Intermittent No Start Condition (long cranking before starting)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jar-sr5, Sep 18, 2009.
  1. Sep 18, 2009 at 2:48 PM
    jar-sr5
    jar-sr5 [OP] Active Member
    Manitoba, Canada
    tacoma SR5
    Grille Craft, 245/75/16 Wrangler Duratracs
    I'm having that problem where is cranks a lot before starting or doesn't start on the first try.
    I know many other people are having this same problem and i was wondering if anyone has heard of a tsb for it for the 09's ?
    below is the tsb for the 05-07's :
    ETA: EG011-07 JUL 07 Engine Controls - Intermittent No Start Condition
    http://www.empirepao.com/tsb/T-EG011-07.pdf
  2. Sep 18, 2009 at 3:12 PM
    98tacoma27
    Ben
    Not Beech Creek
    Take it back to the dealer for warranty coverage.
  3. Sep 18, 2009 at 4:02 PM
    T0LLPHR33
    T0LLPHR33 Well-Known Member
    S1N C1TY...(from Hilo, HI)...
    BSP TRD Off-Road
    APR X-1 | TRD CAI w/Clear Cover | TRD Short Shifter w/ TRD "RED" Shift Knob | SGII w/Blendmount| Snugtop SL w/KeyLess Entry | 5% Tint | Pop-n-Lock | Bosch Icon WB | S2K Antenna | HRM | LS 8K Projectors w/BSP HLM & 8K Fogs w/FLM | Debadged |Tinted Tails | Black Weathertechs | MX RGM & RBM | Optima Red Top 35 | Gatorback Belt |
    you got the TSB in hand but do you still have warranty? either way I would have the stealership take a look at it...good luck and keep us posted...
  4. Apr 30, 2010 at 9:59 AM
    Twirlin
    Twirlin Nature just gets the blow-by
    WI
    '10 TRD Sport Mag Grey
    sounds to me like it's the nature of the beast, but also not normal to those of us not used to it. Newer cars with more computer controlled parts seem to do this. If it was a serious problem, there would be a TSB out for it (after '07).
  5. Apr 30, 2010 at 10:05 AM
    rcbs204
    rcbs204 Well-Known Member Vendor
    I have this exact same issue, very intermittent, gonna go see if mine has been updated.
  6. Apr 30, 2010 at 11:41 AM
    blazze2005
    blazze2005 Well-Known Member
    South Jersey
    05 Tacoma Pre-Runner Sport
    Fuel Off-Road Octane Wheels,Yokohama Geolander ATS 265/65/17.Grillcraft,Borla Exhaust,Truxedo Lo Pro Tonneau Cover,Pop n Lock Tailgate Security,Custom Wet Okle TRD Seat Covers,Catch-All Matts,Gatorback Belt,Shorty Antenna,Toyota Bed Matt,Sirius Radio,Vent Sades,20% Lumar Window Tint
    my 05 tacoma use to have this problem. After I changed
    the miss-matched spark plugs from the factory,it's started perfectly since.
    Put 6 new Denso plugs in...Problem solved
  7. Apr 30, 2010 at 1:27 PM
    Fireguy67
    Fireguy67 Rebecca and Willow's Opa
    Klaus
    Maple Ridge, BC
    2013 4X4 4 door long bed TRD sport
    No mods- running boards, vent visors all around ,Leer XQ Cap, hood deflector,bed extender, OEM roof rack, Toyota bed mat.Nothing fancy!
    Had this problem very intermitantly- was told by a mechanic that it was due to the minimal percentage of ethanol in the gas in Canada, but as blazze2005 stated above- once I changed all the plugs to one brand( in my case NGK) no problems- fingers crossed!!!
  8. Apr 30, 2010 at 1:30 PM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    my truck takes a few cranks to start too, but im pretty sure its normal, my golf did the same thing.
  9. Apr 30, 2010 at 1:41 PM
    mattsowell
    mattsowell Ridiculously lazy member
    kamloops, bc
    2010 Tacoma TRD DC SB sport debadged
    no seatbelt chime, stubby antenna, 5100's front and back with AAL, offset rims with Dura-Trac rubber, weathertec mats, Image Dynamic sub with 5 channel Amp and Kenwood Deck with steering wheel control, PIA bulbs, K&N air filter, ARB Delux front bumper
    my new 2010 has the same issue. My 01 blazer and 89 cherokee never had that ever. NOt sure if its a problem or just the way it's built
    Manfred likes this.
  10. Apr 30, 2010 at 3:35 PM
    AFTaco
    AFTaco Well-Known Member
    Doug
    Anchorage, Alaska
    TRD Off-road
    subscribed
  11. Nov 8, 2010 at 4:03 PM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    Add me to the list. I've had this issue about 3 or 4 times in the last couple of months. Doesn't seem to depend on weather, moisture or outside temp. The Tacoma never started as fast as my old Chevy but was fine. This is a whole other thing and definitely not normal. If it gets worse it'll have to go in to the dealer, I suppose. Mine is a 2009 with about 18k miles....
