Intermittent overheating, AC blows warm
Discussion in '3rd Gen. Tacomas (2016-2023)' started by LivinOnEdge, Aug 7, 2018.
  1. Aug 7, 2018 at 6:12 PM
    #41
    cstern1
    cstern1 Well-Known Member
    Caleb
    KCK
    2017 DCSB Sport
    Blasting heat actually blows air across a heater core, basically a mini radiator. Its how you get heat in the truck. Uses the coolant.
    This works the same as the radiator fan blowing across the radiator, but on a smaller scale. Removes heat from the coolant.
    BSFord and shakerhood like this.
  2. Aug 7, 2018 at 6:21 PM
    #42
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Thats overheating for sure.
  3. Aug 7, 2018 at 6:23 PM
    #43
    lynlan1819
    Tacoma
    Lifted
    The needle should stay in the center,I live in HOT Las Vegas 115,and both my Tacomas stay in the middle no matter if its stopped traffic.
  4. Aug 7, 2018 at 6:25 PM
    #44
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    How long have you been sitting in traffic, idling like this in 100 degree weather with the AC on?
    Spare Parts likes this.
  5. Aug 7, 2018 at 6:28 PM
    #45
    LivinOnEdge
    LivinOnEdge [OP] ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    Heres the update. It dropped from 107 to 100. Stuck in traffic for 2.3 hours. Overheats when ac is on, air is barely even cold anymore. Sweating my balls off, kill me.
    Running Board Man likes this.
  6. Aug 7, 2018 at 6:29 PM
    #46
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    My truck can idle in 100+ with ac full blast for over an hour and not move from the center...ac suffers though.
  7. Aug 7, 2018 at 6:29 PM
    #47
    Pine State
    Pine State Well-Known Member
    Maine
    2018 Tacoma DCSB SR5 4x4
    If im not mistaken , most or all vehicles these days use gauges with perhaps four programmed readings cold/running/hot/overheat
    Its not an analogue gauge so its only reading what the computer gives it. Dont think an app will help here
  8. Aug 7, 2018 at 6:29 PM
    #48
    anthony250f
    Anthony
    San Diego, CA
    Def go to the dealer. Fan clutch may be slipping too much
  9. Aug 7, 2018 at 6:30 PM
    #49
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    My first car would warm up like that sitting in traffic, it had a bunch of electrical Gremlins one of which was the radiator fan would only work when it felt like it. If I sat long enough it would get close to the red, even in 40° temps. Maybe you have a bum thermostat.
    And yes blasting the heat will absolutely help cool the engine, that was my last resort and my car never actually overheated.
  10. Aug 7, 2018 at 6:31 PM
    #50
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Bullshit it isnt, I have a scan gauge in one of my cars and I can easily watch the water temp climb and inlet air temp quickly at idle in traffic with the AC on.
    OP's initial post was an hour ago so I assume that first post was after some time in traffic and not moving.
    He has left that information out of all his posts so what's the harm in asking that important detail?
  11. Aug 7, 2018 at 6:31 PM
    #51
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    The heater core is just a small secondary radiator. Turning on the heat does cool off the truck. Sitting in 100* heat idling is the some of the most extreme conditions for overheating. Placing the transmission in neutral or park and getting some engine rpm's up will help too.
    I don't think you have a problem. It's not hot, just a little warm and it's not gotten any worse in an hour.
    Lt. Dangle, RedBeard1 and Lawfarin like this.
  12. Aug 7, 2018 at 6:31 PM
    #52
    LivinOnEdge
    Land of The Lost
    Going into the dealership first thing when their doors open.
    TacoRated and tcjacado like this.
  13. Aug 7, 2018 at 6:37 PM
    #53
    Jeffas7
    Jeffas7 Monta what na???
    Missoula
    12quad6spd
    Stay hydrated brother
  14. Aug 7, 2018 at 6:38 PM
    #54
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Did you leave it idle for over 2 hrs?
    BillsSR5 likes this.
  15. Aug 7, 2018 at 6:39 PM
    #55
    LivinOnEdge
    Land of The Lost
    Funny you say that. I was going to ask if anyone around me has a motorcycle they could drop off some refreshments to me. My water in my bottle is hot enough to brew tea.
  16. Aug 7, 2018 at 6:44 PM
    #56
    TheGrayRider
    TheGrayRider MARANATHA !!!
    NW Florida
    2017 BBP DC 4X4 OR
    My Bluetooth UltraGauge app tells me my truck runs around 195 degrees F most of the time. Doesn’t matter what the outside air temperature is. If I get stuck in traffic it will go up to around 210-212 degrees F.
    Do you know what the actual water temperature is or you going by the outside air temperature ?
    If you don’t have a warning light and the engine isn’t idling rough... drive on
  17. Aug 7, 2018 at 6:45 PM
    #57
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    A lot of overheating...lol our car blew a gasket twice last year, in Joliet and at gingerman
    Also idk about your beater car but ours didn't have ac and it was always moving.
  18. Aug 7, 2018 at 6:46 PM
    #58
    Pine State
    Maine
    You were implying the gauge was not accurate. Im saying the gauge is not figuring out the temp, only displaying what the computer tells it to. He knows its hot, the gauge says so, how will knowing its 201.356 degrees help him out? Shits fucked in either case
  19. Aug 7, 2018 at 6:46 PM
    #59
    Beef Nachos
    Beef Nachos Here for a good time, not a long time
    Dallas/Ft. Worth
    2017 SR5 DCSB 4x4
    But it’s not new, it’s a year old with 20k
    :stirthepot:
  20. Aug 7, 2018 at 6:46 PM
    #60
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    You do realize if he's in traffic close behind another idling car hes also got that heat to contend with besides ambient air. Since most thermostats open around 205 and overheat engines above 235, there isnt a big temperature range to deal with.
    If you're not moving at all then I'd shut down the truck till you do.
    Curious what the OP's coolant to water ratio mix is, 50/50 is not ideal for eveyone.
    scottalot, BillsSR5 and Spare Parts like this.
