Intermittent Power Window Failure
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ianp05, Oct 12, 2015.
  1. Oct 12, 2015 at 1:52 PM
    Ianp05
    Ianp05 [OP] Well-Known Member
    IAN
    DETROIT
    2006 Double Cab 4x4 TRD Sport
    I have a weird issue here.
    I'm having problems with my passenger side front and back power windows. I'd say we've had 4 incidents since march so it doesn't happen all the time. I often drive with my windows down and sometimes when I get into the driveway they wont go up. I've tried both the driver's side button and the passenger buttons and neither works. The car can be on and idling or off, it doesn't work in either situation. If I put the gear in drive and start pulling around the block, they will work.
    I'm assuming that this is some kind of a power supply issue, as I would imagine there's more power to supply when driving than there would be in idle. I've tried revving the engine in park which doesn't, it has to actually be driving.
    It's an '06 DCSB with 135k miles and I don't believe the window motors have ever been changed.
    Any input would be greatly appreciated. Thanks!
  2. Oct 12, 2015 at 1:54 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Might be the battery going out.
  3. Oct 12, 2015 at 1:57 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    Nope, plenty of power is available even with the engine off and relying solely on the battery. Revving the engine should make no difference and sounds like it didn't which is good. I'd be worried for you if it was making a difference to rev the engine.
    It sounds like an electrical system issue. It's weird and I can't think of what could be causing it. Somehow the truck is getting the wrong sensor or signal and the ECU is preventing the windows from operating. Hmmm. I'll think on this for a bit and report later.
    Ianp05[OP] likes this.
  4. Oct 12, 2015 at 8:14 PM
    Ianp05
    IAN
    DETROIT
    Bump for the nighttime crew!
  5. Oct 12, 2015 at 8:38 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Is this effecting only the Passenger side front and rear windows or all of the windows? The only thing in common with all the window controls is the ground which all are grounded through the drivers master control panel. PM me your email and i'll send you a print.
  6. Oct 13, 2015 at 9:42 AM
    Ianp05
    IAN
    DETROIT
    Pm'd. Thanks!
  7. Oct 13, 2015 at 2:23 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    You got mail!
  8. Oct 21, 2015 at 10:22 AM
    jmcco55
    jmcco55 Member
    2003 Tacoma
    Howdy! I've started having the same problem with my '03 DC Taco; passenger side window won't roll up with driver's or passenger's controls. It fixes itself somehow and starts working again. Were you able to identify a fix? Thanks!!
  9. Feb 24, 2016 at 4:35 PM
    mightym
    mightym Well-Known Member
    SoCal
    2006 Silver Tacoma Long Bed
    Bump, having same issue with my left rear window going down but doesn't come up sometimes.
  10. Mar 15, 2016 at 10:56 PM
    DayStars
    DayStars Well-Known Member
    benn
    Edmonton
    07 Tacoma TDR 6spd DCSB
    2007 Tacoma, 6-speed, 4-door....
    Very similar issue.... rear passenger window works intermittently. Has been doing this for at least a couple years, but not often enough for me to look into it in detail, as long as it goes back up then i'm somewhat content......As I type this now, the window is currently down about 4", since this afternoon, and it will not go back up. I'm losing my 'content'.
    I found this link http://www.aa1car.com/library/power_windows.htm in another thread on here. I'll try trouble shooting it tomorrow...
  11. Mar 16, 2016 at 12:39 AM
    Jimmyh
    SC
    2012 Prerunner SR5
  12. Mar 16, 2016 at 3:29 AM
    McTeague
    McTeague Well-Known Member
    Alan
    2012 MGM Tacoma DCSB TRD Off Road
    Stock
    So I had a lot of these window issues in my Cobra convertible.
    Window going only one way intermittently is most likely corroded switch from water dripping into it, replace switch. Lots of water drips right into the switch when window is open on my vert due to no rain gutter on top.
    Not working at all is most likely the motor, try slamming the door to get it to work and replace the motor.
  13. Mar 16, 2016 at 5:53 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    ^^^ Makes sense. That is also why I love my Vent Shields so I can crack open the windows and not drip into the cab.
