Intro to fitting 35s (< 3" Lifts for those that wheel and love alignments)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JoeCOVA, Feb 18, 2019.
  1. Feb 5, 2021 at 2:07 PM
    #1141
    Nkldime70
    Nkldime70 Well-Known Member
    2016 Tacoma trd offroad
    My apologies I should have been more specific. Would I have any clearance issues with the uca? Frame rubbing? Factoring a lift, pinch weld hammered, cab mount relocation already incorporated in. I am gauging to see if spacers will be needed. I would rather not but if I have to what is minimum size (spacer) will I need to clear?
  2. Feb 5, 2021 at 2:16 PM
    #1142
    Silverlogic
    Silverlogic Well-Known Member
    Tyler
    San Diego, California
    2018 Silver DCSB TRDOR
    Spacers make rubbing worse for everything but the UCA.
    Rockefelluh likes this.
  3. Feb 5, 2021 at 2:19 PM
    #1143
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    Are you asking if you’ll rub without any trimming?
  4. Feb 5, 2021 at 2:19 PM
    #1144
    Nkldime70
    You are not wrong. I am hoping that someone with the same specs can chime in, to give me their experience with this wheel/tire combination.
  5. Feb 5, 2021 at 2:21 PM
    #1145
    Nkldime70
    I am aware that trimming will be involved my major concern is the inner clearance of potential rubbing on the uca and frame and having to run wheel spacers.
  6. Feb 5, 2021 at 2:22 PM
    #1146
    Rockefelluh
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    I have a 16x8 -12 offset and that tire size. You won’t rub on the UCA. Even a JBA I don’t think you’ll rub. I rub in mine a little at full lock.
    But you’ll definitely rub on the normal stuff (cab mount, finer fender, top inner fender, front fender.
    whatstcp likes this.
  7. Feb 5, 2021 at 2:22 PM
    #1147
    Nkldime70
    I currently have total chaos UCA and OEM king suspension all around.
  8. Feb 5, 2021 at 2:22 PM
    #1148
    Rockefelluh
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    You’ll be fine on the UCA then. It’s the other stuff that’ll be the normal work.
    JoeCOVA[OP] and whatstcp like this.
  9. Feb 5, 2021 at 2:26 PM
    #1149
    Nkldime70
    Ok that’s what I was hoping. Trimming is not a concern as that comes with the territory. But having to finesse clearance issues with the UCA would be unfortunate. Thank you for your response.
    Rockefelluh[QUOTED] likes this.
  10. Feb 5, 2021 at 3:15 PM
    #1150
    rububeastin
    rububeastin Irvine,Ca
    2019 Tacoma Off-Road 4x4
    I hope you guys can chime in and share some expertise to help me out too. I’ve read this thread a lot and realize I probably should have got -20 offset 16x8 wheels but I ended up ordering a set of tes in September with the following specs
    16x8 0 offset 4.5” bs
    I plan on wrapping them with 315/75r16 atw3s
    I am currently am running the following setup
    -Front Coilovers: King 2.5 Adjustable,
    -Front UCA: Icon Delta Joint
    -Rear Shocks: King 2.5 x 12″ Adjustable
    -Rear Springs: Icon RXT Pack
    -Rear U-Bolt: Archive Garage Flip with 2.7″ Super Bumps
    -Rear Archive Garage Hammer Hangers
    With about 2” of lift
    I have to run spacers in the rear to clear the smoothies but for the front do you guys think I’m going to have uca rubbing issues? Not sure if I should go the spacer route or just ditch the Tes and get a new set? I currently have a pretty aggressive cmc, hammered pinch welds, viper cut and plan on trimming my fenders next month. Can someone shed some light for me I’m pretty stressed out about trying mount them next week lol
  11. Feb 5, 2021 at 3:22 PM
    #1151
    Rockefelluh
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    Not sure as I don’t have those UCAs. If they rub you might wanna try some 1/4 inch front Bora spacers probably be good. Cheap to try out instead of buying new wheels.
    JoeCOVA[OP] likes this.
