Intermittent Starting Issues . . .
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NMG, Jan 12, 2016.
  1. Jan 12, 2016 at 4:47 PM
    NMG
    NMG [OP] Well-Known Member
    Ottawa
    09 Double Cab TRD Sport
    Hey everyone, was hoping you could help point me in the right direction.
    I have a 2009 Double Cab and have been having intermittent starting issues for about the last 6 months. It's only happened probably 4 or 5 times over that period, but the symptoms are always the same.
    When it happens, I'll turn the key and get nothing. No cranking and no clicking. I still have power though as the radio and dash lights come on fine. Sometimes I'll re-try and get the same thing. Eventually, the truck will turn over but it will crank really slow, almost as though the battery is dying. Once I get it started and drive for a bit, it will start no problem and it will fire up right away, basically as though nothing is wrong.
    When it first started doing this I changed the battery out thinking that was the problem. It didn't do it again so I assumed it was solved. It came back again a couple of months later so obviously that wasn't it. The last time it happened I took it into the dealership for a look. They did a diagnostic of the starting and electrical system and didn't find anything. Truck ran fine after that until today.
    This morning it fired up great, then sat all day. When I got in to head home from work, I got no response from the key. This happened twice then the third time it started cranking but wouldn't turn over. It was cranking very slowly. It did this three times without turning over before finally starting. Again, it was like the battery was almost dead. I was probably cranking for 3-4 seconds as well, which is way longer than I've ever had to before when it did this. I had to run some errands after work and I got the "no response" to the key once, but that was it. When it did respond, it started very quickly and there was no slow cranking.
    Does this sound like the starter going out to you? Any other thoughts? Don't really want to drop a pile of dough on "possible" fixes and unless it's doing it, you wouldn't really know something was wrong.
    Thanks for any feedback you may have!
  2. Jan 12, 2016 at 4:48 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    Check the battery connection to the starter
    12TRDTacoma and DustStorm4x4 like this.
  3. Jan 12, 2016 at 4:49 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    you had anything installed that could be causing a drain on it?
  4. Jan 12, 2016 at 4:49 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Maybe the alternator?
  5. Jan 12, 2016 at 4:56 PM
    NMG
    Ottawa
    K, I will try and check the connection to the starter.
    The truck is bone stock so there shouldn't be any drain.
    I haven't noticed any lights dimming and when I'm not having the issue, the battery seems fine. It cranks very quickly and starts right up.
    It's strange.
  6. Jan 12, 2016 at 4:57 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Most dreaded word "intermittent"
    cosmicfires and 12TRDTacoma like this.
  7. Jan 12, 2016 at 5:31 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    That sounds like a loose connection somewhere - I'd be looking at all power and ground connections between the battery, starter, engine block, and body ground - including where the positive cables are installed on the stud of the battery post clamp. Assuming you've already ensured that both post clamps are clean and tight, if not, do that first.
    cosmicfires likes this.
  8. Jan 12, 2016 at 5:32 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    Some see it as a challenge...
    12TRDTacoma likes this.
  9. Jan 12, 2016 at 6:41 PM
    NMG
    Ottawa
    Connections to the battery are clean and tight, will try and inspect the others. For me, intermittent is a PITA!
    Thanks all!
  10. Jan 12, 2016 at 11:39 PM
    TacoTaco15
    TacoTaco15 Well-Known Member
    Jake
    VA
    2015 MGM DCSB PreRunner 2.7
    What he said. To me, this sounds like a loose connection issue. I'd check all connections AND grounds from the starter and battery. Something sounds to be corroded and or maybe a ground is coming loose.
    Intermittent is bad b/c the problem probably isn't super serious and may be hard to spot. I'd re-tighten and clean all connections - I think that'll clear it right up, and I think you'll find one connection that makes you say 'hmm, that was a bit loose' or 'hmm, that was a bit dirty'.
    IMHO, as always.
