Intermittent Vibration?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ramphonic, Feb 25, 2011.
  1. Feb 25, 2011 at 7:01 PM
    Ramphonic
    Ramphonic [OP] Well-Known Member
    Cape Cod
    2k1 SR5 4x4 V6
    Adjustable Bilstein, AAL Lift, Eagle Rims with BFG ATs, Trd Exhaust, Clear Corners, Red Clear Tails
    I am bashing my head in trying to figure out this vibration. It is at higher speeds (from 45 to 70+) but off and on.. Almost like the road surface makes it better or worse.
    This was worse when I had my old tires and wheels. I bought brand new BFG Ats and eagle rims.. Lifted it with bilstein 5100s and a AAL.. It was good for a while. Then I got my new frame.. It was still fine for a while. Then all of a sudden..
    Thought it was balance but Ive had them rebalanced 2 different places several times.. Checked for out of round.. Nothing... Had the front end checked for wear.. Nothing.. Bought new rack bushings... Nothing.. Someone said it could be internal in the rack? I have new inner and outer tie rods..
    My other issue is that the slip shaft in the steering column has some play as they all do..
    So sorry for the story.. any ideas??
  2. Feb 25, 2011 at 8:30 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Does the frame replacement have a warrantee (the labor) ?
    In other words.... If it does (labor) - take it back and have Toyota check everything to make sure nothings came loose.
  3. Feb 25, 2011 at 8:34 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    where do you feel the vibration more......thru the steering wheel....or thru the floor board? does it feel like its in the front or the back?
  4. Feb 25, 2011 at 8:37 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    I assume you got it aligned correct? Ucas may help
  5. Feb 25, 2011 at 8:40 PM
    mikracer
    mikracer Well-Known Member
    San Luis Obispo, CA
    2009 DCSB | TRD Sport 4x4
    Does it do it when its in 4wd? If it goes away in 4wd, then its a bearing in your front diff. Theres a couple threads on it on the 1st gen and 2nd gen forums. Next time you go for a drive, put it in 4wd and see if you can reproduce the vibrations.
  6. Feb 26, 2011 at 3:39 AM
    Ramphonic
    Cape Cod
    2k1 SR5 4x4 V6
    Did that last summer after I had a clunk when I made sharp turns. One of the alignment adjustments took a 1/4 turn.
    Noise went away
    You can feel and see it in the wheel
    Yes its been aligned several times since.. Upper control arms ever though it was fine when the lift was put in?
    not sure if it does it in 4wd... I have only used the 4wd maybe up to 40mph max.. I avoid highways because of all this..
  7. Feb 26, 2011 at 3:43 AM
    bivey
    bivey Well-Known Member
    Might want to check all of your ujoints on the driveshafts for any kind of play.
  8. Feb 26, 2011 at 3:48 AM
    Ramphonic
    Cape Cod
    2k1 SR5 4x4 V6
    did that
  9. Feb 26, 2011 at 6:19 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    May actually need to get the tires road force balanced......its possible one may be out of round.
  10. Feb 26, 2011 at 6:21 AM
    Ramphonic
    Cape Cod
    2k1 SR5 4x4 V6
    I brought it to Townfair Tire and they roadforce balanced them.. Said nothing was out of round and they actually eliminated alot of the weights
  11. Feb 26, 2011 at 7:38 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    Well....if you have any lift.........could be the cv angle.
  12. Mar 2, 2011 at 5:15 PM
    Ramphonic
    Cape Cod
    2k1 SR5 4x4 V6
    Whats weird is it did it before the lift..
    Would the play in the steering make it seem better or worse?? I am trying to find the preload adjustments for the rack itself.
  13. Mar 2, 2011 at 5:27 PM
    ywen
    ywen Well-Known Member
    once again, does the vibration go away when you put it into 4wd?
  14. Mar 2, 2011 at 5:27 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    i have the exact same issue........:popcorn:
  15. Mar 2, 2011 at 5:28 PM
    Ramphonic
    Cape Cod
    2k1 SR5 4x4 V6
    I dont feel right using 4wd at highway speeds on dry pavement
  16. Mar 2, 2011 at 5:33 PM
    ywen
    I thought you said from 45-70? should be okay if you do it for a few seconds on a straight road. If the vibration goes away, then you'll know it's a front diff issue. The effect is immediate.
    If it goes away in 4hi, then join the club over here.. http://www.tacomaworld.com/forum/2n...unk-found-questions-about-front-diff-now.html Fun stuff! this truck blows!
  17. Mar 2, 2011 at 5:34 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    not recomened.....
    NOT MY DIFF......
    but i have the exact same issue.....
  18. Mar 2, 2011 at 5:35 PM
    ywen
    Trust me.. these drivelines aren't that delicate where you can't do a couple of seconds in 4wd on dry pavement in a straight line..
  19. Mar 2, 2011 at 5:39 PM
    Ramphonic
    Cape Cod
    2k1 SR5 4x4 V6
    I will try it when the highway is wet..
  20. Mar 8, 2011 at 4:23 PM
    Ramphonic
    Cape Cod
    2k1 SR5 4x4 V6
    Does the same thing in 4wd