  12. Feb 5, 2021 at 3:28 PM
    #1152
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    You won't do it no balls
  13. Feb 5, 2021 at 3:29 PM
    #1153
    rububeastin
    Awesome thanks! You think just the .25” would be cool? And not step up to .5”? I was also told a .25 would be cool by Ryan(shmellfab) just want to be safe before I custom order those from bora haha
  14. Feb 5, 2021 at 3:50 PM
    #1154
    Rockefelluh
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    So I would suggest .5”. But the problem is there probably won’t be enough threads left on the studs. You could buy the extended studs, install and then put on the .5” spacers. That’ll for sure keep it off your UCA. I’ve never replaced the studs so don’t know how much work it is.
  15. Feb 5, 2021 at 3:54 PM
    #1155
    rububeastin
    I see that makes sense dam... I guess I’ll try out the .25” and hope it works out lol I appreciate it!
  16. Feb 10, 2021 at 8:57 AM
    #1156
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    285-70-17s should be wider than the 10.5 kendas (if mounted on the same wheel). It should be around ~11.2 inches wide.
  17. Feb 10, 2021 at 8:59 AM
    #1157
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    Cut, tub, weld, replace steering rack. I've thought about it considering all the work going into having 35s fit properly but for how often I wheel, it would be a huge PITA on the streets.
    GillyLink likes this.
  18. Feb 10, 2021 at 10:02 AM
    #1158
    Dampahee
    Dampahee Well-Known Member
    So Cal
    2019 TRD Off Road
    Fox Factory 2.5 extended travel w/DSC Eibach 650x14 springs Fox Factory 2.5 x 12 in smoothies with rr and DSC / Accutune Adventure tune Archive Garage shock relocation Archive Garage hammer hangers with 3.6" shackles Archive Garage high clearance cross bar Deaver Expedition u402 stage1leaf pack Camburg Racing Uniball UCA's Total Chaos Gusseted Spindles Marlin Crawler HD LCA/cam tabs Frame Brace gussets @weldstaco front diff reinforment kit Wheelers u-bolt flip kit with super-bumps Crown performance SS 24 in extended rear brake lines SS extended front break lines Exhaust re-route mod Dirt King Cab Mount Relocation OV Tune-91 Performance Nitro 5.29 Gears ARB Front Locking Differential ARB High output in board compressor Slee On-board compressor mount Blais Bros Taco differential breather mod Schmellfab 12.5° sliders with kick out RCI steel IFS skid RCI steel transmission skid RCI steel T-case skid RCI LCA skid BAMF Rear differential skid Relentless Fabrication hybrid front bumper Relentless Fab High Clearance rear bumper ATHF rear fender supports SOS performance rear disc brake conversion Trimmed Fenders 2.5" Softopper TRD Heritage grill RFT Raptor lights Morimoto XB headlights Baja Designs amber S2 flush mount chase lights Baja Designs S8 30 in lightbar Cali Raised Relay Mount Cali Raised cubby switch mount Smittybuilt X20 10 k winch Factor 55 Fairlead Factor 55 Flatlink E Factor 55 Flatlink Ropeguard Tandem Off Road Manor winch solenoid mount 1.25 inch Spidertrax wheel spacers 17x9 Ultra Wheel x103 beadlocks 35/11.5/17 Nitto Trail Grapplers Fend-X Wheel Liners Clazzio leather seat covers Taco Garage DMM Mount Taco Garage Anytime Front/Rear Camera MESO Customs Chrome Delete MESO Extended fuse cover AVS in channel low-profile wind visors Kicker CS tweeters, 6x9, 6.5's Kicker Key amp Kilmat sound deadening
    yes they are, but a little confusing but I was speaking in regards to the nitto trail grappler 35/11.5. Kendas were too skinny for my liking, so I ended up with the trail grapers.
    rlx02[QUOTED] likes this.
  19. Feb 10, 2021 at 4:35 PM
    #1159
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    I love my nitto ridge grapplers and I know the trail graps are awesome too but both are really heavy for 35s. I’m mostly street too so the trail graps wouldn’t be the best for me. Most likely I’ll get the kenda 35x12.5x17 after I get regeared.
  20. Feb 10, 2021 at 7:44 PM
    #1160
    Dampahee
    So Cal
    2019 TRD Off Road
    my 35/11.5 trail grapplers weight just about the same as the 35/12.5 kendas, 35/12.5 TG is a different story however.
