Intro to Tacoma Trailhunter
Discussion in '4th Gen. Tacomas (2024+)' started by Brentbba, Jun 20, 2024.
  1. Jun 24, 2024 at 10:53 AM
    #121
    ericin1984
    ericin1984 Well-Known Member
    2023 TRD OR Auto
    Wow, 1094lb capacity (as delivered) with a curb weight of almost 5500lb (including the 121 lbs of Chinese weldment junk that was subtracted from the capacity). Where on planet earth did Toyota come up with 1700lbs?
    medicfung, Lt. Dangle and Fast1 like this.
  2. Jun 24, 2024 at 11:28 AM
    #122
    Lunar Squirrel
    Lunar Squirrel Well-Known Member
    24 TRDOR Hybrid SPF100-Octane
    Love the aggressive styling and it looks like a factory prepped over-lander.
    But it should also have a door sticker that reads:
    “Transporting several hundred pounds of sealed nickel-metal hydride underneath your rear passengers may negatively affect payload.”
    medicfung and SH10151 like this.
  3. Jun 24, 2024 at 11:38 AM
    #123
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    *goes to the desert - warranty voided if Toyota finds out*
    RIX TUX and Newwt[QUOTED] like this.
  4. Jun 24, 2024 at 12:40 PM
    #124
    Brentbba
    Brentbba [OP] Well-Known Member
    Tacoma Trailhunter
    Both just a shade under 24"
  5. Jun 24, 2024 at 3:25 PM
    #125
    Fast1
    Fast1 Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
    How many miles do you have on it now?
    Are they p-metric tires? sidewall size and make?
    Somewhat difficult to understand the limited cargo load capacity of a TH at only
    1094 lbs.. (after the reduction of 121 lbs for added equipment)...supposedly improved brakes, revised aftermarket suspension, more load capable 33" tires and new stronger ladder frame.
    my 2021 TRD OffRoad AC is 1150 lbs
  6. Jun 24, 2024 at 4:10 PM
    #126
    Fast1
    Minneapolis, MN
    Isn't the added equipment totaling 121 lbs that which is put on or applied at port?
  7. Jun 24, 2024 at 4:49 PM
    #127
    pinem56
    pinem56 Well-Known Member
    NE
    2018 TRDOR DCSB AT
    I believe so. The window sticker, if the OP would post a photo of it, should indicate what was added at port.
    Fast1[QUOTED] likes this.
  8. Jun 24, 2024 at 6:04 PM
    #128
    Brentbba
    Tacoma Trailhunter
    Goodyear Wranglers 265/70R18
  9. Jun 24, 2024 at 6:06 PM
    #129
    Fast1
    Minneapolis, MN
    which Goodyear Wranglers? there are at least a half dozen types..
    Are they P-metric, C or E rated?
  10. Jun 24, 2024 at 6:08 PM
    #130
    Brentbba
    Tacoma Trailhunter
    Territory RT M&S
  11. Jun 24, 2024 at 6:23 PM
    #131
    Fast1
    Minneapolis, MN
    light weight P-metric tire at 39lbs... 32.6" tire
    Jacob06 likes this.
  12. Jun 26, 2024 at 11:18 AM
    #132
    scottclarkinco
    scottclarkinco Well-Known Member
    Scott
    Denver, Colorado
    2014 MGM TRD Off Road
    A lot. Check out my build page.
    Thanks for that measurement. Was very helpful. One other question I had.....are all 4 windows auto up and auto down? Small stupid thing but just curious.
  13. Jun 26, 2024 at 1:00 PM
    #133
    Brentbba
    Tacoma Trailhunter
    Yes
  14. Jun 26, 2024 at 2:02 PM
    #134
    ericin1984
    2023 TRD OR Auto
    Can you share some pictures of the spare tire and how it is mounted? Full size or compact?
  15. Jun 26, 2024 at 2:04 PM
    #135
    Brentbba
    Tacoma Trailhunter
    Full size, and what I would consider a standard hanging position under the rear of the bed. Nothing new or unique. My 30 year old 1994 Landcruiser had its full size spare mounted the same way.
  16. Jun 26, 2024 at 2:09 PM
    #136
    ace_10
    ace_10 Well-Known Member
    Rural NoVA
    1st Gen, Best Gen X2
    Can you take some pictures of the ashtray: open, closed and halfway?
    :D
    JaKOwNz7, phatso, StayinStock and 2 others like this.
  17. Jun 26, 2024 at 2:15 PM
    #137
    ericin1984
    2023 TRD OR Auto
    So why do the other, non-TH models not fit a full size spare? I thought there was some sort of frame or suspension interference that prevented it, even with the smaller tire sizes.
    taco4moro likes this.
  18. Jun 26, 2024 at 2:27 PM
    #138
    Brentbba
    Tacoma Trailhunter
    Heck if I know. All I can tell you is that there's a full size spare under my Trailhunter. Full Pic of tire and close up showing the tire size. 20240626_142313.jpg 20240626_142325.jpg
  19. Jun 26, 2024 at 2:32 PM
    #139
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    So your tires are different than these that someone else posted...
  20. Jun 26, 2024 at 2:33 PM
    #140
    Brentbba
    Tacoma Trailhunter
    Nope, same Goodyear Wrangler Territory RT
