Intro to fitting 35s (< 3" Lifts for those that wheel and love alignments)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JoeCOVA, Feb 18, 2019.
  1. Apr 19, 2021 at 9:15 AM
    #1261
    KILLINTIME
    KILLINTIME Like a Villain
    This is the first arb bumper I’ve seen that is trimmed exactly like mine. Niiice!
    Dayman Karate[QUOTED] likes this.
  2. Apr 19, 2021 at 9:21 AM
    #1262
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Been sitting on my 35x12.5x17 Mickey Thompson Baja Boss set while I search for wheels. I'm currently on some old school Mickey Thompson wheels as well.. 17x9 with IIRC -12mm offset. They have been awesome for my 33's.. but was wanting/needing to go with something more aggressive. SO.. I'm about to pick up a set of 17x9 -25mm offset Summit Dakars.
    have:
    17x9 -12mm
    285/70/17
    going to:
    17x9 -25mm
    35/12.5/17
    Dampahee likes this.
  3. Apr 19, 2021 at 9:26 AM
    #1263
    Dayman Karate
    Dayman Karate Well-Known Member
    Clay
    Central Alabama
    JKU Rubicon
    https://www.tacomaworld.com/threads/daymans-karate-class-but-you-wont-learn-nothin-4-link-lt-and-previous-iterations.755134/
    Nice! Felt good to slim that thing down a bit.
  4. Apr 19, 2021 at 2:37 PM
    #1264
    Dbodz58
    Dbodz58 Active Member
    Dylan
    Hawaio
    2017 Tacoma TRDOR-SW 6MT
    Go Rhino Raptor Running Boards, switch pros 8100, ditch lights, hidden bumper lights, OEM+ and Prinsu Roof Rack.
    So what's your final offset like? I'm curious about the 315/70/17 but I have 0 offset methods. Hard to find Toyo MTs so I'm trying to expand my tire sizes for ~34" tires lol
  5. Apr 19, 2021 at 2:39 PM
    #1265
    Dbodz58
    Dylan
    Hawaio
    You got a video or any links to help someone DIY these cuts and not look like a 3rd grader did it? Lol
  6. Apr 23, 2021 at 8:18 PM
    #1266
    cementnotgray
    cementnotgray Well-Known Member
    Denver, Colorado
    2019 TRD OR M/T
    35s, 5.29s, OVT
    My attempt at filling the void that trimmed fenders leave
  7. May 5, 2021 at 3:05 PM
    #1267
    cementnotgray
    Denver, Colorado
    2019 TRD OR M/T
    35s, 5.29s, OVT
    So I just test fit the 35s with a spare wheel and they don't rub on the UCAs with 4.5 bs wheels. There's about an inch of clearance. I'm assuming they will rub elsewhere at full lock and such?
  8. May 5, 2021 at 3:15 PM
    #1268
    Dampahee
    Dampahee Well-Known Member
    So Cal
    2019 TRD Off Road
    Fox Factory 2.5 extended travel w/DSC Eibach 650x14 springs Fox Factory 2.5 x 12 in smoothies with rr and DSC / Accutune Adventure tune Archive Garage shock relocation Archive Garage hammer hangers with 3.6" shackles Archive Garage high clearance cross bar Deaver Expedition u402 stage1leaf pack Camburg Racing Uniball UCA's Total Chaos Gusseted Spindles Marlin Crawler HD LCA/cam tabs Frame Brace gussets @weldstaco front diff reinforment kit Wheelers u-bolt flip kit with super-bumps Crown performance SS 24 in extended rear brake lines SS extended front break lines Exhaust re-route mod Dirt King Cab Mount Relocation OV Tune-91 Performance Nitro 5.29 Gears ARB Front Locking Differential ARB High output in board compressor Slee On-board compressor mount Blais Bros Taco differential breather mod Schmellfab 12.5° sliders with kick out RCI steel IFS skid RCI steel transmission skid RCI steel T-case skid RCI LCA skid BAMF Rear differential skid Relentless Fabrication hybrid front bumper Relentless Fab High Clearance rear bumper ATHF rear fender supports SOS performance rear disc brake conversion Trimmed Fenders 2.5" Softopper TRD Heritage grill RFT Raptor lights Morimoto XB headlights Baja Designs amber S2 flush mount chase lights Baja Designs S8 30 in lightbar Cali Raised Relay Mount Cali Raised cubby switch mount Smittybuilt X20 10 k winch Factor 55 Fairlead Factor 55 Flatlink E Factor 55 Flatlink Ropeguard Tandem Off Road Manor winch solenoid mount 1.25 inch Spidertrax wheel spacers 17x9 Ultra Wheel x103 beadlocks 35/11.5/17 Nitto Trail Grapplers Fend-X Wheel Liners Clazzio leather seat covers Taco Garage DMM Mount Taco Garage Anytime Front/Rear Camera MESO Customs Chrome Delete MESO Extended fuse cover AVS in channel low-profile wind visors Kicker CS tweeters, 6x9, 6.5's Kicker Key amp Kilmat sound deadening
    Best way to see where you rub is the pull your suspension/bump stops then use floor jack to fully cycle your suspension at full lock both ways. You'll know exactly what needs to be done at that point.
