Inverter Question
Discussion in 'Technical Chat' started by YotaGangYotaGang, Oct 15, 2021.
  1. Oct 15, 2021 at 10:26 PM
    YotaGangYotaGang
    YotaGangYotaGang [OP] PreRunners are wannabe 4x4’s
    Covina
    95, 97, 01 Tacoma | 06 Tundra | 07 FJ Cruiser | 08 Prius
    A rtt i never use and 30 light bars
    So I purchased an inverter was 400 watt and the lil heater i bought was 400watt and itll start but then the inverter will poop out, I have the inverter connected to DC 120v outlet (cig lighter). What gives? If I have this correctly the cig lighter can only output around 100w-200w cus its connected to the cig lighter as opposed to the actual battery where I can get the full 400w with battery connections to the terminals? Thx for the help. If this inverter experiment doesnt work then I think its better to just buy a generator imo.
  2. Oct 16, 2021 at 6:58 AM
    MuddySquirrel
    MuddySquirrel Well-Known Member
    Will
    Phoenix
    2015 Taco 6-speed Off-Road
    Short version- yes, you're trying to pull more than the cigarette lighter can supply.
    If you add a new connection to your battery (PROTECT WITH A FUSE OR BREAKER) you should be able to pull the rated 400 watts until your battery runs down. This is still somewhat risky because you are pulling the inverter's rated max as a constant load (inverter will get hot and may shut down after a time) and have no battery protection (likely 1-2 hours before your battery is dead), but should work. You'll need 4-8 ga cable depending on your inverter placement. If you need this for more than defrosting your windows, I'd use that generator or get a fuel based heater.
    Long version with math.
    Let's talk amps. Power is measured in watts, or amps x volts. Volts are how likely something is to short circuit or arc, amps are how likely something is to overheat/melt wires.
    Your inverter is pulling ~37 amps at full draw (400W x 1.1 (efficiency loss) /12v = 36.67 A)
    The cigarette lighter circuit is only good for 10-20 amps. You're overloading the circuit and it's shutting down before it melts. To fix this, you need a circuit capable of supplying more power.
    Blue Sea has a great chart for sizing wiring, take a look at the chart and the article. https://www.bluesea.com/resources/1437
    If you undersize the wiring it heats up and pulls more current, if you undersize it too much it melts and the magic smoke escapes.
    So you'll want to run 4-8 ga wire for your heater circuit. That'll handle the 37 A draw and, as long as the truck's running, your alternator should put that back.
    If the truck's not running, those 37 A have to come from the battery. Not sure what you have installed, but if you're stock it should be in the 45-80 amp hour range. Best case scenario truck gets 2 hours of heater time before the battery is dead.
    Without knowing your precise use case, you're likely better with a generator or fuel-based heater.
  3. Oct 16, 2021 at 7:32 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    aint sain dont do it
    37 amps is a lot o draw........ alot
    inverters are not magic
    they can overheat..................they can start fires
    DC voltage fires are insanely quick
  4. Oct 24, 2021 at 10:17 AM
    mike92y
    mike92y Well-Known Member
    Michael
    Glendale, AZ
    2018 TRD OFF ROAD
    OME all around. SPC UCA. This and that.
    It's responses like these that make TW great. Nothing to add to original question I think it's been answered just want to give everybody a shout out for helping this guy. And OP I hope you have it figured out.
    doublethebass likes this.
