Intro to fitting 35s (< 3" Lifts for those that wheel and love alignments)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JoeCOVA, Feb 18, 2019.
  1. Dec 3, 2022 at 5:19 PM
    #1741
    gil_S
    gil_S Well-Known Member
    Seattle, WA
    How much lower backspacing do you think would be required to not rub your sway bar? I was considering 315's with 4.30" or 4.28" backspacing wheels given I have tubular UCAs.
  2. Dec 4, 2022 at 12:06 PM
    #1742
    El Taco Sucio
    El Taco Sucio Well-Known Member
    SoCal (805)
    Silver TRD Sport 4x4
    Mod list... Well, my paint is factory.
    I’m not 100% sure but a 4in bs might clear the sway bar.
  3. Dec 19, 2022 at 10:43 PM
    #1743
    Noelbnetz
    Noelbnetz Active Member
    2022 White Tacoma TRD Off Road
    I'm on a 3 inch lift from Icon, Icon UCA, and with t8 seekers wheels that have -38 offset. I have already got a bmc done. After following and reading this thread for some time, I can probably assume I gotta do a whole BMR to fit 35s on my rig :frusty:
  4. Dec 19, 2022 at 11:00 PM
    #1744
    LordJuicifer
    LordJuicifer Active Member
    2015 MGM Sport
    I have a -25 offset and still rub with a BMR these offsets are rough haha I rub on the firewall not the body mount
    Noelbnetz[QUOTED] likes this.
  5. Dec 20, 2022 at 8:03 AM
    #1745
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Been debating throwing in the max caster front tabs in my Poly Taco tabs kit (currently running neutral front, max rear). I still get some slight rubbing at the firewall (I think some more BFH action will solve that) and slightly on the driver side frame at full lock. Curious if anyone has made that move/adjustment with tabs and what they saw/what it impacted. It should give me even more caster, but not sure how that's affecting the rub on the frame. If its inevitable due to backspacing/tires/etc.. then I wont bother playing with the tabs.
  6. Dec 20, 2022 at 9:25 AM
    #1746
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    So you are saying it drives absolutely fine on highway when making turns at high speed?
  7. Dec 20, 2022 at 9:50 AM
    #1747
    JoeCOVA
    JoeCOVA [OP] Well-Known Member
    Joe
    Colorado Springs
    In an adrenaline induced kind of way.
    CemenTRDgen and Junkhead[QUOTED] like this.
  8. Dec 20, 2022 at 9:54 AM
    #1748
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Ok I thought so:) I will be keeping mine as I travel mountain passes loaded quite often.
  9. Dec 20, 2022 at 10:12 AM
    #1749
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I've taken mine through some gnarly mountain passes... it rolls a bit.. but it is what it is. just drive slower knowing your truck and weight.
    Junkhead[QUOTED] likes this.
  10. Dec 20, 2022 at 10:54 AM
    #1750
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Hm.
    I’m thinking more like if I need to do a quick maneuver at 65+. Or let’s say I’m going downhill 65-70 in a sharp turn and need to brake hard quick. Not that these situations are common, but there are a lot of morons on the road.
    I’m usually at max payload when I travel, so there is that too.
  11. Dec 20, 2022 at 11:01 AM
    #1751
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I mean.. sure, it would help I guess. I tossed mine 10+ years ago and havent even once thought.. "man.. I wish I had my sway bar for ....". just my 2 cents. My truck is over GVWR.. so I know how it goes. I've beefed up everything I can so far to help combat (gusseting, bracing, hangers, custom leaf pack, wilwood bbk, etc). I still feel the truck sway and move occasionally, but that's my doing with building the truck up, Just gotta know the limits and stay within them.
    Junkhead[QUOTED] and JoeCOVA[OP] like this.
  12. Dec 20, 2022 at 11:42 AM
    #1752
    erok81
    erok81 Well-Known Member
    Imposter
    Honestly if you are at max payload, going down hill at 65-70 in a sharp turn and brake hard, sway bar or not that’s probably not going to end well.
    With that said I took mine off long ago as well and drive canyons everyday with a heavy truck and haven’t really ever ran into an issue. I also have fairly soft suspension.
    There’s an easy test you can do. Pull it off and drive around. Hit a canyon. Some turns, etc. see if you like it or not. It’s maybe. 20-30 minute job to remove. Hell, remove the ends and tie them up to test it. That’s even less work.
  13. Dec 20, 2022 at 12:56 PM
    #1753
    JoeCOVA
    Joe
    Colorado Springs
    Its actually not bad at all, you have to take some tight corners pretty fast to induce enough roll to make you pucker. In those cases you slow down a bit, most highways and interstates will never see it, theres only a few mountain roads here that I'm like ok this stretch will be slow.
    Junkhead[QUOTED], erok81 and XPOTRPR like this.
  14. Dec 20, 2022 at 1:04 PM
    #1754
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    this for sure. I found one of those roads and the limits in Oregon coming back from picking up our Camper. Traction control kicked in, but I also had enough roll for the stainless brake lines on my BBK to rub the tires' sidewall lugs. moved them out of the way since then..
    Junkhead likes this.
  15. Jan 20, 2023 at 9:09 AM
    #1755
    El Taco Sucio
    SoCal (805)
    Still debating this...
    Remove sway bar or add a .25-.5" high quality hub centric spacer to get my tire to clear my sway bar? I need to remove my sway bar and measure the clearance needed. I can't seem to get to motorsport-tech.com right now, hopefully they're still around.
    Seriously heavy truck with a couple hundred pounds of weight from racks and RTT, above CG, make me a bit leery about sway bar removal.
  16. Jan 20, 2023 at 9:15 AM
    #1756
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I threw my sway bar away like 10 years ago. My truck weighs ~6600lbs. You adapt and learn.
    Maxx, H3llRid3r, Mully and 2 others like this.
  17. Jan 20, 2023 at 9:15 AM
    #1757
    JoeCOVA
    Joe
    Colorado Springs
    what's a sway bar
    Maxx, H3llRid3r, Mully and 1 other person like this.
  18. Jan 20, 2023 at 9:41 AM
    #1758
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Remove it, it's one of the best free mods.
    I cut mine up and turned it into a gate hinge.
    Gate will still be there a 100 years from now.
    Good luck with your truck.
  19. Jan 20, 2023 at 10:14 AM
    #1759
    El Taco Sucio
    SoCal (805)
    Yeah and it looks like Motorsport-tech might be gone. Phone doesn't go through either.
  20. Jan 20, 2023 at 12:24 PM
    #1760
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
