Intermittent Wiper Switch update
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nitro52, Jan 13, 2012.
  1. Jan 28, 2014 at 11:58 AM
    #41
    chapman311
    chapman311 New Member
    '14 Tacoma 4x4
  2. Jan 29, 2014 at 2:21 AM
    #42
    ZEROPILOT
    ZEROPILOT Can't re-MEMBER
    ED
    SUNRISE,FLORIDA
    09 2.7 XTRA CAB 5 SPEED
    LARGER WHEELS. DIFFERENT STEREO. PUSH BAR. TAILGATE EXTENDER. WIPER MOD. TPMS LIGHT DELETE MOD.
    Thanks for the info!! No delay has been a real pain! You only have to change this switch? Same relay and everything? Plug and play? WOW.
  3. Jan 29, 2014 at 5:29 AM
    #43
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    I think this was the first mod I completed. I was new to Toyota and did not understand how to take the steering column shroud off. I thought I was going to break the plastic.
  4. Jan 29, 2014 at 6:44 AM
    #44
    GreatCanadian
    GreatCanadian Well-Known Member
    Newfoundland
    SR5 4X4 V6
    If you read the brochure CLOSELY you will see they have themselves somewhat protected there (at least in the Canadian brochure). It states that the brochure may not be accurate and to check the website for the latest updates. My brochure did not match my truck, but the website did. Good for you for gettting a few hundred dollars back, as Toyota did not have to do that IF they're website was up to date.
  5. Jan 29, 2014 at 11:58 AM
    #45
    ZEROPILOT
    ED
    SUNRISE,FLORIDA
    I just ordered the switch. I see two Phillips screws behind the steering wheel. Does the plastic column cover snap off? Is that all?
  6. Jan 29, 2014 at 12:08 PM
    #46
    Frobozz
    Frobozz Well-Known Member
    North of Ordinary
    15 TRD/OR Access Blue Ribbon Metallic
    Tonneau, Canoe Rack
    To anyone purchasing a new or used Tacoma, I recommend you make this mod part of the purchase negotiation. As part of my recent 2014 purchase, I added the requirement that they swap stems to give me the intermittents. Works great!
    As an aside, in this day and age, I am a bit surprised Toyota doesn't just include it as part of the standard package as they seem to have done with cruise and AC.
  7. Jan 29, 2014 at 12:59 PM
    #47
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    Correct
  8. Jan 29, 2014 at 4:03 PM
    #48
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Agreed. You can spend $13k on a new Yaris that has a 3-speed wiper standard. But all base Tacos, $19K+ come with only a 2-speed wiper. At the very least, offer the Yaris's 3-speed switch (it fits just fine). The fixed int would be better than nothing. And don't get me started about the lack of a cargo light, locking fuel door or front mudguards (for the base).
  9. Jan 29, 2014 at 6:53 PM
    #49
    cholland
    cholland Active Member
    California
    13 Access cab 4x V6 manual
    ZEROPILOT: yeah it just snaps off once the screws are out.
    If you pull the streering column adjuster and drop the streering wheel it makes it a little easier to mess with. I used a butter knife to gentry pry the front open. A putty knife might work too. Something you can get wedged in there a bit and not muck up the plastic. I got a flashlight and looked for the back clips... I was able to barely reach in with my fingers and release them.
    I seem to remember another thread on here where someone took some pictures.
    Actually changing the switch is the easiest part. It took me twice as long to get it snapped back together. Had a hard time lining up the little alignment pegs at the front so it would snap together clean.
    Now if it would just rain, I would actually get to use them.
  10. Jan 30, 2014 at 1:29 AM
    #50
    ZEROPILOT
    ED
    SUNRISE,FLORIDA
    THANK YOU.
  11. Feb 24, 2014 at 9:49 PM
    #51
    20Taco14
    20Taco14 New Member
    BC
    '14 Base 4x4
    I picked up my new Tacoma last week. Intermittent wipers were a must! This was my first mod so far. I should have had the dealer include as part of purchase but forgot with all the excitement.
