Intermittent Wiper Switch update
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nitro52, Jan 13, 2012.
  1. Oct 8, 2014 at 2:16 PM
    #61
    mikeflys1
    mikeflys1 New Member
    CT
    '15 Taco
  2. Oct 9, 2014 at 6:54 PM
    #62
    MooreG
    MooreG New Member
    15 Tacoma 4x4
    Thanks. I took a chance and ordered that same part number before I was able to read your post. It works like it should. Thanks for the help! Now I am working on the fog lights. Didn't come with them so I am hoping that these will be just as easy.
  3. Dec 23, 2014 at 1:31 PM
    #63
    Clearwater Bill
    Billy
    Largo Florida
    Just thought I'd add some more info (and ask a question or two).
    I recently acquired a switch from a 2014 Camry, as it was suggested to me that 07+ Camry switches should PnP for my '13 base.
    1) I disassembled, and before installing the switch, plugged in harnesses to test. Both plugs fit just right.
    2) the wiper side (4 wire/pin side) worked fine. High/low/intermittent/mist
    3) the washer side (2 wire/pin side) didn't work at all. Further examination showed that the pins in the new part didn't go in the same place wires were in for the plug. (so of course it didn't work)
    4) connected jumpers from the plug to the new switch washer side, now everything works.
    5) decide I'd try removing the wires/pins from the plug, reinstall them in the position to match the new switch. But that's not always easy, and especially working with a short wire up under the steering wheel.
    6) before starting that, I decided to try a trial fit of the switch itself into the combination block. Whoa! No fit! Way too 'thick' to clear the ignition switch.
    7) Just glancing at it, the switch has the right general shape. But the snap lock is different, thickness is different and a couple other dimensions are too.
    So, assuming the piece I got was exactly as described (and I have no reason to doubt), apparently the unit from a '12/'13/'14 Camry will not work. This was labeled as being from a '14 w/26k miles, and it was pristine.
    Thus the question is, for those who have used Camry/Corolla switches, which year models are the ones that DO work?
    Lastly, does anyone need a combination switch from a '14 Camry? The turn/light switch is included, as is the column mount :D
  4. Dec 23, 2014 at 7:12 PM
    #64
    macknepa
    macknepa Active Member
    NE PA
    2017 DCOR Manual
    09-13 Corolla and 07-11 Camry should fit. Have a 10 Corolla switch in mine. Works perfect.
  5. Jan 11, 2015 at 3:07 PM
    #65
    FDSender
    FDSender Member
    Brad
    Baltimore, MD
    10 Tacoma Reg Cab 4X4
    Have looked at several different places for this part and it seems to run around $100. Anyone find it cheaper?
  6. Jan 11, 2015 at 3:43 PM
    #66
    jbcanes
    jbcanes Well-Known Member
    Justin
    Tampa, FL
    14 PreRunner double cab
    backup camera, intermittent wiper, step bars, bug deflector, window vent, console vault,solid fold 2.0, 2016 sport wheels, front camera, anytime rear front camera mod, homelink mirror, dash cam, unifilter,
    I got a used one on eBay for 65
    #66
  7. Jan 14, 2015 at 8:04 AM
    #67
    Yasren
    Yasren New Member
    North Carolina
    2014 4dr 4wd
    I found a switch on ebay, called the toyota parts department to make sure it was what it said it was. While talking to the parts person, she put me on hold and talked to her shop forman. He told her i might need to replace the motor and the body computer in addition to this switch to have intermittent wipers. Is this indeed the case? I have a 2014 4 dr model
    #67
  8. Jan 14, 2015 at 10:00 AM
    #68
    Clearwater Bill
    Billy
    Largo Florida
    Another steaming pile of catalog jockey ignorance.
    If you'll read through this thread you'll find several '14s that have made the switch.
