Intermittent steering wheel shake
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tim7902, Aug 19, 2017.
  1. Aug 19, 2017 at 6:57 AM
    Tim7902
    Tim7902 [OP] Well-Known Member
    Tim
    Maryville, TN
    2001 tacoma doublecab
    I've been having some intermittent steering wheel shake while driving around 60mph or greater. I've also noticed at speeds around 70 or so i hear a pop sound that sounds like someone tapped the bottomside of the drivers floorboard with the end of a ratchet. Any speed lower than 60 and no shake or noise. I'm wondering if a lower balljoint would cause these symptoms?
  2. Aug 19, 2017 at 7:23 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    It could. Jack it up and check out your front end
  3. Aug 19, 2017 at 7:28 AM
    AllTerrainMonster
    AllTerrainMonster Well-Known Member
    South Korea
    2006 2.7L Base 2WD
    I had shake as well and it turned out to be one of my front tires blew a bead and caused a bubble to form in the tread, had to get it replaced
  4. Aug 19, 2017 at 7:44 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I recently experienced a mild steering wheel shake at freeway speeds.
    Getting the tires re-balanced and rotated solved that. No charge for that, at America's Tire where I bought the tires.
  5. Aug 19, 2017 at 9:36 AM
    Tim7902
    Tim
    Maryville, TN
    I jacked up on the lower control arm on both sides and checked for play in the wheel up/down and side to side. No play on either. Nothing looks obviously wrong. Put the wheel back on and drove it down the road and still doing the same thing. :notsure: next i may try rotating the tires and see what happens. I cant imagine its a tire out of balance due to the shake not happening all the time.
  6. Aug 19, 2017 at 11:53 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Stock size tire? Any wheel spacers? Stock wheels? Does it seem to go away in a freeway speed turn?
  7. Aug 19, 2017 at 11:55 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    This POP noise constant when shaking or makes the noise, then starts shaking? How many miles on front end components? Ball joints been replaced?
  8. Aug 19, 2017 at 12:07 PM
    Tim7902
    Tim
    Maryville, TN
    Stock rims and tire size. No lift or spacers. It does seem like it goes away in a turn. The pop noise isnt very consistent. It only seems to happen when im at 70 or above and i rarely get on a highway to get that fast. Shaking happens before the noise cause it starts around 55-60. I'm fairly certain no suspension parts have been replaced from the look of them. None look new. I've got right at 130,000 mile on the truck.
  9. Aug 19, 2017 at 12:33 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    You need to jack up by lower control arm and use a pry bar or 3ft 2x4 under tire and lift it up. That will check for lower ball joint play. A pair of channel locks and squeeze tierod end togeather for looseness. Same on upper ball joint.
  10. Aug 19, 2017 at 12:38 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Mine is doing the same thing in the corners. Balancing tires didn't help. My wheel bearings feel tight. I've eliminated or replaced everything but wheel bearings. I'm going to replace them next. 260k miles couldn't hurt.
    I put my chassis ears on the knuckles and drove at 70mph and listened for bearing noise. The right seemed aa touch louder then the left. But no unusual noises.
