Intro to fitting 35s (< 3" Lifts for those that wheel and love alignments)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JoeCOVA, Feb 18, 2019.
  1. Oct 22, 2021 at 3:28 PM
    #1461
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I was referring to this 502 page thread.
    https://www.tacomaworld.com/threads...g-now-adding-long-travel-and-934-cv’s.626274/
    my bad.
  2. Oct 22, 2021 at 3:33 PM
    #1462
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
  3. Oct 22, 2021 at 3:34 PM
    #1463
    gudujarlson
    Minnesota
    I have no excuse other than being distracted.
  4. Oct 22, 2021 at 3:37 PM
    #1464
    JoeCOVA
    JoeCOVA [OP] Well-Known Member
    Joe
    Colorado Springs
    We both know I wheel and wheel hard. A problem has to exist for it to need a solution/fix. If there is ever an actual problem then this may be an option; but $2000 and a ton of labor, I would be considering other options as well.
    Most of us aren't having issues and our up travel limitations aren't from the inner fenders.
    This may be a good option for 37s, 39s, etc but not sure.
  5. Oct 22, 2021 at 3:38 PM
    #1465
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    For the price it's cheaper to cut and tub, then keep patching when it cracks. It's has an appeal for those that would like bolt on option, but couple beers over weekend with squared tube and it can be done for less. :sawzall::welder:
    JoeCOVA[OP] likes this.
  6. Oct 22, 2021 at 3:39 PM
    #1466
    CGoss
    CGoss Well-Known Member
    Las vegas
    2006 rad red offroad
    Sorry but the part where you say "...severely limit up travel..." Is inaccurate. You are limiting travel less than an inch to fit a 35, thats not severely.
    Its a cool kit, and some people will see the value in it, and others wont. I think this kit really helps when you have LT or the pivot kit, as both push the wheels forward for more firewall clearance and rubbing under the battery tray becomes a bigger issue.
  7. Oct 22, 2021 at 3:47 PM
    #1467
    gudujarlson
    Minnesota
    Idk, I like the idea that if something is worth doing, it’s worth doing right. The thought of taking a sledge hammer to my fender wells is the main reason I ended up going to skinny 33’s instead of something larger.
    CherylJane likes this.
  8. Oct 22, 2021 at 3:51 PM
    #1468
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Well it's out there for those that are interested. The rest of you we'll have to agree to disagree on almost every point you've all made.
  9. Oct 22, 2021 at 3:51 PM
    #1469
    JoeCOVA
    Joe
    Colorado Springs
    I think we can all agree that its a good product and glad something like this is at least available as an option.
    JDSmith and ovrlndkull[QUOTED] like this.
  10. Oct 22, 2021 at 4:02 PM
    #1470
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Yep.
  11. Oct 25, 2021 at 2:39 PM
    #1471
    Trail_limo_pro
    Trail_limo_pro Well-Known Member
    Brian
    Oahu Hawaii
    After running 35s for a while now was wondering if anyone else noticed lots of feedback into the steering wheel. I get that it’s more weight being transmitted into our systems but would love to get the truck 100%. Not sure if our high caster angles or a weak component in our ifs. Maybe heavier duty ball joints or steering rack bushings. Figured I’d ask, see if anyone else noticed this. Info, Spc uca, maxed stock tabs setting E. Thanks
  12. Oct 25, 2021 at 2:50 PM
    #1472
    JoeCOVA
    Joe
    Colorado Springs
    No other than tire balance stuff. What feedback are you getting
  13. Oct 25, 2021 at 2:56 PM
    #1473
    Dayman Karate
    Dayman Karate Well-Known Member
    Clay
    Central Alabama
    JKU Rubicon
    https://www.tacomaworld.com/threads/daymans-karate-class-but-you-wont-learn-nothin-4-link-lt-and-previous-iterations.755134/
    https://jdfabrication.com/collections/05-15-6-lug/products/howe-tc-pump-steering-kit
    I hear great things about this pump upgrade. Sounds like you’re the perfect candidate.
  14. Oct 26, 2021 at 3:31 AM
    #1474
    Trail_limo_pro
    Brian
    Oahu Hawaii
    It just a vague jiggle in the steering wheel. It’s definitely not alignment or balance issue. Going to look for more info on dayman karates recommendation and see if anyone is running this on a 3rd gen
    singletrack_ftw likes this.
  15. Oct 26, 2021 at 6:49 AM
    #1475
    JoeCOVA
    Joe
    Colorado Springs
    Hmm interesting.
    As far as the pump, I’d be surprised if 3rd gens are running it because you can’t use the same mounting location.
  16. Oct 26, 2021 at 11:39 AM
    #1476
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    No, the slide rack does not work with the 3rd gen.
  17. Oct 26, 2021 at 11:45 AM
    #1477
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    except he posted the Howe steering pump kit which also doesn't work on the third gens
  18. Oct 26, 2021 at 12:11 PM
    #1478
    gudujarlson
    Minnesota
    Can someone explain how faster line pressure increase results in less steering wheel feedback when hitting bumps?
  19. Oct 26, 2021 at 12:34 PM
    #1479
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    gives a rough description.. in the description of the Howe kit.
  20. Oct 26, 2021 at 12:38 PM
    #1480
    89hatcher
    89hatcher Well-Known Member
    So what usually breaks when jumping up to 35's?