  9. Jan 14, 2015 at 10:34 AM
    #69
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    they told me the entire truck would have to be re-wired lol
    just install the switch. will take you roughly 15 minutes. which includes retrieving your screw driver.
    #69
  10. Jan 15, 2015 at 6:22 AM
    #70
    Hilltowner
    Hilltowner Member
    New England
    Tacoma Access Cab 4x4
    What nonsense - I have a 2014...dealers...that's why I buy (even new) and service at non-dealers...
  11. Jan 16, 2015 at 7:09 AM
    #71
    FDSender
    FDSender Member
    Brad
    Baltimore, MD
    Did the mod yesterday...took 15 minutes! I used part#8465204141.
  12. Feb 2, 2015 at 3:09 PM
    #72
    jibski
    jibski Well-Known Member
    Josh
    Arvada, CO
    2009 Silver 2.7 AC 4X4
    #72
  13. Mar 22, 2015 at 9:04 AM
    #73
    albullock001
    albullock001 New Member
    Al
    New Orleans
    2011 Prerunner
    where is the switch? on the column? or - underneath the dashboard?
  14. Mar 29, 2015 at 6:32 PM
    #74
    ChetSt3dman
    ChetSt3dman Member
    nj
    '15 Prerunner DCSB
  15. Nov 9, 2015 at 8:49 AM
    #75
    Tacoroamer
    Tacoroamer Active Member
    Atlanta
    06 Access Cab
    camper top
  16. Nov 10, 2015 at 4:23 PM
    #76
    Tacoroamer
    Atlanta
    06 Access Cab
    camper top
    I went to the local south Atlanta Toyota dealer, gave them my VIN and told them I wanted the variable mist speed lever. They came up with a part number 84652-04131 so I ordered it but when I got home I checked it out online and that is the stock part that comes on the Tacomas, without the variable speed mist control. I called and got it changed to 86452-04141. $127. I will pick it up this week, IF they get me the right one.
  17. Nov 10, 2015 at 5:02 PM
    #77
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    i have a new 2015 base acc cab 4x4. power door locks, nice high tech "head unit", steering wheel controls. it even has a remote key fob. i love my new truck. drove it a few days, and then it started to rain. i turned on the wipers,they worked great, hey brand new truck. the rain slowed to a mist, went to switch to intermitteint, WTF!!!!! you gotta be kidding me. i'm going to have to do this mod. i'm still pissed, over 25000.00 truck. my wife's cheap ass ford has intermittent wipers.
  18. Nov 10, 2015 at 7:29 PM
    #78
    R.T.
    R.T. Active Member
    2021, TRD Sport, DCSB, Magnetic Gray Metallic
    Wiper Switch, Cruise Control, Back-up Camera and Locking Tailgate were the first mods I made. All pretty much plug & play on my 2015 AC Base.
  19. Nov 10, 2015 at 7:42 PM
    #79
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    That is exactly my list of first mods on my 15 AC base. I did the hose clamp and washers on the tailgate though, not the pop n lock. Thought about fog lights but they aren't pre wired on mine and I don't want them badly enough to run wires. Are you planning on doing any more relatively easy power options?
  20. Nov 12, 2015 at 5:53 PM
    #80
    R.T.
    R.T. Active Member
    No more mods on the horizon. I too considered fog lights but just as you found, I'm not pre-wired. If I was going to bother with wiring lights I would probably go with LEDs in the grill. If it had been pre-wired I'd put in factory fogs. No power mods for me. IMHO most attempts to get more power from these 4 cyl just act to lighten your wallet (of course lighter is faster). I find the 2.7L to have plenty of torque for the truck's size and weight. Recently took the truck on a trip to the Blue Ridge Mountains, even spent some time on a pretty rough/steep Forest Service Service Road, and it never struggled. I was pleasantly surprised.
    Of the mods I completed, Cruise Control was the cheapest, camera/lock combo most expensive, all of them were easy. It took about an hour combined with the camera/lock taking the longest.
