved, as it could be sensor related.
