Intermittent wipers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dewey7015, Jan 22, 2011.
  1. May 3, 2012 at 6:03 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Otherwise known as "mist/2fast/way2fuckingfast"
    Bobsgym and BassAckwards like this.
  2. May 4, 2012 at 3:34 AM
    Dewey7015
    Dewey7015 [OP] Well-Known Member
    Massachusetts, USA
    2018 TRD sport
    Anyone found anything that fits from other years/models?
    Thought I saw somewhere that a stalk from A solara fit?
  3. May 4, 2012 at 4:16 AM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2025 Underground SR5 RWD Double Cab
    Clazzio seat covers,
    To determine if one wiper stock fits different models, get the stock number for the Tacoma and go to different models (year,make,model) and see if the number matches.
    I am sure ... although if I am wrong I am sure that someone will point it out :cool: ... that Toyota does not waste their time assigning different stock numbers for the same interchangeable part ... just a suggestion.
    I guess I am of the opinion that a little effort and research goes a long way ...
  4. May 4, 2012 at 6:26 AM
    Dewey7015
    Massachusetts, USA
    2018 TRD sport
    just asking...
    thought the reason for forums is for people to share info..
    I will do the research, thanks.
    should I start a thread on what size tire fits my truck?:)
  5. May 4, 2012 at 7:02 AM
    jpmorrisvb
    Jimmy
    Virginia Beach
    Dewey, Dewey, Dewey ... too funny ... but that tire thread sounds like a great idea. :cool:
  6. May 4, 2012 at 7:41 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Just a guess that all of the wiper stalks are compatible.
    Why would Toyota make different parts when they don't need to?
    The only difference that I've seen reported is that on some, turning the knob "up" may either increase or decrease the delay.
    On mine, with the knob turned "up" to the "widest" white stripe, my delay is the longest.
    Whether this is the result of people ordering alternate part number or what, I don't know.
    But really... why dick around unless you're talking about yanking one from a junk yard?
    If it's a junk yard part, it's going to be cheap enough to make a mistake (it'll either fit or not fit, it won't fuck the truck up).
    If ordering new, just order the right one....
    Taco-Jones likes this.
  7. May 5, 2012 at 7:27 PM
    Dewey7015
    Massachusetts, USA
    2018 TRD sport
    I'm dicking around because if I just order a new one, it's $114.00.
    So when I read a post on here saying for $26 bucks a 2006 solara stalk fit, and he got it on eBay, I am interested.
    To me, modding isn't just ordering. That's part of it, but most of my mods are frankenstein nature..
    That's why I'm asking.
  8. May 5, 2012 at 9:07 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    And like I said... ya, if you're getting a "junkyard" part or a pull from another Toyota, then ya, it's worth it if it'll work.
    I suspect it will... been reading that they are compatible, but I don't have anything solid to back that with.
    Personally, for $26, I'd buy it and if it didn't fit, I'd sell it for $50 on SolaraWorld.
  9. May 20, 2012 at 6:40 AM
    darrylt
    darrylt Active Member
    Darryl
    Chesapeake, Va
    12 PreRunner
    Just bought a 2012. No intermittent wipers. Was a surprise, not something I thought to check.
  10. May 21, 2012 at 7:08 PM
    Ebby1600
    Ebby1600 Member
    Ebby
    Planet Earth
    2012 Black Regular Cab 4x4 AT
    Rubber floor mats...lol Intermittent wipers
    I have a 2012 Regular cab made in Texas. Interval wiper stalk and 20 minutes and your in business. Search 2nd gen forum for instructions.
  11. May 22, 2012 at 5:43 AM
    darrylt
    Darryl
    Chesapeake, Va
    12 PreRunner
    Where did you get the part? Cost?
  12. May 22, 2012 at 7:20 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Read Roland's post and quote above.
    Part number and source are given.
  13. Jun 14, 2012 at 3:20 PM
    Hot2na
    Hot2na Well-Known Member
    Anyone try and order a 2012 intermittent stalk?
  14. Jun 14, 2012 at 4:35 PM
    PaintDrinkingPete
    PaintDrinkingPete Well-Known Member
    NoVA
    2012 4x4 TRD Sport DCSB
    I'm kinda glad you mentioned that. I traded in a 2005 Tacoma for my current 2012, and the first time I drove in the rain I could have sworn it was the opposite from what it had been on my previous truck...but also figured I could just be going crazy! :cool: On my 2005, I'm pretty sure the "widest" stripe was the fastest setting.
  15. Aug 8, 2012 at 8:34 AM
    #35
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    Thanks for this thread guys, especially the Picaso photos in Rolands album, i was able to know exactly where i needed to push the trim. The exchange took all but 20 minutes. i left the truck running for trim removal so i could swing the wheel. the top pieces pulled right apart and squeezed back together with no problem based on the photos above of knowing where to push. Thanks Roland.
    I installed the later part number in my 2012
    wiper switch 84652-02610
    the top thick dashed line is the most frequent wipe, with the lower thin section being the most delayed. you can call it a mind game, "thin part for least rain"? lol idc as long as it works :)
    also, it wipes when you rinse the windscreen too. so now i can mist like a human being instead of some thug having to manually select to wipe off the fluid.
    im very relived that this mod was plug and play. because the prior set up is absolute utter BS. i never even thought to check for it when i purchased the truck.
  16. Aug 8, 2012 at 8:54 AM
    #36
    Beefed Taco
    Beefed Taco Taco Vending Machine
    Brian
    My Metal Shop
    99 Taco
    streetacos.com parts!
    I have one of these plug and play for a 1st gen Taco. It's on my website for anyone interested. 15 minutes and you'll have intermittent wipers. If interested, click my sig and go into my store. :thumbsup:
  17. Aug 9, 2012 at 10:34 AM
    #37
    Greenbean
    Greenbean B.S. Goodwrench
    Zack
    Western NC
    2015 AC 2.7L 5-spd 4x4 Utility Package
    I am wondering the same thing???
  18. Aug 9, 2012 at 11:21 AM
    #38
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    One stick skinny means less rain, on the other it means wiping less often.
    One stick fat means more rain, on the other it means wiping more often.
    Yes, mind game usually from brand to brand but now year to year within same gens. Stupid.
  19. Aug 10, 2012 at 4:06 AM
    #39
    Hot2na
    in answer to my own question : I just ordered and rec'd a 2012 stalk...took alot longer to get...I'll post results whenever I get around to swapping it out...
  20. Aug 10, 2012 at 4:12 AM
    #40
    Greenbean
    Zack
    Western NC
    Cool, I'll be patiently waiting my friend,
