Introducing New Tacoma Fox Performance Elite Series Shocks
Discussion in 'Suspension' started by Dirt King Fab, Mar 4, 2022.
  1. Mar 4, 2022 at 9:10 AM
    Dirt King Fab
    Dirt King Fab [OP] Well-Known Member
    San Diego
    2013 Toyota Tacoma
    Hey guys we are excited to announce the new 05-22 Tacoma Fox Performance Elite Series Shocks. These will be in stock at Dirt King Fabrication and shipping in 3 weeks, and pair perfectly with our boxed/tubular UCAs. Call today to speak to our sales team and make sure to ask about our Mid Travel Packages 619-944-8913
    Fox Elite Series 2.5 Coilovers | 883-06-178
    The Elite Series 2.5” Fox OEM for the Toyota Tacoma are direct bolt-on replacement shocks intended for maximum performance. These coilovers are specifically designed to optimize off-road performance without compromising on-road handling. The shocks are adjustable for up to 3” of lift and include all necessary hardware needed for installation. Requires aftermarket upper control arms.
    Specifications
    • Wheel Travel: Additional 25% of travel compared to stock
    • Amount of Lift: Allows for 0-3” of lift
    • Adjustments: DSC Adjusters
    • Compatibility: 05-22 Toyota Tacoma 2WD / 4WD
    View Product Listing
    Fox Elite Series 2.5 Smooth Body Shocks | 883-26-112
    The Elite Series 2.5” Fox OEM rear smooth body shocks for the Toyota Tacoma are direct bolt-on replacement shocks. These rear shocks are specifically designed to optimize off-road performance without compromising on-road handling. The shocks will allow for up to 1.5” of lift in the rear, and include all necessary hardware needed for installation.
    Specifications
    • Wheel Travel: Additional 15% of travel compared to stock
    • Amount of Lift: Allows for 0-1.5” of lift
    Race Series vs Elite Series
    Race Series
    • Body: 2.5" Smooth bore and honed seamless alloy body
    • Body Plating: Zinc-plated and double-clear coated for long lasting finish
    • DSC Adjusters: Available in DSC and non DSC options
    Elite Series
    • Body: 2.5" impact-extruded and CNC-machined 6061-T6
    • Body Plating: Type III anodized aluminum body
    • DSC Adjusters: Only available with DSC adjusters
    PAIR FOX SHOCKS WITH DIRT KING UPPER CONTROL ARMS
    Ball Joint UCA's | DK-811901
    Specifications
    • Wheel Travel: Additional 1” of travel compared to stock
    • Track Width: Stock
    • Maximum Backspacing: 4.75”
    • Minimum Rim Size: 16”
    • Coil Over Shock Size: Factory or OEM replacement coilovers
    Bushing UCA's | DK-811902
    Specifications
    MulletTaco and drizzoh like this.
  2. Mar 4, 2022 at 9:13 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    $$ and availability?
  3. Mar 4, 2022 at 9:19 AM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
  4. Mar 4, 2022 at 9:30 AM
    Dirt King Fab
    San Diego
    2013 Toyota Tacoma
  5. Jun 1, 2022 at 3:35 PM
    Dirt King Fab
    San Diego
    2013 Toyota Tacoma
    These shocks are now in stock and ready to ship
  6. Dec 13, 2022 at 6:45 AM
    Jes963
    Jes963 Well-Known Member
    Fontana CA
    2018 Tacoma Trd pro
    @Dirt King Fab fox shock 883-06-178 to get the 3inch lift do you have to adjust the shock or does it come adjusted for max lift? I got a 2018 Tacoma btw
  7. Dec 13, 2022 at 7:38 AM
    BugJuice
    BugJuice Well-Known Member
    I believe for 2016+ trucks the lift is 0"-2" and 2005-2015 is 0"-3". The reasoning is 2016+ is an inch higher that 2005-2015 years.
    AccuTune Offroad likes this.
  8. Feb 19, 2023 at 10:19 PM
    Chief_CNMI
    Chief_CNMI Well-Known Member
    Bryan
    Saipan, Northern Mariana Islands
    2020 4x4 V6 SR5 White
    All lighting are led, wheels, tires, 5100 lift, pro grill, bed light, seat covers, door sill protectors.
    For the 3rd gen models. What are the extended and collapse measurements on these?
    And does anyone know the collapse and extended measurements for Kings 2.5 and the eibach stage 2.0?
