Intermittent Starting Problem - Tacoma Sport 2022
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacomaXX55, Aug 4, 2022.
  1. Oct 16, 2022 at 11:54 PM
    TacomaXX55
    TacomaXX55 [OP] Member
    You should bring it to your dealer and have them download the code. Apparently, the ECU will store the error code information for a few days until it get overwritten. The error code however will not point to the exact problem but it's good to have this documented as it's really hard to reproduce.
  2. Oct 17, 2022 at 5:55 AM
    22Coma6MT
    22Coma6MT Well-Known Member
    2022 TRD Sport AC 6MT
    seems odd to me they would just replace the battery. they can test the battery under load and determine if it is good or bad.
    i would have suspected one of the switches/sensors/contacts mentioned in another post. the push button start, park and brake pedal engagement, and associated wiring are where i would focus.
    Edit: I use to troubleshoot and repair electro/mechanical systems and most intermittent electrical issues were caused by a loose or poorly made connection, or a bad contactor/switch.
  3. Oct 19, 2022 at 5:01 PM
    NotAFanofToyota
    NotAFanofToyota New Member
    2022 Toyota Tacoma SR5
    I am having a similar issue right now - 2022 Tacoma SR5. I’ve had zero problems other than it randomly deciding to not start. It cranks and the battery runs perfect, so I’m beginning to think it’s a fuel pump issue (I’m not mechanically inclined at all). Toyota tells me nothing is wrong with it at all because they apparently got it to start right away the first time I brought it in. But this time…I took video on 2 separate occasions showing that it wouldn’t start. Having it towed in tomorrow and I’m honestly thinking about selling it right away if it decides to start up again. Toyota’s response to the last time it was brought in left much to be desired, and I honestly don’t think I’ll ever buy one again.
    22Coma6MT likes this.
  4. Oct 19, 2022 at 5:10 PM
    saint277
    saint277 Vigilo Confido
    The CEL is always on when the truck is on but the engine isn't started. That's why it doesn't have a code they can read, and why one isn't stored in memory.
  5. Oct 19, 2022 at 6:29 PM
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Falken Rubitrek AT 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    Are you positive you are pressing brake and then starting?
  6. Oct 20, 2022 at 10:25 AM
    NotAFanofToyota
    ***important update to my similar issue***
    Fortunately the truck wouldn’t start in front of the service manager and staff. They started diagnosing it and found that the main relay was bad. Apparently it’s a simple fix - they ordered the part and it should be all done tomorrow.
    Idk if your issue is the same as mine, but it would be worth a shot letting them know about my situation
    Canadian Caber likes this.
  7. Oct 20, 2022 at 11:49 AM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Great News. Glad they figured it out for you. We have to ask. Are you now a fan of Toyota?
  8. Oct 20, 2022 at 11:53 AM
    NotAFanofToyota
    Well it’s not running just yet, so I’ll remain not a fan for the time being, and probably a little while after until I know the issue is permanently gone