  11. Jan 13, 2016 at 2:45 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    As this is a 2009 Taco I would highly suspect the Starter Solenoid is worn and burned from use and age. They do have a rebuild kit for those I think #DoorDing has the low down on rebuilding these. Or do a search. It isn't uncommon and will give you the symptoms as you described...
    It isn't hard to do, just a small pain in the @ss. Cheaper than replacing the starter by leaps and bounds.
  12. Jan 13, 2016 at 3:17 PM
    NMG
    Ottawa
    Okay, thanks guys. Truck acted perfectly normal today, LOL. As soon as it warms up I'll check the connections and go from there if they check out.
  13. Jan 13, 2016 at 5:12 PM
    cheech1
    cheech1 Well-Known Member
    Kaneohe, HI
    08 PreRunner Off Road
    Sounds like starter to me, but as others have said, check all connections, ESPECIALLY the grounds.
    Had similar problem with my old '84 pick up. Prior to replacing the starter, I would make sure I parked on a hill so I could roll start it.(manual tranny) I also carried a hammer to give the starter a whack to get it going.
    BTW, that was the only major repair I had on that truck in over 100k miles.
  14. Feb 8, 2016 at 8:45 AM
    pretzel
    pretzel Well-Known Member
    TX
    2010 Tacoma 4 cyl
    Did you find the problem/solution?
  15. Apr 20, 2020 at 5:16 PM
    TequilaAndTacos
    TequilaAndTacos New Member
    Isaac
    2007 short box taco
    Was this issue ever solved? I’m having the exact same issue, but it’s much more frequent. Seems to always be right before I leave for work.. no matter the time of day lol
  16. Sep 12, 2020 at 3:13 PM
    hresendiz25
    hresendiz25 Active Member
    Horacio
    Arizona
    2009 Toyota Tacoma 4x4 Double Cab
    URD Fuel Pump
    Any resolution?
    Experiencing the exact same problem.
    I even called to be towed. Then it started.
    Cancelled the towing truck. But I am now confused since it starts good.
    Starter? Relay?
  17. Sep 12, 2020 at 3:18 PM
    ohiowa
    ohiowa Have you tried rebooting?
    Ohio
    2015 Super White TRD OR DCSB V6 6MT
    ARE Overland Shell
    I can’t speak for OP, but this sounds like a trademark starter solenoid/starter replacement. Weak/no start that only happens sometimes is usually the only warning you get that your starter or solenoid are going bad. I had a 2003 Corolla that just refused to start one day out of the blue around 120,000 miles. New starter and it was fine again for another 100,000 miles.
    hresendiz25[QUOTED] likes this.
  18. Sep 12, 2020 at 5:35 PM
    EvilElvis
    EvilElvis Well-Known Member
    PNW
    2012 3wd
    I had similar symptoms to my truck. Turned out to be corroded contacts inside the starter. I took out the starter and cleaned out the internal contacts with sandpaper, fixed the issue. Similar to what was done in this thread, but I just cleaned up the contacts.
    https://www.tacomaworld.com/threads/how-to-rebuild-the-tacoma-starter-motor.200964/
  19. Sep 12, 2020 at 7:26 PM
    MikeDeason
    MikeDeason Well-Known Member
    The problem is your ECU. Replace it. I had same thing. Eventually traded up to a 15 to get if off my neck.
  20. Sep 12, 2020 at 7:48 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    No.
    This is the issue. Rebuild the starter solenoid < 1 hour for <40 dollars.
    You can buy the contacts and plunger new from Nations Starter and Alternator for about 30 - 35 bucks. Much cheaper than hundreds for a rebuilt POS from Autozone etc.
    https://www.nationsstarteralternator.com/Starter-Rebuild-Kits-s/37.htm
    Check this video for rebuilding the solenoid on the starter.
    https://www.youtube.com/watch?v=qwokxzjlYcQ&feature=emb_logo
    davidstacoma, hresendiz25 and ohiowa like this.
