Interstate or Wallmart replacement battery?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kryten, Jan 16, 2013.
Which battery choice?
Poll closed Feb 15, 2013.
  1. Toyota OEM battery from a dealer for $241
    6.0%
  2. Interstate Mega-Tron Plus 27F for $165
    38.8%
  3. Wallmart Everstart Maxx 27N for $103
    38.8%
  4. Interstate 24F or Duralast Gold 24F battery for around $150-$160
    16.4%
  1. Jan 16, 2013 at 11:39 AM
    98tacoma27
    Ben
    Not Beech Creek
    No.
    24 and 27 are LH.
    24R/F and 27R/F are RH
    Hotdog likes this.
  2. Jan 16, 2013 at 11:43 AM
    kryten
    kryten [OP] Well-Known Member
    Canada
    07 TRD Sport DCSB 6MT 4x4
    1" lift from 3rd gen suspension, 265/75/16 ATs
    Hmm, they are called stealership for a reason. :rolleyes: But seriously, I may have to stop by after work and see if they made a mistake last time.
    Edit: Just googled a bit and you are right. Toyota P/N 00544-27F60-710 is anywhere from $80-$106 online in Toyota Of Dallas for example. I will definitely go to to dealer tonight and see what they have to say.
    I see, thanks again Ben.
  3. Jan 16, 2013 at 12:16 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    i got 10 years out of a duralast gold from autozone. 98 jeep grand cherokee in new england at that!! as noted yes they are made by johnson controls
  4. Jan 16, 2013 at 12:19 PM
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    I like interstates.
  5. Jan 16, 2013 at 12:22 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Walmart batteries are fine. Photocopy your receipt. The original, heat won't last, and Walmart won't honor the warranty without it.
  6. Jan 16, 2013 at 12:35 PM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    Interstate is my choice, I put one of those in my mazda after its battery gracefully died after 5 years, and never had any starting issues after that.
    I put a $60 wally-world battery in my wife's 2004 corolla about 3 years ago and its still running strong. In fact once I fixed her intake manifold gasket issue (improperly designed Toyota gasket caused a serious vacuum leak which lead to severe sputtering at cold temperatures), which helped ruled out the charging system as a problem I couldn't be happier with the starting and charge retention performance of that battery.
  7. Jan 16, 2013 at 1:19 PM
    miniceptor86
    miniceptor86 Well-Known Member
    Jim
    McGregor,IA
    07 Speedway Blue Prerunner Dbl cab
    TRD sport exhaust and cold air intake, nerf and bull bar, RideRide, ProEFX towing mirrors, BakFlip F1 trifold tonneau
    I have a WalWorld battery in my diesel tractor/loader and have had no problems. They last about four years in the worst battery environment possible. It sits up front of the radiator, is exposed to a lot of vibration and shocks, undergoes significant discharges during the winter heating the glow plugs and cranking the cold diesel and sits for weeks unused.
    You could probably do a search on the difference between the F and N suffixes.
    Jim
  8. Jan 16, 2013 at 1:38 PM
    kryten
    Canada
  9. Jan 16, 2013 at 1:44 PM
    4x4Taco2012
    4x4Taco2012 Well-Known Member
    Tim
    Huntingdon Valley, PA
    2022 DCSB Limited 4x4
    TRD lift, TRD SEMA wheels, TRD skid plate, TRD Pro fog lights, TRD Heritage Grill, OEM bed cover, LT275/70/17 Falken Wildpeak AT3Ws, OEM bed lights, OEM all weather floor mats, OEM door skid plates, OEM mud guards, OEM bed mat, Black lug nuts
    Definitely check the dealership again. I just purchased a new Toyota battery from my dealer for my '07 4Runner and it was roughly $90.
  10. Jan 16, 2013 at 1:54 PM
    Wayne
    Wayne Active Member
    san fernando valley
    06 white 4 door long bed,sr5
    front d rings, rubber bed mat, running boards, front oem seat covers,
    Check Costco--Best deal I could find and has more cold cracking capicty and 3 year free replacement.
    Wayne
  11. Jan 16, 2013 at 2:00 PM
    snoope
    snoope Well-Known Member
    Winter Haven Florida
    2002 Tundra Limited 4x4
    I have a Walmart Battery in the Ridgeline and it is fine...Honda wanted twice the $$ while both Advanced and Autozone only had their top of the line in stock...:mad:
    Tacoma is an '02 and only has had 2 battery's..OEM for 6 years and a Duralast since...Not bad for New England ;)..
  12. Jan 16, 2013 at 2:12 PM
    kryten
    Canada
    I could not find neither 24F or 27F in my local Costco. It was the first place I went to check. :D
  13. Jan 16, 2013 at 2:43 PM
    jonny
    jonny Betty White Edition Heep ZJ
    THIS
    got one for my mazda. more CCA and almost half the price of the vatozone gold:cool:
  14. Jan 16, 2013 at 2:44 PM
    jonny
    nvmnd them :p
  15. Jan 16, 2013 at 3:36 PM
    #35
    Treeswing
    Treeswing Member
    Kevin
    Valley of Hearts Delight
    '10 DCLB SPT
    We just went with a AAA battery when ours died. We got nearly stranded in Yosemite a couple years ago, so the roadside service(and general AAA awesomeness) anywhere is what sold me. 27F - 100$
    CAA have the same deal?
  16. Jan 16, 2013 at 4:32 PM
    #36
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    The worst luck in batteries was the Champion brand from Sams, there has been an Everlast in my 68 dodge for 6 years now, I usually get them from the local autoparts store and get the freshest one I can find.
    Howard
  17. Jan 16, 2013 at 4:43 PM
    #37
    tollyr14
    tollyr14 Well-Known Member
    Tolly
    York, PA
    All those batteries are made by the same company FYI
  18. Jan 16, 2013 at 4:54 PM
    #38
    tacomathom
    tacomathom Well-Known Member
    Tom
    It's not new, it's not Mexico
    Get the CHEAPEST battery with the LONGEST free replacement warranty.
  19. Jan 16, 2013 at 4:55 PM
    #39
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    When my yota batt dies interstate it will be for me.
  20. Jan 16, 2013 at 5:07 PM
    #40
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    Hans,
    The OP is Canadian, so Canadian Dollars, not U.S. dollars.
