Intermittent wipers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dewey7015, Jan 22, 2011.
  1. Aug 25, 2012 at 10:55 AM
    #61
    Greenbean
    Greenbean B.S. Goodwrench
    Zack
    Western NC
    2015 AC 2.7L 5-spd 4x4 Utility Package
    I thought that was the second half of the number, I was using the numbers from the previous post...
    84652-04141 2005 - 08 Tacoma
    84652-02610 2009 - 11 Tacoma
    84652-02710 2012 - ? Tacoma
    Either way, I'll just get a 2012 wiper stalk and just use it, rained again on the way to work and I really would have liked them... Argh! :mad:
  2. Aug 25, 2012 at 11:13 AM
    #62
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Oops... Ya, you're right.
    As mentioned, and I'm as OCD as anyone, you'll get used to the direction of the knob.
    Regardless of the graphic (which you can't see because the wheel blocks it), you get used to either "turning up" the delay, or "turning up" the wiper frequency.
  3. Aug 25, 2012 at 11:15 AM
    #63
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    +1
  4. Aug 26, 2012 at 6:46 AM
    #64
    Dcd5907
    Dcd5907 Well-Known Member
    Anthony
    Southern NY
    '11 Tacoma AC V6 4x4 MT
    Fog install, tinted, de-badged, relentless skids, beefed sliders, CBI spare tire carier, SCS F5's, color matched grill, GY Duratrac's,
  5. Sep 4, 2012 at 2:33 PM
    #65
    MikeCB600F
    MikeCB600F 4 Cylenders of angry fury
    Plainfield, IL.
    2012 Reg Cab 2.7L 4x4
    Extang Trifecta Tonneau cover
    Installed the intermittent wiper stalk today.
    Pics when photobucket is not down for maintenance.
  6. Sep 4, 2012 at 3:13 PM
    #66
    Greenbean
    Zack
    Western NC
    :thumbsup:
  7. Sep 5, 2012 at 4:18 PM
    #67
    Genobrew
    Genobrew Member
    Gene
    12 PreRunner
    All this talk about intermittent wipers working in reverse, unreal. I am a limo driver and today I drove a Caddy and a Lincoln and it was raining. They work the same as my 2012 Tacoma with the upgrade. The small short line is the slow position and the big fat line is the fast position. Turn toward driver for slow position and turn forward to speed up. Unbelievable!
  8. Sep 5, 2012 at 4:34 PM
    #68
    B737
    Kevin
    Jersey Shore
    stock
    i agree, i believe the new tacoma's are supposed to be that way. for some reason people are calling it 'reversed' when its actually been changed by toyota themselves.
  9. Sep 5, 2012 at 7:03 PM
    #69
    Rich91710
    Rich
    Los Angeles
    08 Base
    My '08 with the part number indicated above (84652-04141) is the opposite.
    Wide line = longer delay.
    But it's natural... Pop the stalk down to INT, turn the control "down" to go faster, then when it bottoms out, pull the stalk "down" to the first speed.
    I'll double check tomorrow, but I'm pretty sure that's how it worked last week.
  10. Sep 6, 2012 at 3:13 PM
    #70
    MikeCB600F
    Plainfield, IL.
    Couple pictures of install
    New wiper stalk
    Two plugs at bottom and tab to press to remove
    Installed
    The picture shows the intermittent knob at the fastest delay
    The wiper stalk has the right side mounting hole for the screw that holds the plastic on the column. When you tighten the screw, it is a little harder to tighten than the left screw because you are cutting new theads. Also the plastic has 1/8 inch high dowel pins, so be careful when putting the plastic back together.
    After squirting the windshield, the wipers do two swipes:)
    Beats having to turn on the wipers after squirting the windshield.
  11. Sep 6, 2012 at 7:22 PM
    #71
    Greenbean
    Zack
    Western NC
    That's it, I am buying my wiper switch tomorrow!!!
  12. Sep 7, 2012 at 3:00 AM
    #72
    MikeCB600F
    Plainfield, IL.
    What a difference the intermittent wipers make. I was done in about 15 minutes while snapping a couple pics along the way. The hardest part was trying to get the plastic to pop off. The left side popped off in a couple seconds, but the right side would not pop. I had to find a skinny flat blade screwdriver to slide between the piece to push the tab back.
  13. Sep 9, 2012 at 7:05 PM
    #73
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Thanks Mike !! I have the same taco as you and ordered the same switch you recommended / source. I really miss the intermittent wipers and your (and everyone's!) Help here make it sound like a real no brainer !!!
    Thanks to All!
    I'll advise on the eventual results .....
  14. Sep 10, 2012 at 9:00 PM
    #74
    Rich91710
    Rich
    Los Angeles
    08 Base
    Had the opportunity to confirm (and remembered to mentally note) that the above is correct.
    Knob turned all the way down to the narrow line is the shortest delay... 2 seconds or so between swipes.
    All the way up at the wide line is the longest delay... 10-12 seconds.
  15. Oct 6, 2012 at 10:37 PM
    #75
    azonicbruce
    azonicbruce Well-Known Member
    Bruce
    Owasso, OK
    2012 SR5 4x4 Double-Cab
    Same here. I thought for sure there was a defect. But if you read in the manual it states it's supposed to be that way. All my other vehicles it's opposite.
  16. Oct 6, 2012 at 11:09 PM
    #76
    Rich91710
    Rich
    Los Angeles
    08 Base
    Those are good shots Mike.
    As a side note, the connector under the ignition switch with 2 wires on it... Unplug that and you no longer have that annoying beep when you stop at a gas station and open the door while leaving the key in.
  17. Oct 7, 2012 at 7:39 AM
    #77
    Cowboybob
    Cowboybob Well-Known Member
    Is that the connector with the white and blue/yellow wires in it shown above?
  18. Oct 7, 2012 at 8:48 AM
    #78
    Rich91710
    Rich
    Los Angeles
    08 Base
    I think so. It's the only 2-wire connector on the ignition switch, right?
    Side note, if you are going to be taking the truck in for the spiral cable recall, I'd wait and unplug it after that.
  19. Oct 30, 2012 at 4:42 PM
    #79
    CLynch
    CLynch Well-Known Member
    Charlie
    Upstate New York
    None
    10 mins tops. Thanks guys.
  20. Nov 1, 2012 at 5:34 AM
    #80
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    x3, mine is same as this & the one on my car is same way - wide line is longer delay and short line is shortest delay vs wide line meaning more wiping and short line meaning less wiping. INT = delayed wiping so wide line being longer delay just makes more sense IMO but is still nothing to make any big deal about. Adapt and do what works. No different than the + and - on the sport shifter being opposite in my car and the wife's car. Pulling back is + in my car and - in hers. Insignificant shit. Important thing is does it work or not regardless of orientation.
