Interstate or Wallmart replacement battery?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kryten, Jan 16, 2013.
Which battery choice?
Poll closed Feb 15, 2013.
  1. Toyota OEM battery from a dealer for $241
    6.0%
  2. Interstate Mega-Tron Plus 27F for $165
    38.8%
  3. Wallmart Everstart Maxx 27N for $103
    38.8%
  4. Interstate 24F or Duralast Gold 24F battery for around $150-$160
    16.4%
  1. Jan 16, 2013 at 5:25 PM
    #41
    2006TRDSPORT
    2006TRDSPORT 2006TRDSPORT
    Felton, Delaware
    2004 4Runner SR5 4WD
    I bought an everstart from WM 2 1/2 yrs ago, no issues as of yet. I even left my dome light on overnight and it started right up next morning. It cost around $80-90.
  2. Jan 16, 2013 at 7:17 PM
    #42
    kryten
    kryten [OP] Well-Known Member
    Canada
    07 TRD Sport DCSB 6MT 4x4
    1" lift from 3rd gen suspension, 265/75/16 ATs
    Answering my own question. There is an EverLast 27N and a 27S available at Wallmart. Straight from Wallmart website too, from the link I even provided in my first post. :facepalm:
    What does a N or S designation mean
    Model numbers that end in either an (N) or (S) are specifically designed for maximum performance in either the northern or southern regions of the U.S.
    Also went to the dealership. The one for $241 is actually $199, but they assumed $42 for installation for a total of $241. It is 850cca too. I asked about the Toyota TrueStart 710cca 165 reserve one (p/n:00544-27F60-710) many of you got from the dealer for $100 or less. Apparently they can't order them in Canada...
    I will be getting this Wallmart one tomorrow provided it has the correct terminal orientation. It just makes sense for the price and good reviews it gets. Thanks for all suggestions and replies.
  3. Jan 16, 2013 at 8:45 PM
    #43
    RightCoast
    RightCoast Well-Known Member
    Brian
    LBI, Nj
    need's more lift
    Toytec adjustable coilovers, camburg UCA, 5100's in the rear, AAL, 285/75-16 Wardens, Level 8 Mk6 wheels,satoshi grill and BHLM.
    I work in a parts department at a dealer and we use interstate for a lot of applications... Couldn't think of a single bad thing to say, they're a great battery!
  4. Jan 16, 2013 at 9:42 PM
    #44
    Toyotacerttech
    Toyotacerttech Well-Known Member
    Michael
    Texas
    2011 double cab 4x4 TRD
    The Toyota batteries, true-2 and true start, that I get at work come off the interstate truck and they are the ones that warranty them when we get a bad one.
  5. Jan 16, 2013 at 10:40 PM
    #45
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Wallyworld batteries have treated me well surprisingly
  6. Jan 20, 2013 at 11:39 AM
    #46
    kryten
    Canada
    Conclusion:
    Ended up getting the Interstate MTP-27F 710cca 165 reserve battery in the end for $160. It probably is the same one as my original Toyota OEM as I've read somewhere that that particular OEM is made by Interstate. Specs and size are same also.
    When I went to pick up that EverStart Maxx 27N at Wallmart, sadly I realized terminals are reversed and figured it would be too much trouble. Oh well. Would have loved saving $60 this time around, but sounds like I did get a good product at least. Just to add, I've learned that "N" suffix stands for Northern climate and "S" suffix for southern climate for this battery.
    For fellow Canadians, apparently Toyota dealers up here cannot order that particular Toyota TrueStart battery (P/N 00544-27F60-710) that all of the US guys get for $100 or less at the dealer. :pout::canada:
    Thanks everyone for tons of responses and great help once again.
  7. Jan 20, 2013 at 7:39 PM
    #47
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    265/75R16 Falken Wildpeak AT3 LED Bulbs Access Lorado
    Check with NAPA as well.
  8. Jan 27, 2013 at 11:49 AM
    #48
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    Some battery manufacturers make "North" version formulated for cold climates and a "South" version for hot climates. "27" is the BCI [specification] Group Size. "F" is a subgroup indication for terminal placement originally for Fords. "27N" is an attempt to indicate a BCI Group 27 size for Northern climates, but I do not recall if Walmart specified 27 or 27F terminal placement from Johnson Controls on the EverStart branded batteries. So I would recommend that you check the terminal placement before purchasing the 27N. BTW, Johnson Controls also private labels Toyota's TrueStart, Interstate's MegaTron, and AutoZones' Duralast, but there are performance, capacity, and warranty differences between these batteries affecting their cost.
