Intermittent Start Problem / Gear Selector
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fortech, Mar 29, 2013.
  1. Mar 29, 2013 at 9:01 AM
    Fortech
    Fortech [OP] Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    I've been having a weird problem as of late, that affects the starting of the vehicle as well as the transmission gear selection. My Tacoma is a 2005 4.0L V6 with the 5 speed auto.
    I seem to be having a problem with my shifter or gear selector. Sometimes the truck won't start because it does not think it is in Park. Sometimes shifting to neutral will allow it to start, sometimes not. Sometimes when shifting from park into drive there will be a lag before the truck goes into gear. Sometimes it doesn't go into gear at all, I have to reposition the shifter or fiddle with it a bit. While this is happening the shifter may be in the drive position, but the "D" light in the dashboard isn't illuminated. Happens with neutral and park sometimes too. The shifter is in position but the appropriate light in the dash doesn't illuminate.
    Has anyone else experienced this? Obviously there is a maladjustment between the shifter mechanism and the electronics controlling the transmission. I'm just wondering what I have to sync, and the procedure to do it.
    Thanks y'all...
  2. Jul 6, 2013 at 7:28 PM
    rcchris
    rcchris Well-Known Member
    Halifax
    '12 v6 4wd access cab auto black
    Did you find a solution to this problem? A guy I work with just recently had the same problem, his is a 2005 model as well.
  3. Jul 6, 2013 at 8:14 PM
    Fortech
    CANADA
    I adjusted the neutral safety switch and this far everything has been great.
  4. Sep 30, 2015 at 6:04 AM
    markcheverie
    markcheverie New Member
    mark
    2005 Toyota tacoma
    I have the exact same issue can you tell me the procedure you did to adjust the neutral safety switch?
  5. Nov 25, 2016 at 9:27 AM
    rmalin
    rmalin Member
    Ross
    MA
    09 TRD OR
    Im having a similar issue with my 2005 tacoma. Can anyone help me out with an adjustment procedure for the nss or inhibitor switch (ive heard it called both)?
  6. Dec 13, 2018 at 4:27 AM
    BenSkiv
    BenSkiv Well-Known Member
    Ben
    Maine
    2019 Tacoma TRD-off-road DCLB
    Anybody ever get figure this out? I adjusted my NSS and it fixed it for a bit, but now this problem is back.
