Intermittent throttle loss
Discussion in '1st Gen. Tacomas (1995-2004)' started by REV04, Apr 18, 2016.
  1. Apr 18, 2016 at 8:28 AM
    REV04
    REV04 [OP] New Member
    Robin
    Occasional throttle lag in maintaining speeds, (when on off throttle coasting). Six months Mechanic trying to diagnose problems, only happened twice when he drove it. Changed all coils, spark plugs wires and fuel filter. 2004 Toyota Tacoma with 225207 miles on it.
    I've got a 2004 Toyota Tacoma with 2,248.00 miles. Six months ago it started small quick loses of power in the grass peddle. It doesn't happen often or regularly. In the 6 months it only happened twice for my Mechanic, his discription is "it feels like it's falling on its face".
    We first replaced fuel filter then he did tune up, all new coils and unrelated repairs. Water pump, hoses and belts.
    Timing bet done at 150,000 miles.
    I've read all related threads on this subject and found the sea foam to be my next try. But I can't find sea foam. Is it a boat related item?
    I also did the 100 peddle pump on the grass throttle.
    I'm at a loss here. I Love my Toyota and don't really want to sell it. I drive 80 miles a day and it is terrifying when I get a 3 second loss of power in the fast lane on the 417, people won't let you over.
    It's becoming deadly Dangerous.
    It's happening more frequently, just not when the Mechanic is testing it.
    Any help or suggestions would be greatly Appreciated.
    Thank you
  2. Jul 20, 2016 at 9:57 AM
    MartinDWhite
    MartinDWhite Well-Known Member
    Martin
    Greenville, SC
    2004 4-dr 4x4 Tacoma TRD
    Relentless front and rear bumpers, Warn M-8000S Winch, Relentless RockSliders, bigger tires, bed cover RTT ... and more big changes in the works.
    My 2004 v6 4x4 TRD double cab is starting to have the same issue and would love to know if you found anything.
    At first it happened at slow speeds and only soon after starting the truck. Once it happened at a faster speed I took it to the dealer. They said the MAF was reading 74 when it should be near 100, so it was replaced. This seemed to fix it for a week. It didn't happen at all. Now it has started again at slow speeds.
  3. Jul 20, 2016 at 11:54 AM
    eon_blue
    Azusa, CA
    Yeah, I was going to say you might want to give the mass air flow (MAF) sensor a good cleaning, maybe even your throttle body. Both are very easy to do on your own, be sure you use MAF sensor cleaner specifically (not electrical/carb cleaner). May even have to replace it, but start with cleaning it and see if that helps.
    Is your check engine light on?
  4. Jul 20, 2016 at 12:37 PM
    MartinDWhite
    Martin
    Greenville, SC
    The check engine light (CEL) is NOT on. Never has been while driving. It does come on during the light test before starting the engine so it does work.
  5. Jul 20, 2016 at 12:38 PM
    scootn2nature
    scootn2nature ttora member since 2001
    orinda
    2000 2.7l sr5
    bentup sliders, tjm t17, badland rear,custom leafsprings, fabtech performance co's,
    cat is begining to plug up
  6. Jul 20, 2016 at 12:42 PM
    MartinDWhite
    Martin
    Greenville, SC
    Is there any check for the CAT being plugged
  7. Jul 20, 2016 at 12:45 PM
    scootn2nature
    orinda
    2000 2.7l sr5
    If you have ever ridden a motor cycle and forget to turn the petcock on or run out of gas thats what it feels like then all of a sudden back to normal............. thats your cat plugging up assuming its not fuel related....
