intermittent starting problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MRPVette, Oct 3, 2022.
  1. Oct 3, 2022 at 7:02 AM
    MRPVette
    MRPVette [OP] Well-Known Member
    Kingwood Tx
    2011 tacoma TRD
    Tinted windows, alarm, leather interior, retraxx bed cover, 3" lift,17x8 moto medal rims,275/70/17 bfg tires
    I have a 2011 Tacoma with 127k on it Saturday I decided to try and figure out why the ac outlet in the bed is no longer worked,anyway I had my wife press the inverter button on the dash 8-10 times while I listened to figure out which relay it was under the hood. About an hour later my truck would crank but not start finally after about 30 minutes it cranked up.I drove it on and off all day Sunday and it drove fine went to run to the store last night and it wouldn't start 15 minutes later cranked right up.any ideas
  2. Oct 3, 2022 at 7:20 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Would check battery and Alt
    Run down to parts store and test both
  3. Oct 3, 2022 at 7:29 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    See if the security light next to the clock is flashing with the key on when it won't start.
    TomTwo, tenui and Geeves77 like this.
  4. Oct 3, 2022 at 11:08 AM
    tenui
    tenui Well-Known Member
    This happens to me whenever it is hot out and I park in the sun (90F+). Leaving the windows open a bit and letting the ignition assembly cool down solves it.
  5. Oct 3, 2022 at 2:14 PM
    Waasheem
    Waasheem
    2007 xrunner
    On mine, a failing clutch pedal switch was causing an intermittent no start. Stuck in a bypass wire, no more stomp to start.
    Next I had to replace the starter solenoid contacts, problem solved, fires up every time now.
  6. Oct 3, 2022 at 4:04 PM
    Waasheem
    Waasheem
    2007 xrunner
    Oops, you mentioned crank but no start. So my previous post is no help.
    Jimmyh and wilcam47 like this.
  7. Oct 3, 2022 at 4:42 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    How's the condition of the battery terminals?
    whatstcp and TomTwo like this.