  9. May 5, 2021 at 3:36 PM
    #1269
    cementnotgray
    Denver, Colorado
    2019 TRD OR M/T
    35s, 5.29s, OVT
    My fenders are cut, pinch weld is smashed, just chopped my cab mount. I spend about $400 on quality 1in spacers and extended ARP studs. Just making sure I didn't spend the money for nothing. But everyone says 3.5 bs so I'm thinking it's still necessary to have the spacers
  10. May 15, 2021 at 9:26 AM
    #1270
    clg
    clg Well-Known Member
    2017 Off-road
    I'll be doing trimming soon to finally clearance for my 315's, and I'll be leaving tabs on the fender to attach a flare to. I intend to use some adhesives to adhere some 90deg tabs I'll fab up directly to the inner fender, then use 1/8th puck board for the liner itself. If you didn't think to leave tabs when cutting, just glue on 3 or 4 tabs onto the fender now and there shouldn't be a problem. I'd recommend avoiding top centre as that seems to be the likeliest spot for a tire to rub, as it would tear the tab off.
  11. May 28, 2021 at 12:47 PM
    #1271
    cementnotgray
    Denver, Colorado
    2019 TRD OR M/T
    35s, 5.29s, OVT
    So I'm rubbing at full lock after installing 1in spacers. I do my own alignments and I pushed it as far as I thought I could but thats the only thing I can think of besides getting a bigger hammer
  12. May 28, 2021 at 1:40 PM
    #1272
    socalexpeditions
    socalexpeditions IG: @socalexpeditions
    There’s a point where Pushing your tire further out makes rubbing worse.
    Here’s my clearance with 17x9 -25
  13. May 28, 2021 at 2:27 PM
    #1273
    cementnotgray
    Denver, Colorado
    2019 TRD OR M/T
    35s, 5.29s, OVT
    Yeah but I only have 3.5in bs with the 1in spacer. Whats your backspacing? Also, did you cut and grind down your pinch weld?
  14. May 28, 2021 at 2:35 PM
    #1274
    socalexpeditions
    4” BS
    Take a picture of your left rear and left front cam tabs for me! What UCA do you have? Have you bashed anything in?
    cementnotgray[QUOTED] likes this.
  15. May 28, 2021 at 2:48 PM
    #1275
    cementnotgray
    Denver, Colorado
    2019 TRD OR M/T
    35s, 5.29s, OVT
    Front driver
    Rear driver
    Front passenger
    Rear passenger
    JBA UCA and I've really just banged in the pinch weld. I see you cut and grinded yours? I can bang in more but I think its an alignment issue because with any flex it would go right back to rubbing. When I was doing it I couldnt get the caster any further without messing up my camber.
  16. May 28, 2021 at 3:15 PM
    #1276
    socalexpeditions
    Oh well this is easy.
    Your cam tabs are at the wrong position for rear on both. They must be maxed out for the most amount of clearance.
    Driver Rear
    Do this for the other side too.
    Then for front cam tabs, pull them in.
    You gain an extra 1” or so just like that. What I do for my alignments (and why I think SPC is best is because you can adjust camber from up top) is max out both rear cam tabs, pull in both front cam tabs, and only tell them to adjust camber/caster off that front cam tab.
  17. May 28, 2021 at 3:38 PM
    #1277
    cementnotgray
    Denver, Colorado
    2019 TRD OR M/T
    35s, 5.29s, OVT
    Yeah I just didnt know I was going 35s when I got the JBAs. Last time I was under there I tried placing the rears all the way in and adjusting the fronts only but again I couldn't get proper camber out of it. I'll give it another try though. Did you cut and grind your pinch weld?
    MountainManGuy likes this.
  18. May 28, 2021 at 3:53 PM
    #1278
    MountainManGuy
    MountainManGuy Well-Known Member
    Colorado
    2019 Toyota Tacoma TRD Off-Road DCSB
    I ran into the same issue. Couldn't get the camber right when I did that. I have SPC's and was able to get a bit of camber correction back with the UCA. It's still not perfect though as I rub the UCA on full lock.
  19. May 28, 2021 at 4:36 PM
    #1279
    JoeCOVA
    JoeCOVA [OP] Well-Known Member
    Joe
    Colorado Springs
    Whats your alignment status? I'm bringing mine back to Rex since I dorked my alignment wheeling.
  20. May 28, 2021 at 5:03 PM
    #1280
    socalexpeditions
    You trade off camber/caster.
    You should be able to zero everything out first, then adjust camber yourself perfectly on the top. Rubbing the UCA on full lock is an offset issue. -25 offset 4” BS will clear UCA, frame, and cab mount.
    XPOTRPR likes this.
