Intermittent No crank , No start 99 Tacoma 3.4
Discussion in '1st Gen. Tacomas (1995-2004)' started by Double Taco Jon, Aug 28, 2016.
  1. Aug 28, 2016 at 3:27 PM
    Double Taco Jon
    Double Taco Jon [OP] Member
    Northeast Tennessee
    2008 double cab Prerunner, 1999 Tacoma ext cab 4x4
    So about 4 years back once maybe every 6 months my truck wouldn't start after driving it awhile and stopping no crank no start. As the years past it got to the point it needed to be addressed. It always starts back after it sits for awhile. I put new starter and solenoid which came with last year. It drove no issues for about a month and then started it again usually at the worst times.I decided take to a mechanic which at one time was toyota certified. If you have ever had the pleasure of changing out a starter on a tacoma you will understand why i didn't want try mess with again.He has his own shop now and only works on Toyota. He changed starter again. I drove it again another month or so , no issues then it started back. I took back to mechanic and only thing he did was change out starter again. He drove it , but never stalled on him. So once again drove fine for a month or so then its back to no crank, no start from time to time. When it won't start all electronics and lights work, radio,dome light, head light etc with no noticed dimming. The starter relay tested good, battery is about 12.6 when tested. The mechanic did mention it could have something to do with my vehicle protection package fouling up and shutting starter down. I assume it came factory on the window says Permavin Security . The last time it wouldn't start i did as he said and got out and locked vehicle then unlocked , but still wouldn't start. Theres nothing i can find out about this. I'm at my wits end on this. I have almost ruled out ignition switch cause it never dies while driving. In the past my truck has started back within 5 min up to over a hour or two. I try all kinds of crazy stuff to get started , but haven't found anything seems work on a constant basis. The truck has 190,000 miles. Please help !!, if the rust isn't bad enough now this.
  2. Aug 28, 2016 at 4:03 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I would replace the starter relay, even though it 'tested out' OK. Cheap and easy thing to try. Thats what fixed my no-crank issue, several years ago.
  3. Aug 28, 2016 at 4:06 PM
    mlcc
    mlcc Well-Known Member
    Oregon
    2002 DC TRD/ 1995 4runner
    Mid travel, armour all around
    is it a manual? could be a bad clutch start switch
  4. Aug 28, 2016 at 4:38 PM
    Double Taco Jon
    Northeast Tennessee
    It is an automatic.
  5. Aug 28, 2016 at 9:27 PM
    mlcc
    Oregon
    When it does not start can you remember if you can hear the starter relay click, if not then start with the relay and everything leading up to it.
  6. Aug 28, 2016 at 9:34 PM
    Double Taco Jon
    Northeast Tennessee
    I'm really not sure if clicks or not when won't start . Been awhile since i drove it. I have young child and you never know where you might get stranded nor for how long. When I pulled relay and checked it , it would click. I will change out and see what happens. Thanks.
  7. Aug 28, 2016 at 10:10 PM
    tan4x4
    Rick
    Folsom, CA
    It also could be a defective park/neutral switch. The next time it does not start, try moving the shifter a little.
  8. Aug 29, 2016 at 3:18 AM
    Double Taco Jon
    Northeast Tennessee
    I always jiggle and also move from park to neutral. I'm going pick up relay and start driving it again. I do hope that's the problem.
  9. Sep 17, 2016 at 12:44 PM
    DanM
    DanM Member
    Dan
    Houston, TX
    08 PreRunner SR5
    I'm having the same problem with my '08 4.0. Did the start relay fix it?
    Thanks.
  10. Sep 19, 2016 at 4:56 PM
    Double Taco Jon
    Northeast Tennessee
    Sorry for the delayed response, but no it didn't fix mine. I'm at a loss with whats going on with mine exactly.
  11. Sep 19, 2016 at 6:08 PM
    kylehirsch87
    kylehirsch87 Member
    Kyle
    99 tacoma ext cab TRD
    Supercharged, cold air intake
    Had the same issue with my truck. Intermittent no starts. Sometimes the solenoid would engage but no starter. Sometimes nothing at all. Chased it and chased it thinking it was in my security system. I ended up having corroded battery terminals and corrosion in the wire leading to it. A can of electrical parts cleaner and a wire brush fixed it right up. Ill be changing those out soon enough.
    IDK if you have checked that, but sometimes problems are that simple.
  12. Sep 20, 2016 at 7:31 AM
    kgw
    kgw Well-Known Member
    kgw
    SoCal
    99 PreRunner
    140 amp alternator, Big 3 upgrade, Ultimate Headlight Mod, Trans Cooler
    Have you checked your electrical grounds? On my taco, the ground on the intake plenum next to the diagnostic port was loose, and would randomly cause no starts.
  13. Oct 19, 2016 at 5:32 PM
    DanM
    DanM Member
    Dan
    Houston, TX
    08 PreRunner SR5
    Took it to the dealer and they replaced the starter. Problem solved.