  12. Nov 8, 2010 at 4:11 PM
    Thucker
    Thucker Well-Known Member
    Portland, OR
    2010 Mag. Gray BC LB Sport 4x4
    I have a 2010 with less than 10k on the odometer and this has happened to me a couple times. One time where it cranked and cranked and wouldn't start on the first try. I turned it off and tried again, it cranked for a couple sec then started. Other times it cranks for a couple sec before starting.
    It's actually pissing me off cause it's so new. If it happens again, I'm going back to the dealer and make them do something about it.
  13. Nov 8, 2010 at 4:16 PM
    503TRD
    503TRD Trucker
    Chad
    Tualatin, Oregon
    '10 4x4 DC TRD Sport
    Front Bilstein 5100's Set @ 2.5", Rear Bilstein 5100's, Rear TSB, Rear 1.5" ToyTec AAL, 1" CB Drop Kit, N-Fab Nerf Steps, WeatherTech All Weather Rubber Floor Mats, Grillcraft Grill(Upper/Lower), Blacked Out AC Condenser/Radiator, Tinted Front Windows, Vision X H4 SuperWhite Headlights, Halo H10 Solaris Yellow 45w 3000k Fog Lights, K&N Air Filter, Removed Front Mud Flaps, 18" MagnaFlow Muffler, Chrome Exhaust Tip, TRD Logo Leather Shift Knob, LED License Plate Lights, LED Interior Lights, LED Reverse Lights, LED Auxiliary Reverse Lights, Chrome TRD Badge on Tailgate, Redline Tuning Elite Hood Struts, Disabled Seatbelt Chime, Foglights Anytime, ScanGauge II, 13" Stubby Antenna, Flyzeye Design LED Light, Cobra 19 CB Radio/Firestik II Antenna, 18x9 Raceline Raptors, LT275/70/18 Hankook Dynapro ATm, 1.25" Sidertrax Wheel Spacers, Heated Front Seats, LED Tailgate Bar, 11" Double Row LED Bar Behind Grill
    X2, my truck has not started(on the first try) twice, and two other times its cranked slightly longer than usually...kinda weird considering its a 2010 with 2k miles...
  14. Nov 8, 2010 at 4:17 PM
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    Mine does the same, sigh
  15. Nov 8, 2010 at 4:22 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Mine did it one time.....1300 miles from home.....in a construction zone sitting in a line of cars in the middle of nowhere:eek: Turned the key to start, cranked for 10 seconds with absolutely no sign of life at all. Turned key off, then back on, fired right up. Ran all the way home no problems. Five months later, still hasn't happened again.
    That tsb I believe is part of the emmissions warranty, 7 years? I was going to ask to have it done, but scared to let the dealer mess with it now since it's running great.
  16. Nov 8, 2010 at 6:58 PM
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    I've had my 2010 for a year and it's done this a couple of times. It will turn over and turn over, but not start. When I turn it off and try again, it fires right up.
    The problem hasn't been nearly frequent enough to warrant wasting hours at the dealership for them to shrug and say they "can't find anything wrong".
  17. Nov 8, 2010 at 7:09 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Add me to the list too. I was thinking the fuel is draining back.
  18. Nov 9, 2010 at 3:17 AM
    Jimsc
    Jimsc Well-Known Member
    Jim
    Greenville, SC
    10 PreRunner Double Cab
    Aries Nerf Bars, Cargo Seperator
    Mine starts fine when its cold, but after it warms up the starter turns over twice as long to start. Not a problem and it has never failed to start just seems odd that it takes longer to start after its warmed up?
  19. Dec 11, 2010 at 7:29 AM
    vpcustoms
    vpcustoms Well-Known Member
    2017 Double Cab 4X4 TRD Sport
    Took mine it today to have the tsb done for excessive cranking. It only happened twice in the past year, so i took it in and they did the update, the tech said that there is also a tsb on the transmission shifting so i said go for it and do it, all covered under warranty and did not cost me a dime.Will keep posted if it ever happens again.
  20. Feb 8, 2011 at 11:23 AM
    PB65stang
    PB65stang Well-Known Member
    Patrick
    Kansas City
    2016 F150 Lariat 4x4
    5100s (2.5" front), OEM Raptor wheels, 315/70/17 BFGs, Undercover, tint, Weathertechs.
    Add me to this list as well. My 2009 did this a couple times right after I bought it, and it's been doing it again lately. Went almost 9 months without it doing it at all. I took it to the dealer, and they "couldn't duplicate the problem". I'm not concerned about the truck necessarily, it's just frustrating. Mine also seems to be slightly flooded when it does start (runs rough for 1-2 seconds) which makes sense.
    Glad to know this happens to other people as well, and it's not just my truck. My best guess is that the key could have something to do with it, because my Dad's Xterra does the exact same thing, and it's with 1 key only.