    I picked up the intermittent wiper switch from a local wrecker for $60. Toyota people want $240 for this locally with 4 different part #'s to choose from.
    Warning to all: First I tried a wiper switch out of a 2011 trd and the thing gave me 3 slow constant wiper speeds and one fast. I couldn't even turn the thing off! Next I tried one out of a 2007 trd and the thing works perfect.
    Really happy with the buy but beware they are not all the same.
    Took me about ten minutes. Easy job but definitely finicky with all the flimsy plastic to take apart without damaging.
  12. Feb 25, 2014 at 1:47 AM
    #52
    ZEROPILOT
    ED
    SUNRISE,FLORIDA
    The switch kind of snaps in, cassette style. No bolts, just plastic clips. I used the part number ending in 10. It operates in the normal fashion and has like four intermittent speeds. The part number ending in 43, I hear, operates in reverse. That is, it switches backwards. Still will work.
  13. May 16, 2014 at 2:20 PM
    #53
    jbcanes
    jbcanes Well-Known Member
    Justin
    Tampa, FL
    14 PreRunner double cab
    backup camera, intermittent wiper, step bars, bug deflector, window vent, console vault,solid fold 2.0, 2016 sport wheels, front camera, anytime rear front camera mod, homelink mirror, dash cam, unifilter,
    #53
  14. May 31, 2014 at 11:45 AM
    #54
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    "FINALLY" I got around to installing the delay wiper stalk on my 2012. This was easy as pie and, as stated, did not take me ore that 10 minutes. the hardest part is just getting the top and bottom covers apart and back in and together. IT just takes a little fidgeting. I've had my new stalk for a while just never got to putting it in. Works Great ! Let it Rain!!! (Also put in a Curt hitch and wiring harness so I can finally go looking for a used pontoon boat).
    Thanks to all who did the pics, previous work, part number infos and encouragement!!
    Canufixit
  15. Jul 16, 2014 at 3:48 PM
    #55
    Chief Ten Bears
    Chief Ten Bears Member
    Southern Maryland
    2013 4x4 Stock regular cab
    I just did my 2013 regular cab 4x4. Like most of the others have posted, its pretty easy. My only issue was getting the little tab pushed in far enough to release the old unit. I couldn't get a screwdriver to go in at the right angle. I finally used an allen key (bent at a 90 degree angle) to depress the tab and popped it loose.
    I used part #84652-02710 and it works great. I swear, with the old unit, on the high speed setting I thought the blades were going to fly off the arm! Absolutely worth the $100 bucks.
  16. Aug 11, 2014 at 9:20 PM
    #56
    Outbound
    Outbound Well-Known Member
    double cab short box
    I just did my 2013 DCSB this afternoon. Took less than 10 minutes. Literally, plug and play. There are two different choices for the switch -02610 and -02710. The only difference is whether it has arrows to indicated the different settings or letters (-IMP, etc). the -02710 is for 2014 and on. I went with the -02610 as it matches the not intermittent version that came stock on my Taco and I kinda just liked the look better. Really simple to do.
  17. Aug 12, 2014 at 4:38 AM
    #57
    reg boulette
    reg boulette Well-Known Member
    Ridiculous that you spend this much on a vehicle to find it lacks common features available since the 1980's.
  18. Aug 19, 2014 at 10:06 PM
    #58
    Outbound
    Yes but how else would they get you to buy the SR5...
  19. Aug 19, 2014 at 10:22 PM
    #59
    SWOreBowHunter
    SWOreBowHunter Well-Known Member
    Oregon
    '14 AC 4x4
    Front: 5100s and 884x Rear: Dakars and OME Nitrochargers
    They could put a locking rear diff in it. I would've shelled out the extra $1500 for that.
  20. Sep 29, 2014 at 8:07 PM
    #60
    MooreG
    MooreG New Member
    15 Tacoma 4x4
    Just bought a 2015 DCSB 4x4, and didn't notice that it didn't have intermittent wipers. Can anyone here confirm if any of the previous mentioned switches will work with this model?
