Intermittent Trouble Starting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jcarr, May 31, 2012.
  1. May 31, 2012 at 4:08 PM
    jcarr
    jcarr [OP] New Member
    Central Illinois
    07 Tacoma 4x4
    I have a 2007 Tacoma Access cab 4x4 V6 with just over 60K. The last couple of days I have had 2 occassions wher the truck will just click then have trouble turning over. Eventually both times it started after 5-6 consecutive attempts to turn the key. My battery is not very old and no CEL. Other times it has fired right up. Anybody else experience this? Any ideas what to look into?
    Thanks
    Justin
  2. May 31, 2012 at 4:11 PM
    ajwhlr04
    ajwhlr04 Well-Known Member
    Aaron
    Woodland Hills, CA
    2007 Tacoma 4x4 Double Cab 6MT
    I would have the battery checked at autozone or somewhere that checks it for free. Even though it's not very old, I've heard that batteries sometimes sit on shelves in the store for a long time.
    If not the battery, I guess the starter could be giving up.
    Good luck!
  3. May 31, 2012 at 4:51 PM
    Ga tacoguy
    Ga tacoguy Well-Known Member
    Rudy
    Augusta Ga.
    Extended cab Base model 4 cyl
    Tailgate mod, horn mod,storage door mod
    :) WELCOME TO THE FORUM.
    From your description, it sounds like your starter solenoid is going out. When your engine doesn't crank, does the starter sound like it is spinning but not turning over the motor ? If it is, you may have some bad spots on your starter ring on your flywheel. Check the wires by the starter solenoid and see is any are loose or bare. This is where your problems are . Good Luck.
  4. May 31, 2012 at 5:18 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    It could just be a loose / dirty connection on the battery or starter solenoid. Always start with the simple / cheap and work towards the complex / expensive when troubleshooting. 90% of the time it is something simple and not a starter or solenoid.
  5. May 31, 2012 at 5:26 PM
    whopper
    whopper 2016 MGM 4x4 double cab
    wayne
    north carolina
    2016 tacoma double cab 4x4 MGM
    On going
    could be the starter contacts there brass and do wear out i had to have my contacts replaced at 44000
  6. May 31, 2012 at 7:31 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    03 F250 CCSB
    Gibson stainless headers, custom free-flow Y-pipe, Magnaflow muffler, 285/75R16 KBro2's
    X2 Disconnect your battery terminals, clean the battery posts and the terminals, then tighten back down. I can't tell you how many times this has been the problem when I've worked on a car that had intermittent starting issues.
  7. Jun 1, 2012 at 5:46 AM
    jcarr
    Central Illinois
    07 Tacoma 4x4
    Took it by the parts store last night and battery was only half the rated cranking amps. They replaced the battery and it seems to be ok so far.
    Thanks for all of your responses.
    Justin