    I learned this the hard way since then I have saved people alot of headaches
  8. Jul 20, 2016 at 12:58 PM
    scootn2nature
    orinda
    2000 2.7l sr5
    take it off and see if you can see through it. depending on what you have I have cali 4cyl with two cats not a good idea to run with my front one disconected because there is only a manifold left besides the noise you dont want to suck in cold air or start scrubbing cyl. if its like mine I undid the pope behind the first one and shown a flashlight down the o2 sensor hole but that wont be nec just look at it if it doesnt look honeycomb any more its gonna be all melted and [lugged up. I have had two front ones go bad the rear one is still normal looking. its a gradual loss of power and fuel mileage too but so gradual hard to tell until it gets to the point of complete failure
  9. Jul 20, 2016 at 1:07 PM
    scootn2nature
    orinda
    2000 2.7l sr5
    I had to drill mine out the first time until toyota replaced the first one I got almost double the gas mileage but drove around with cat efficiency cel and a loss of torque
    fyi any car in usa 96 and newer is covered under FEDERAL MANDATE/LAW (doesnt matter on owner or title ) 8 years or 80k miles for any smog related part/ the dealer must replace for free and they hate that and dont offer it up either. If you dont know it they will normally charge you .
    greed is the scurge of man
    man is the scurge of earth
    I wrote that
    Scott
    Spillman
  10. Jul 20, 2016 at 1:10 PM
    MartinDWhite
    Martin
    Greenville, SC
    I will check the CAT tonight. There has been a drop in mileage, the truck is down to about 15.5 average with half city, half highway.
    This truck has a few miles on it, about 175,000 miles.
  11. Jul 20, 2016 at 1:20 PM
    scootn2nature
    orinda
    2000 2.7l sr5
    good luck get the gaskets soak the bolts........the best is acetone and tranny fluid mix somewhere on here there is a great write up on that . i wish I knew 30 uears ago
  12. Jul 20, 2016 at 1:28 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    It's the Throttle Position Sensor and it is a well known problem. My 04 does the exact same as yours. At 2000-2500 rpm the engine just loses power for no reason. I have taken mine off and checked it with a multimeter and sure enough when twisting going from stop to stop the meter reads OL ( Off Line ) in one spot meaning the contacts are losing contact. When the ECM sees this OL it assumes that the driver is letting off of the gas. The sad thing is Toyota doesn't sell the TPS sensor separately neither does any parts distributor. Toyota wants you to buy the complete throttle body. Now.....You can get the sensor from china. Alibaba has them, but you have to buy multiple sensors to get one. I have been trying for the last week or so to buy 5 of them. I have seriously gotten the run-around.
    Here is the part# 89452-35030.
    It is the part number for the 4 prong TPS sensor that is for the drive by wire motors. The 3 prong sensors will not work.
    mechanicjon and ThunderOne like this.
  13. Jul 21, 2016 at 7:09 AM
    MartinDWhite
    Martin
    Greenville, SC
  14. Jul 21, 2016 at 1:10 PM
    chrisjul
    chrisjul Member
    Have you changed your fuel filter?
  15. Jul 21, 2016 at 5:43 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Seafoam is pretty easy to find, its not a marine product. It'll be at most any parts store like napa or what ever youve got in your area. It would definitely be worth a try fur ya at this point...
  16. Jul 25, 2016 at 7:39 AM
    MartinDWhite
    Martin
    Greenville, SC
    I swapped the fuel filter and front CAT this weekend and the hesitation issue appears to have gone away, and there feels like for power. Swapping the CAT was a bear. Snapped off one bolt and rounded off one nut. Two other bolts were too rusted to even try and use a wrench on. A Dremel with flexible lead and cutoff wheel cut the bolts and a long drill bit drilled them out.
  17. Jul 25, 2016 at 7:49 AM
    Nighthawk
    Nighthawk 'streme spoats
    Levi
    Casper Wyoming
    2008 Red TRD OR AC V6
    Bilstein 5100's w/ Eibach coil overs in front (set at 3" of lift). Front diff drop kit. Extended Bilstein 5100's in the rear. Deaver 2" AAL in rear w/ axle shims. 285 x 75 r 16 Goodyear Duratracks. Wheelers steelies type B, AFE cold air intake. Sway bar delete. All Pro Apex front bumper (rattle canned Rustoleum primer + flat black). Plasti-dipped emblems. Mud flaps removed.
    I think I found the problem....
  18. Dec 31, 2016 at 10:50 PM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
