Intermittent wiper switch works backwards ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 4BIT, Sep 21, 2012.
  1. Sep 21, 2012 at 6:26 AM
    4BIT
    4BIT [OP] Member
    Jim
    Ontario, CANADA
    2010 Double Cab TRD
    Ok, I freely admit up front that I may be losing my mind...
    My Tacoma intermittent wiper switch has the "wider band" icon at the top and narrows to the point at the bottom. But my wiper delay is fast when set at the top and longer delay when turned to the bottom.
    I own a Camry with the same set up and it works as normal "wide band" at top means long delay, "short band" at bottom means minimum delay.
    Am I losing my mind ?
  2. Sep 21, 2012 at 6:28 AM
    ouyin2000
    ouyin2000 Well-Known Member
    Nova Scotia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    As you rotate the dial away from you, the wiper delay gets shorter and shorter. Or the wipers move faster, same thing.
  3. Sep 21, 2012 at 6:32 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    it changed sometime between 07 and 09. i had an 07 and it was right, got the 09 and it's backwards...weird.