    For more information and tips on buying replacement batteries, please see Section 7 in the Car and Deep Cycle Battery FAQ 2013 on www.batteryfaq.org.
  9. Jan 27, 2013 at 12:57 PM
    #49
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    And Johnson Controls makes the batteries here in Bristol...
  10. Jan 27, 2013 at 5:01 PM
    #50
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Bingo!
  11. Jan 28, 2013 at 4:09 AM
    #51
    Shadetree
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    I would add to PSJ's advise: "that meets the minimum CCA requirments for the coldest temperature driven in".
  12. Jan 28, 2013 at 6:47 AM
    #52
    2004TacomaSR5
    2004TacomaSR5 Sentinel Prime
    Jon
    Montana
    2004 Tacoma DCSB & '79 Toyota Pickup 4WD
    Can't go wrong with an Interstate, I'd avoid NeverStarts though. Only been able to get 6 months to a year out of those.
  13. Jan 28, 2013 at 6:49 AM
    #53
    Kirk1589
    Kirk1589 Well-Known Member
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Pasti-Dip Grille, K&N drop-in, Magnaflow 14", Custom tail light mod, Fog light mod, diff vent mod, Alpine Components, Sequoia JBL radio
    Duralast is crap
  14. Jan 28, 2013 at 6:57 AM
    #54
    Workman
    Workman Well-Known Member
    06 access cab, off road, V6
    Workman's stock battery lasted him six years. On the sixth year, he knew that his battery was surely going to quit so Workman started searching for a good deal. He got an Interstate Megatron 27f at commercial tire for 89.99, 25% off.
    Workman kind of wonders how much longer his stock battery would have gone though!
  15. Jan 28, 2013 at 7:24 AM
    #55
    EFalco50
    EFalco50 Woah! How did that get here?
    Ethan
    Corpus Christi
    2012 Single Cab 4x4
    Weather Tech Floor liners, AFE drop in air filter, BFG All Terrain's, Fog lights, Reese Hitch, Undercoating/Rustproofing,
    Go for a optima if your gonna spend that amount of cash, any AGM style battery is better. Stay away from walmart what ever u do, just make sure its the same series battery 27R or what ever.
  16. Jan 28, 2013 at 8:27 AM
    #56
    fixer5000
    fixer5000 the logical one
    massachusetts
    11 trd sport longbed
    weathertech visors,remote start,lojack, ARE z type topper, wet okole seat covers, pop n lock tailgate lock
    and you base this assumption on what? i got 10 years out of the last one i had in a 98 jeep...beat that number with your facts !!
  17. Jan 28, 2013 at 9:19 AM
    #57
    kryten
    Canada
    Yes, that is a great summary. That is exactly what I've learnt in my research shopping for this battery. You can put it to word much better than I did. :thumbsup:
    Yes, the Wallmart Everstart was labeled 27N, so basically a 27 group battery, but a version designed for northern climates. I needed 27F (ford standard, terminals reversed).
    Purchased Interstate Megatron 27F.
    I got the same Megatron 27F in the end. My OEM lasted 6 years as well.
    Yep, got direct replacement 27F for 27F with exactly same specs. If I'm not mistaken, that particular OEM I had was manufactured by Interstate, so quite possibly it is the same battery with different sticker on it. Can't confirm however.
  18. Jan 28, 2013 at 9:23 AM
    #58
    Kirk1589
    Dave
    Sticks-RI
    03 SR5 Off-Road
    I had one in my last truck. the first one failed me then got it replaced under warranty, then had issues with that so i got a stock ford one
  19. Jan 28, 2013 at 12:26 PM
    #59
    fixer5000
    massachusetts
    if your ford started on the first try the battery woulda lasted a lot longer...heres your cookie :)
  20. Jan 28, 2013 at 2:28 PM
    #60
    Kirk1589
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Good one! But that wasn't the case, after I had the OEM in it was fine.
