Intro to fitting 35s (< 3" Lifts for those that wheel and love alignments)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JoeCOVA, Feb 18, 2019.
  1. Feb 22, 2019 at 9:11 AM
    #41
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Honestly if you're going back and forth eventually you'll probably stick with one size. By the looks of things the rpm variation is negligible. Reading though joe and others experiences with it though if you're running heavier extras plus 33 and up size 529 is the spot. Probably cant go wrong with 488 either, but I'm guessing eventually one tire will be the constant size and not back and forth eventually.
    16Tacos[QUOTED] likes this.
  2. Feb 22, 2019 at 9:16 AM
    #42
    heffer
    heffer Well-Known Member
    Jeff
    Los Angeles
    '15 Magnetic Grey 4X4 TRD Off Road
    Icon Extended Travel, SPC control Arms, OME Dakars, B110's
    Instead of wasting gas doing this, you can remove your coilovers jack one tire up and check for rubbing that way
    PB FAB likes this.
  3. Feb 22, 2019 at 4:26 PM
    #43
    JoeCOVA
    JoeCOVA [OP] Well-Known Member
    Joe
    Colorado Springs
    Ya I’m not pulling a coilover. Not gonna save gas anyway with 35s anyway!
    But it’s a fair point.
    Rockefelluh and mcharfauros like this.
  4. Feb 22, 2019 at 8:36 PM
    #44
    heffer
    Jeff
    Los Angeles
    Pulling a coil over takes 15 minutes. And you get to test fitment through the whole range of travel
    MulletTaco likes this.
  5. Feb 22, 2019 at 8:37 PM
    #45
    JCOOR
    JCOOR Well-Known Member
    TRD Burglar
    And an alignment
    rlx02 likes this.
  6. Feb 22, 2019 at 8:38 PM
    #46
    heffer
    Jeff
    Los Angeles
    Uhmm. No. Not if you’re just pulling the coil overs off
  7. Feb 22, 2019 at 8:41 PM
    #47
    heffer
    Jeff
    Los Angeles
    If you make any height adjustments the. Yeah you’ll need another alignment. But spending the 15 minutes taking the coilovers on and checking fitment that way is way more worth the time and effort you’ll spend checking for rubbing going over speed bumps unless the speed bumps are going to be the extent of your wheeling.
  8. Feb 22, 2019 at 10:06 PM
    #48
    JoeCOVA
    Joe
    Colorado Springs
    Come on over. Takes me way longer than 15 minutes to pull a coilover. Grossly over exaggerating.
  9. Feb 22, 2019 at 10:12 PM
    #49
    erok81
    erok81 Well-Known Member
    Imposter
    Hahahaha. Way longer than 15 minutes. 15 minutes would be me pulling out jack, jacking up truck, placing jack stands, take off wheel, 15 minutes are up.
    Plus if you are doing this correctly you take off coilover, de pressurize coilovee, remove coilover, replace coilover, cycle travel, do whatever, reverse above.
    Eff that. :cool:
  10. Feb 22, 2019 at 10:46 PM
    #50
    heffer
    Jeff
    Los Angeles
    Fine, I guess if you want to count taking getting a jack, putting it up on jack stands add another 15 minutes. If you have the tire off its only 4 bolts and 1 nut for the spindle (6 with reservoirs).
    Why would you even remove any of the nitrogen from the coil over to take it off? Have you tried pulling off your coil overs before?
    I have some time tomorrow, I can pull one of my coiler overs off and record it.
    This is all besides the point. Driving it around on the street isn't going to tell you where you're rubbing when you're off road and actually flexing the truck out. Unless you're really just intending on not taking it off road I guess that's fine and it works.
    Im by no means saying your method is wrong but when I'm cutting I prefer to actually see where Im rubbing and not making guesses about where I am actually rubbing and for how simple it is to actually take a coil over off its really a no brainer to me.
  11. Feb 22, 2019 at 10:49 PM
    #51
    erok81
    Imposter
    No. I’ve never removed a coilover...ever.
    Look at my post again. You de pressurize to cycle the suspension with the coilover, minus coil, installed. Probably over kill for a regular ol, mid travel kit though. I did it with mine to set bumps and the bypass shocks.
  12. Feb 22, 2019 at 10:53 PM
    #52
    heffer
    Jeff
    Los Angeles
    Sure, thats one way to do it to if youre setting hydros, but hydro bumps weren't mentioned here. And this conversation was regarding trimming for wheel fitment...
    Also pretty sure you can cycle your suspension with nitrogen in the coilover.
    synaps3 likes this.
  13. Feb 22, 2019 at 10:57 PM
    #53
    heffer
    Jeff
    Los Angeles
    Side note: this was a well written write-up and you covered the general topic pretty well
  14. Feb 23, 2019 at 3:52 AM
    #54
    JoeCOVA
    Joe
    Colorado Springs
    You obviously didn’t read the post. It’s an intro and has nothing to do with testing for offroad. That’s the the advanced section.
    I’ll probably do a separate thread rather than post so people can ask intro questions in one and advanced questions in the other
  15. Feb 23, 2019 at 9:45 AM
    #55
    heffer
    Jeff
    Los Angeles
    Still doesn't get around the fact that you'll be guessing where you're cutting and how much to cut
  16. Feb 23, 2019 at 1:05 PM
    #56
    JoeCOVA
    Joe
    Colorado Springs
    I didn’t guess and knew where to cut.
    synaps3 and JCOOR like this.
  17. Feb 23, 2019 at 3:21 PM
    #57
    heffer
    Jeff
    Los Angeles
    You seem hurt bud. Like I said multiple ways of doing it. One way being more accurate and precise
  18. Feb 23, 2019 at 6:56 PM
    #58
    Judicar
    Judicar Well-Known Member
    2016 Tacoma TRD OR DCSB
    @JoeCOVA cool post...thank you for the info. I'm looking to start prepping for 35's so this is exactly what I was looking for.
    JCOOR and JoeCOVA[OP] like this.
  19. Feb 23, 2019 at 7:19 PM
    #59
    wood714
    wood714 Got any Quaaludes?
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    35's? How about 44's?
    Jonnyfive5 and JoeCOVA[OP] like this.
  20. Feb 23, 2019 at 7:54 PM
    #60
    erok81
    Imposter
    If you haven’t looked, check out the thread created by @90yota. He was one of the first to throw on 35’s and a small lift. I don’t think his is an instruction list like here. But good info and pics for sure.
    Side note: def go for 35’s. Much better looking :cool:
